- Thank you received: 4153
Notes from installation of ethercat on Raspberry Pi 4
2 years 1 month ago #309840
Replied by rodw on topic Notes from installation of ethercat on Raspberry Pi 4
2.9.2 may not have the ethercat repositories installed. You may need to do this next
forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories
- bertoldo
2 years 1 month ago #309875
by bertoldo
Replied by bertoldo on topic Notes from installation of ethercat on Raspberry Pi 4
hello rodw!!! Im istall
www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz
and I download a
and install, then I go
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
... So, I got here! ethercat slaves and from here I gave the command and there was no error or anything appeared... and from then on... nothing else...
- bertoldo
2 years 1 month ago #309904
by bertoldo
RODW!!!
I redid it again and it worked! It communicated... thank you very much for your help!
I concluded that I needed to install that package first... and then follow the step by step...
Now I'm going to look for how to configure this in Linux CNC since the communication exists now... is there a specific link for me to configure it? I believe I should be at the part where I configure the Linux CNC software now, right?
- COFHAL
- Thank you received: 62
2 years 1 month ago #309956
by COFHAL
Replied by COFHAL on topic Notes from installation of ethercat on Raspberry Pi 4
What is the correct order for ethercat to work correctly on the PI4, I have tried all the ways and I always get the error that the EtherCAT0 file does not exist in /dev/
- bertoldo
2 years 1 month ago #309996
by bertoldo
hello, I just did this part:
1- www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz
2- forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories and install,
3- forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step ...
ethercat is installed but I haven't been able to communicate with the servo yet... that's what I'm doing now without any major processes.
- COFHAL
2 years 1 month ago #310039
by COFHAL
I have been able to install ethercat on 3 PCs without any problems, but on a Pi4 it has not been possible, it always gives an error when running the ethercat master command. Has anyone had any success in doing so?
Time to create page: 0.618 seconds
