Marco Reps video on youtube about EtherCAT
2 years 2 months ago #309164 by Evgeny
I have this
/home/cnc/hal-cia402
o_Oimage missing /media/kunena/emoticons/shocked.png
2 years 2 months ago #309165 by chrisfischer
Is the ethercat-conf.xml file in the ~/dev/hal-cia402 directory?
Good question, should have mentioned. yes its in there. it wasnt clear from the instructions if anything else is needed like hal files etc.
So right now there is the ethercat-conf.xml the cia402.comp and the lincense and readme files. there is also an example folder with a less complete ethercat-conf.
i used the marcos ethercat-conf file and removed some info as i only have two drives under power right now.
Warning: Spoiler!
2 years 2 months ago #309166 by chrisfischer
Hi. If you figure out how I can send you 10GB of data, I can send you an acronis image of my system, the drivers are already installed and the configuration runs.
Thank you very much for the offer. wouldnt this be full of configurations made exactly to your hardware? not sure this is the best method to fix...
2 years 2 months ago #309168 by jimwhiting
You might want to check the ethercat_conf file name... You config uses ethercat-conf (hyphen) where the files is usually an ethercat_conf (underscore).
2 years 1 month ago #309184 by COFHAL
2 years 1 month ago - 2 years 1 month ago #309185 by chrisfischer
Thanks for the comments guys, running this fixed my issue.(not sure why)
sudo apt update
sudo apt install -y linux-headers-$(uname -r) ethercat-master linuxcnc-ethercat
Last edit: 2 years 1 month ago by chrisfischer.
Time to create page: 0.076 seconds
