EasyCAT Arduino shield
2 years 7 months ago #296803 by RDA
Replied by RDA on topic EasyCAT Arduino shield
Aah so the J45 is a stacked one, now it makes more sense.
Thanks for clarifying!
2 years 7 months ago #296809 by tommylight
Replied by tommylight on topic EasyCAT Arduino shield
the EtherCAT Click has two ports, the first picture is somewhat misleading
It sure is, looks like a single port connector, while it does explicitly mention the chip has 2 full speed 100M ports with auto negotiation.
2 years 7 months ago #296815 by zmrdko
Replied by zmrdko on topic EasyCAT Arduino shield
What ethercat slave controller does it use?
Other interesting device is Mikroe Ethercat Click
www.mikroe.com/ethercat-click
same: LAN9252
this is maybe the same thing
2 years 7 months ago #296816 by zmrdko
I did not documentation in the bausano site but I assume this is just the LAN9252 shield? Or does it have also an MCU so that you can plug a shield into this board?
just LAN9252 shield - it requires arduino or nucleo to be attached and running certain code
2 years 7 months ago #296817 by jjdege
Replied by jjdege on topic EasyCAT Arduino shield
Hello,
I have acquired EasyCAT shield for Arduino. It's working pretty well and very customizable.
HI
I confirm the versatility of EasyCAT, I built  this pendant in EtherCAT for LinuxCNC
with EasyCAT and an ItsyBitsy M0, less bulky than an Arduino and with the pins needed.
The following user(s) said Thank You: PHILCOAST, RDA, zmrdko
2 years 7 months ago #296818 by RDA
Very cool, thanks for sharing.
The following user(s) said Thank You: jjdege
Time to create page: 0.079 seconds
