- Thank you received: 167
it looks like ethercat slave devices need their own ethercat IC, it doesnt look like you can do it in software, at least i have not found any examples/codeThis Ethercat setup looks like it could be a better solution, assuming all I have to do is add a magjack to the PCB.
I think you're right. After you mentioned that I looked at the Ethercat application note and they specifically refer to slave devices as requiring an ESC or Ethercat Slave Controller that contains the ethernet PHY. It can be built in FPGA too but from what I gather the slaves are hardware.
