EasyCAT Arduino shield
1 year 4 months ago #330583 by Hakan
Replied by Hakan on topic EasyCAT Arduino shield
I see, the "-m" flag makes it write the pdos.
But what about the sdos? I don't see them coming over.
1 year 4 months ago #330584 by meister
Replied by meister on topic EasyCAT Arduino shield
I haven't seen it yet either :( but I haven't used it yet either
1 year 4 months ago - 1 year 4 months ago #330616 by Hakan
The xml to eeprom translation is a missing piece. With the pdos and sdos. Siitool comes halfway.
Currently I see no other option than to use TwinCAT. If there was a way for TwinCAT to only do
the translation of xml into an eeprom binary file that would help. But no, I have to take out the card
from the machine and bring it to the Windows/Twincat machine and flash the eeprom from the xml file
with TwinCAT.
If you like JavaScript, you can start from the eeprom_generator which already can do the eeprom content,
without pdos and sdos again. There is a src/generators/EEPROM.js you can have a look at.
EasyCAT uses LAN9252 I have read so should be directly usable.
github.com/MetalMusings/MyOwnEtherCATDev...ils/EEPROM_generator
Last edit: 1 year 4 months ago by Hakan.
1 year 4 months ago #330628 by meister
already a good starting point :)
github.com/multigcs/esitool
The following user(s) said Thank You: Hakan
1 year 4 months ago #330635 by meister
new discovery, there is no sdos data in the eeprom.
could not find any in the documentation or in a sanmotion servo eeprom, the data is probably read from the firmware.
1 year 4 months ago #330641 by Hakan
You are right.
I read out eeprom from a slave I know has SDOs.
But nothing with the SDO names in the eeprom bin file.
So, it is possible the siitools -m could produce a good eeprom.
I'll test later this evening, I have a device I can experiment with.
Time to create page: 0.069 seconds
