EtherCat I/O
3 years 4 months ago #272873 by rodw
Replied by rodw on topic EtherCat I/O
The I/O modules are fairly easy to sort out. The original one might be a bit more challenging as its got a lot more than just I/O on it.
re the servo type
ethercat pdos >pdos.txt and share here. Somebody may have some ideas on where to go.
3 years 4 months ago #272876 by ChapEng
Replied by ChapEng on topic EtherCat I/O
Rod, you pop up everywhere, even if you're not already on the thread hahah.
Attached is the pdos.txt
3 years 4 months ago #272912 by rodw
Yeh, neverr let my mates down :)
It looks it still has the 6040 and 6041 registers so they should map to status word and control word
the other 32 bit registers are probably for commanded position and velocity and actual positin and velocity
SO if you set the drive up the same as the other ones with a control word and a status word and the other 4 pins as the commanded and actual pins was the cia402 drives, you will never now your luck. If we are right,  the actual position should count with movement.
3 years 2 months ago #279042 by Sakhalin_Cat
Replied by Sakhalin_Cat on topic EtherCat I/O
Hello.
Thanks for the information you provided. I found an EtherCat module on Aliexpress - aliexpress.ru/item/1005005335192044.html , but I don't know if it will work with your driver. I don't understand programming and writing a driver on my own causes me difficulties. Therefore, before purchasing this device, I would like to understand that the purchase makes sense. Please see if this device can be used with LCNC and how difficult it is to register it in the system. Modules based on Beckhoff couplers work perfectly on my machine, I am delighted with them. But connecting other non-Beckhoff devices raises only many question for me.
Thanks a lot for your attention. Good luck.
3 years 2 months ago #279043 by rodw
You don't need to write a driver but you do need to configure the ethercat.xml file to access the I/0 machines. That one should be fairly easy to work out and there are examples for weipu and rtelligent already built. There is another I've seen with an encoder nad I would like to try configuring it as the only thing we have now are Beckhoff modules and they are quite expensive!
The following user(s) said Thank You: Sakhalin_Cat
3 years 2 months ago - 3 years 2 months ago #279078 by jjdege
Replied by jjdege on topic EtherCat I/O
Hi everyone
i would like to report this I/O device,  www.bausano.net/en/hardware/easyio.html
it has everything needed for a CNC machine and XML file configured for LCNC, I have it and it works.
bye thank you
Last edit: 3 years 2 months ago by phillc54. Reason: Show link address
Time to create page: 0.230 seconds
