- Thank you received: 59
From your pictures of the drives I would also recommend you go and look at the correct installation/wiring recommendations in the manual before you damage one of the drives. (Space around the drive, and not daisy chaining the wiring like you have). I get it is a test setup... so might be changed in the future.
It appears you have issues with the lcec_conf module?
