EtherCat I/O
3 years 1 month ago #281847 by rodw
Replied by rodw on topic EtherCat I/O
The hardware is only useable in an ethercat environment. Without the xml and ethercat, it is useless!
3 years 1 month ago #281848 by Smitherman
Replied by Smitherman on topic EtherCat I/O
Yeah i will use Ethercat, but an Industrial PLC from one of the members here (udo s). So i will not need the XML file.
So my question is for what the ports can be used, like as a relays port or more, like for communication or even analog I/O.
3 years 1 month ago #281849 by rodw
Please read my response. Please read the XML. Thats all the documentation available. Chapeng and I have worked together. Both of us have one.
If there were any special features, we would have included it in the XML.
2 years 6 months ago #299431 by leandrocontarini
Replied by leandrocontarini on topic EtherCat I/O
It helped a lot friend
thank you very much.
2 years 4 months ago #304137 by Ahmed.emara
Replied by Ahmed.emara on topic EtherCat I/O
i bought this IO module and i have problem with the output ports, i am using out16,15,14 i connected 24V to power supply of this group ( second group ) and i connect my load to the pins and when i try to sent high signal the LED in the module turns on but there is no voltage on the output pin , when i measure the voltage its 0 on high signal and when low signal it gives about 7V
2 years 4 months ago #304142 by rodw
The outputs are probably NPN which means your load needs to go between  the output pin and ground and common will need to be +24V
