Problems with Lichuan Ethercat servo drive
- tar_san
27 Jun 2025 22:39 #330941
by tar_san
Replied by tar_san on topic Problems with Lichuan Ethercat servo drive
I succeeded LC10E driver homing with incremental encoder + origin, limit switch with my own homing codes.
- Luckbiturbo
12 Jul 2025 10:06 #331725
by Luckbiturbo
Replied by Luckbiturbo on topic Problems with Lichuan Ethercat servo drive
Hi MaxEkb77, did you solve it? I found the same problem with your same servo in CSP mode
- MaxEkb77
- Thank you received: 9
12 Jul 2025 21:38 #331739
by MaxEkb77
Replied by MaxEkb77 on topic Problems with Lichuan Ethercat servo drive
I contacted support - they said it was normal.
I'm trying to work on my milling machine - I haven't found any problems yet.
- stirra
14 Jul 2025 00:08 #331798
by stirra
Replied by stirra on topic Problems with Lichuan Ethercat servo drive
Could you post your configuration files? I still have been unable to get homing to work correctly with the Lichuan LC10E and a home switch.
- MaxEkb77
14 Jul 2025 06:30 #331806
by MaxEkb77
I use abs position, when set to zero i reset encoder multiturn position.
If you need a ini setup for abs, late copy this side a config.
- stirra
14 Jul 2025 19:04 #331828
by stirra
I was hoping @tar_san could post his files, as he indicates he got homing with external limit and origin switches working. I had thought I had homing figured out back in January, but discovered it was only working for Z index pulse homing, not external switch homing. I then had to set the project aside for six months due to a high priority consulting project, and am back on my LCNC ethercat quest again.
-- Ralph
-- Ralph
- stirra
15 Jul 2025 00:43 #331841
by stirra
Actually, now that I have done more testing and fixed on issue in my ini file (had HOME_SEQUENCE=1 for all joints instead of 0), my original instructions at forum.linuxcnc.org/ethercat/54908-missin...-homing-lc10e#318671 appear to work correctly for homing LC10E drive with an external home switch on DI2.
-- Ralph
-- Ralph
- MaxEkb77
15 Jul 2025 07:30 #331848
by MaxEkb77
You can make "no encoder reset" & use standart linuxcnc homing procedure
- tar_san
15 Jul 2025 22:16 #331871
by tar_san
Hello.
I had to recreate LC10 homing code from zero reading manual designated for a driver with a motor with incremental encoder . ( I thought original code was difficult to fix )
If you still have some problems, I consider to open my codes...( I have something to do for some improvement )
- mra7768
16 Jul 2025 13:03 #331895
by mra7768
Replied by mra7768 on topic Problems with Lichuan Ethercat servo drive
Hi, I’d like to ask — which version of LinuxCNC and kernel are you currently running?
Time to create page: 0.346 seconds
