Notes from installation of ethercat on Raspberry Pi 4
09 Sep 2024 21:40 #309792 by bertoldo
tks! rodw... I will try it!
09 Sep 2024 21:59 #309797 by bertoldo
From what I understand, this is the ISO that is to be downloaded, am I right?
www.linuxcnc.org/iso/linuxcnc_2.9.3-amd64.hybrid.iso
10 Sep 2024 03:29 #309814 by rodw
Thats not for a Raspberry PI. But yes for a normal PC.
What PC are you using?
10 Sep 2024 11:26 - 10 Sep 2024 11:55 #309830 by bertoldo
raspberry pi 4 8 ​​giga ram, instalei 2.9.2 instalação perfeita... agora vou tentar comunicação. tks . Vou postar a evolução... I download link www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz
Last edit: 10 Sep 2024 11:55 by bertoldo.
10 Sep 2024 12:50 #309840 by rodw
2.9.2 may not have the ethercat repositories installed. You may need to do this next
forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories
11 Sep 2024 01:06 #309875 by bertoldo
hello rodw!!! Im istall www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz and I download a forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories and install, then I go forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step ... So, I got here! ethercat slaves and from here I gave the command and there was no error or anything appeared... and from then on... nothing else...
11 Sep 2024 14:05 #309904 by bertoldo
RODW!!!
I redid it again and it worked! It communicated... thank you very much for your help!
I concluded that I needed to install that package first... and then follow the step by step...
Now I'm going to look for how to configure this in Linux CNC since the communication exists now... is there a specific link for me to configure it? I believe I should be at the part where I configure the Linux CNC software now, right?
12 Sep 2024 00:21 #309956 by COFHAL
What is the correct order for ethercat to work correctly on the PI4, I have tried all the ways and I always get the error that the EtherCAT0 file does not exist in /dev/
12 Sep 2024 12:20 #309996 by bertoldo
hello, I just did this part:
1- www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz
2- forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories and install,
3- forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step ...
ethercat is installed but I haven't been able to communicate with the servo yet... that's what I'm doing now without any major processes.
13 Sep 2024 01:27 #310039 by COFHAL
I have been able to install ethercat on 3 PCs without any problems, but on a Pi4 it has not been possible, it always gives an error when running the ethercat master command. Has anyone had any success in doing so?
