Marco Reps video on youtube about EtherCAT
2 years 8 months ago - 2 years 8 months ago #294469 by scottlaird
Heh. Yeah, well, it's open source and we give credit. "steal" might be overstating things.
I'm curious how long it'll take him to throw an EtherCAT module in the MX2. That plus maybe a pair of RJ45<->fiber converters would completely eliminate his EMI problem. My MX2 EtherCAT board is due tomorrow, but I'm running low on time to get VFD "vl" mode working before I spend a big chunk of March on airplanes.
Also, I'm curious if his 1000 Hz MX2 can do vector mode at > 400 Hz, or if it's just V/F.
Last edit: 2 years 8 months ago by scottlaird.
2 years 8 months ago #294472 by tommylight
No idea, it's been quite some time since i messed with VFD's, time, i have 2 collecting dust in the shop, one has RS485 and i have 2 of USB to RS485 dongles dangling somewhere. Had another one with vector mode up to 400Hz but got drenched in coolant fluid when i gave it to some friends :(
But he has another video just for that spindle and control box so might be more info there. And another visiting the factory, i think.
2 years 8 months ago #294490 by rodw
Oooh, he's done work on CiA 402 homing modes? I may have to steal that next month.
I'll have to steal your code the following month!
I started on this soon after the homemod was released  but then Dewey rewrote the interface so it was obsoleted.
github.com/rodw-au/ciahome
My intent was to move all of the cia402 pins from Dominic's component into joint pins. I'm not sure if that was the right approach...
My bitmapped structs might be of interest. By utilising  a union, we can publish both the status word and its bitmapped pins which makes the code more readable....
github.com/rodw-au/ciahome/blob/main/ciahome.comp#L144
2 years 5 months ago #301536 by chrisfischer
Im trying to be inspired by these drives, looking at the manual I see it has touch probe functions in the drive itself. Does anybody know why one would want the touch probe to be wired directly to the drive? And is the probe wired directly to all x,y,and z drives in parallel?
Thanks for your knowledge.
2 years 5 months ago #301543 by dm17ry
i'm not sure about ethercat, but e,g, mechatrolink protocol has a LATCH function when drives remember the value of the motor position counter on a rising edge of external signal. this should give better resolution than sensing the probe at the controller and then reading back position. i guess ethercat does the same
The following user(s) said Thank You: tommylight, Aciera, chrisfischer
2 years 4 months ago #302157 by eduard
"Also, I'm curious if his 1000 Hz MX2 can do vector mode at > 400 Hz, or if it's just V/F."
Yes it can. I'm using the same way, with EtherCAT hat.
