asd-a2-e ... lcec driver?
2 years 7 months ago - 2 years 7 months ago #295740 by jjdege
Replied by jjdege on topic asd-a2-e ... lcec driver?
HI
In the .ini file,
SCALE = ..... positive the axis goes in one direction, if you put " - " in the other,
the number corresponds to the mm, or in, which the axis travels in one rotation
Last edit: 2 years 7 months ago by jjdege.
2 years 6 months ago #298980 by zmrdko
Replied by zmrdko on topic asd-a2-e ... lcec driver?
Is sii_write permanent?
I am loosing my sii settings after drive reboot.
forum.linuxcnc.org/ethercat/52425-esi-write-lost-after-reboot
2 years 6 months ago #299003 by GuiHue
Replied by GuiHue on topic asd-a2-e ... lcec driver?
For stuff like rotation (CW, CCW) vs Forward/Reverse on the axis I would always go through the servo setup itself using the manufacturers software (here: asda soft). In fact, this is the first thing i always do.
11 months 2 days ago #339490 by Beovoxo
Replied by Beovoxo on topic asd-a2-e ... lcec driver?
Cyclic synchronous velocity mode only ? are you running external scale encoder or motor encoder on your setup. i am really confused... I thought ASD-A2-E could be running PT modes ? Motor encoder + Glass scale encoder ???
10 months 1 week ago #340370 by Beovoxo
Many thanks for the warning i would have used it if i have seen it before starting my build :(:(:( ... So right now im stucked hard, "mounted glass scales and most of the components , and the finding out that i cant go fully close loop :(:( its a REALLY HARD DAY... may i ask what did you do ? running the system just with the motor encoders ?
10 months 1 week ago - 10 months 1 week ago #340373 by Hakan
Replied by Hakan on topic asd-a2-e ... lcec driver?
Wasn't around here when all this started. lcec_deasda driver has limitations. Ok. Don't use that driver then.
What about using the "generic" driver? Or the basic_cia402. Prefer the "generic" driver)
Is this the drive in question deltronics.ru/images/manual/ASDA_A2-E_UM_EN_20150430.pdf ?
Chapter 5.3 describes CSP mode which you want to use. Looks like a normal cia402 drive to me,
shouldn't be too difficult to get going.
Last edit: 10 months 1 week ago by Hakan.
Time to create page: 0.139 seconds
