EasyCAT Arduino shield
1 year 4 months ago #330560 by Hakan
Replied by Hakan on topic EasyCAT Arduino shield
Can you share how to create the eeprom content from an XML file?
1 year 4 months ago #330562 by meister
Replied by meister on topic EasyCAT Arduino shield
what will you pay me for it ?
;P
Converter:
github.com/synapticon/siitool
eepromtool (write flash):
github.com/OpenEtherCATsociety/SOEM/blob...romtool/eepromtool.c
1 year 4 months ago #330563 by meister
create:
$ siitool -m  -c -o eeprom.bin esi.xml  = eeprom.bin generated
check:
$ siitool -p eeprom.bin  Error, SII probably malformed. No 0xffff at the end found First print preamble and config Preamble: PDI Control: ................ 0x0c80 PDI Config: ................. 0xee42 Sync Impulse Length: ........ 2000 ns (raw: 0x00c8) PDI Config 2: ............... 0x0000 Configured Station Alias: ... 0x0000 Checksum of Preamble: ....... 0x003c (ok) Identity:   Vendor ID: ................ 0x00400000   Product ID: ............... 0x00000715   Revision ID: .............. 0x00002ef8   Serial Number: ............ 0x00000000 Default mailbox settings:   Bootstrap Mailbox:   Received Mailbox Offset: .. 0x0000   Received Mailbox Size: .... 0   Send Mailbox Offset: ...... 0x0000 ....................       Entry 8:       Entry Index: .............. 0x60fd       Subindex: ................. 0x00       String Index: ............. 64 (Digital inputs)       Data Type: ................ 0x07 (Index in CoE Object Dictionary)       Bitlength: ................ 32
1 year 4 months ago #330565 by Hakan
Ok, I have seen those.
When you write an eeprom this way and then list the pdos with "ethercat pdos", do you see the ones you expect to see?
1 year 4 months ago - 1 year 4 months ago #330566 by meister
accidentally flashed my ethercat servo with something wrong, and restored everything with this tool and the original esi xml
so yes, it really works
I use it to configure my LAN9252 board
EDIT:
uhhh, found this site: markosankovic.github.io/2016/06/28/esi-to-sii-binary.html
i think i need to test this '
ethercat sii_write ...
I must have overlooked it somehow :)
Last edit: 1 year 4 months ago by meister.
1 year 4 months ago #330581 by meister
because of the strange licenses from siitool i will write my own in python
Time to create page: 0.200 seconds
