Notes from installation of ethercat on Raspberry Pi 4
5 years 4 months ago #212048 by Hakan
Here is a video I made using the info in this thread.
I think I have accomplished a circular reference between this thread and the video now
The following user(s) said Thank You: arvidb, Rabin, Wesleyooms
5 years 3 weeks ago #222770 by tuzki
Hi. I am a novice and I want to ask you a question.
You said that you did not use PID algorithm, why use PID algorithm in the driver? Shouldn't this PID algorithm be implemented in LinuxCNC?
4 years 3 months ago #247939 by wgn21
In the "make build step" I got the following error:
configure: error: Failed to find Linux sources. Use --with-linux-dir!
make[1]: *** [etherlabmaster.Makefile:31: autoconf] Error 1
make[1]: Leaving directory '/home/laserplasma/Desktop/etherlabmaster/etherlabmaster-code'
make: *** [/home/laserplasma/Desktop/etherlabmaster/configure/E3/RULES_ETHERLAB:73: autoconf] Error 2
Can someone please give some insights on how to solve it? I thought it's to do with the header installation but I think I already did that step using sudo apt install linux-headers-4.19.0-19-all
Please help. Thank you
4 years 3 months ago #247982 by andypugh
Is that the right linux-headers? It does not seem to be for an RT kernel.
Is that an exact match for the output of uname -a ?
4 years 2 months ago #250838 by yi2580
Hello, I have an rk3399 board that I also want to use to install linuxcnc and EtherCAT, but I don't know what. ISO file should be downloaded to enable my card to install linuxcnc and EtherCAT, because this system needs to be real-time, which makes it difficult for me to choose.
I hope someone can give me some advice
4 years 1 month ago #252776 by Drizzt
目前还没有什么好办法,不过如果只是装LinuxCNC的话还是有做到的。原因是etherlab需要对应的head,而目前市面上的RK3399,RK3568等开发板好像都没有提供32位的内核和RT补丁,并且etherlab还没有arch64的版本。摊手。。。
Time to create page: 0.947 seconds
