asd-a2-e ... lcec driver?
9 months 6 days ago - 9 months 6 days ago #341961 by cncfreak
Replied by cncfreak on topic asd-a2-e ... lcec driver?
File Name: ASDA_A2E_2...1-26.xml
File Size:8.62 KB
File Name: Ethercat_slv.txt
File Size:38.5 KB
Use this xml file instead. There are all the ios configured.
Also you have to program on each drive the following:
P2-18 -> 0x0130
P2-19 -> 0x0131
P2-20 -> 0x0132
P2-21 -> 0x0133
P2-22 -> 0x0134
P4-06 -> 0x0000
Or use the attached parameter file if you have the asda-soft.
Rename the *.txt file to *.par
Last edit: 9 months 6 days ago by cncfreak.
9 months 4 days ago #342061 by Mr. Mass
Replied by Mr. Mass on topic asd-a2-e ... lcec driver?
Thanks for the explanation, the outputs are working with these settings. I was surprised that there are hidden parameters for the outputs. I didn't see them in any manual, or in asda soft either. But the inputs are still not working. Maybe there are hidden settings for the inputs too? Or am I missing something else?
9 months 3 days ago - 9 months 3 days ago #342166 by cncfreak
Have you download to drive the parameter file i attached?Check the manual for the Asda-A2 drive has more detailed infos.
Last edit: 9 months 3 days ago by cncfreak.
8 months 4 weeks ago #342341 by Mr. Mass
Of course, the first thing I did was upload your *.par file to the servo. But there was a problem: the firmware versions didn't match. Your file was 01.645, and my drive was 01.644. ASDA software did the conversion, but the DI didn't work.
I found a solution: parameter P3-18 must be set to 0x1000, then the inputs start working from linuxcnc. This works for me, perhaps this will also help someone with the problem of non-functioning DI.
8 months 4 weeks ago #342342 by cncfreak
Strange because in the attached parameter file the P3-18 is also set to 0x1000h.
8 months 3 weeks ago #342526 by Mr. Mass
Thank you very much for this screenshot. For a long time, I couldn't understand why the manual didn't match the hardware. It seems that the old firmware was done differently...
Time to create page: 0.211 seconds
