EtherCat I/O
2 years 4 months ago #304143 by Ahmed.emara
Replied by Ahmed.emara on topic EtherCat I/O
how?? i want to connect two pins from VFD ( spindle forward and reverse) and do you mean the common is the power input of the group ?
2 years 4 months ago #304147 by rodw
Replied by rodw on topic EtherCat I/O
This may explain things.
control.com/technical-articles/a-look-in...-npn-and-pnp-sensor/
I'm not sure if your device can use negative and positive as a common.
Also have a look at some other ethercat documentation for wiring diagrams
2 years 4 months ago #304148 by Ahmed.emara
i am using this device as you recommended in this post
www.xt-xinte.com/DIEWU-EtherCAT-Slave-IO...Encoder-p748959.html
2 years 3 months ago #305522 by Ethercatuser
Replied by Ethercatuser on topic EtherCat I/O
Hi
I got this unit and I'd like to import it into "codesys".
The xml seems to be a very different format than most esi files I've seen and doesn't import into my app.
Does linuxcnc process a different type of xml to import devices or am I missing something?
2 years 3 months ago #305525 by rodw
Yes, what is used on WIndows is not helpful. The git for the Linuxcnc driver has documentation
github.com/linuxcnc-ethercat/linuxcnc-ethercat
2 years 3 months ago #305537 by Ethercatuser
Now I'm even more confused. I'm not sure if your most recent comment was a response to mine.
The ethercat xml format (esi) is a standard by beckhoff.
www.ethercat.org/en/downloads/downloads_...B2BB2686BBA963EC.htm
It would seem that the driver used for cnc linux is using a different format and that, to be frank, seems like a very odd decision.
They use strange language too, it's a "EtherCAT SubDevice Information (ESI) " that's normally used, a device description file as they are generically known similar to gsdml or iodd. A driver is really a different thing but maybe that's normal language in the cnc world. Tis stuff isn't a windows / linux issue.
I bought one from aliexpress but I suspect the vendor won't have a xml file for it now. I need one in the standard format unfortunately maybe the one created here is based off the standardised format?
I'm surprise you guys aren't using the SOEM library for you master is there a reason? Does the one you linked run in user space?
Time to create page: 0.241 seconds
