Help,with the EtherCAT config
- timaer
- Thank you received: 4
06 May 2024 08:30 #299909
by timaer
Replied by timaer on topic Help,with the EtherCAT config
Well,I updated the hal file ,and the error still ,but the msg changed as following ..
Debug file information:
Note: Using POSIX realtime
Failed to execute SDO download: Input/output error
LCEC: slave 0.0: Failed to execute SDO download (0x2000:0x00, size 2, byte0=112, error -5, abort_code 08000000)
LCEC: failed to configure slave 0.0 sdo 2000:00
LCEC: slave 0.0: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -5, abort_code 06090011)
LCEC: failed to configure slave 0.0 sdo 2007:06
LCEC: slave 0.0: Failed to execute SDO download (0x2007:0x05, size 1, byte0=5, error -5, abort_code 06090011)
LCEC: failed to configure slave 0.0 sdo 2007:05
LCEC: slave 0.0: Failed to execute SDO download (0x2011:0x00, size 2, byte0=1, error -5, abort_code 08000000)
LCEC: failed to configure slave 0.0 sdo 2011:00
LCEC: slave 0.0: Failed to execute SDO download (0x607c:0x00, size 2, byte0=0, error -5, abort_code 08000000)
LCEC: failed to configure slave 0.0 sdo 607c:00
LCEC: slave 0.0: Failed to execute SDO download (0x609a:0x00, size 2, byte0=244, error -5, abort_code 08000000)
LCEC: failed to configure slave 0.0 sdo 609a:00
LCEC: slave 0.0: Failed to execute SDO download (0x6099:0x01, size 2, byte0=196, error -5, abort_code 08000000)
LCEC: failed to configure slave 0.0 sdo 6099:01
LCEC: slave 0.0: Failed to execute SDO download (0x6099:0x02, size 2, byte0=244, error -5, abort_code 08000000)
LCEC: failed to configure slave 0.0 sdo 6099:02
LCEC: slave 0.1: Failed to execute SDO download (0x2000:0x00, size 2, byte0=112, error -5, abort_code 06090031)
LCEC: failed to configure slave 0.1 sdo 2000:00
LCEC: slave 0.1: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -5, abort_code 06090011)
LCEC: failed to configure slave 0.1 sdo 2007:06
LCEC: slave 0.1: Failed to execute SDO download (0x2011:0x00, size 2, byte0=1, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.1 sdo 2011:00
Failed to execute SDO download: Invalid argument
LCEC: slave 0.2: Failed to execute SDO download (0x2000:0x00, size 2, byte0=88, error -22, abort_code 5142f089)
LCEC: failed to configure slave 0.2 sdo 2000:00
LCEC: slave 0.2: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -22, abort_code 00000000)
LCEC: failed to configure slave 0.2 sdo 2007:06
LCEC: slave 0.2: Failed to execute SDO download (0x2011:0x00, size 2, byte0=0, error -22, abort_code 00000000)
LCEC: failed to configure slave 0.2 sdo 2011:00
Failed to register PDO entry: No such file or directory
LCEC: master 0 PDO entry registration failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./cia402.hal:15: waitpid failed /usr/bin/rtapi_app lcec
./cia402.hal:15: /usr/bin/rtapi_app exited without becoming ready
./cia402.hal:15: insmod for lcec failed, returned -1
HAL: ERROR: pin 'lcec.0.3.out-01' not found
shutdown.hal:2: unlink failed
3960
Stopping realtime threads
Unloading hal components
LCEC: exiting
3960
- onceloved
- Thank you received: 59
06 May 2024 08:33 #299910
by onceloved
Replied by onceloved on topic Help,with the EtherCAT config
Can you use remote assistance?
- timaer
06 May 2024 08:37 #299912
by timaer
I'm afraid not ,I didn't find remote assistance in linuxcnc Raspberry Pi 5 image.Does the error showing up indicate my connection of the hardware wrong ? I just use my Raspberry Pi 5 connect the leashine L7 servo and step moter 556 ,I didnt use Beckhoff Bus ,is this the possible reason ?
- onceloved
06 May 2024 08:39 #299913
by onceloved
Please wait a moment. I will change your configuration and upload it later.
The following user(s) said Thank You: timaer
- timaer
06 May 2024 08:40 #299914
by timaer
That's very nice of you ! Thanks a lot!
- onceloved
06 May 2024 08:47 #299916
by onceloved
Type ethercat cstruct in the terminal to see what is returned
- timaer
06 May 2024 08:58 #299917
by timaer
cnc@raspberrypi:~$ ethercat cstruct
/* Master 0, Slave 0, "L7EC-750"
* Vendor ID: 0x00004321
* Product code: 0x00000093
* Revision number: 0x00000001
ec_pdo_entry_info_t slave_0_pdo_entries[] = {
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60b8, 0x00, 16},
{0x603f, 0x00, 16},
{0x6041, 0x00, 16},
{0x6061, 0x00, 8},
{0x6064, 0x00, 32},
{0x60b9, 0x00, 16},
{0x60ba, 0x00, 32},
{0x60fd, 0x00, 32},
ec_pdo_info_t slave_0_pdos[] = {
{0x1600, 3, slave_0_pdo_entries + 0},
{0x1a00, 7, slave_0_pdo_entries + 3},
ec_sync_info_t slave_0_syncs[] = {
{0, EC_DIR_OUTPUT, 0, NULL, EC_WD_DISABLE},
{1, EC_DIR_INPUT, 0, NULL, EC_WD_DISABLE},
{2, EC_DIR_OUTPUT, 1, slave_0_pdos + 0, EC_WD_ENABLE},
{3, EC_DIR_INPUT, 1, slave_0_pdos + 1, EC_WD_DISABLE},
{0xff}
/* Master 0, Slave 1, "DM3E-556"
* Product code: 0x00008100
ec_pdo_entry_info_t slave_1_pdo_entries[] = {
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60b8, 0x00, 16},
{0x603f, 0x00, 16},
{0x6041, 0x00, 16},
{0x6061, 0x00, 8},
{0x6064, 0x00, 32},
{0x60b9, 0x00, 16},
{0x60ba, 0x00, 32},
{0x60fd, 0x00, 32},
ec_pdo_info_t slave_1_pdos[] = {
{0x1600, 3, slave_1_pdo_entries + 0},
{0x1a00, 7, slave_1_pdo_entries + 3},
ec_sync_info_t slave_1_syncs[] = {
{2, EC_DIR_OUTPUT, 1, slave_1_pdos + 0, EC_WD_ENABLE},
{3, EC_DIR_INPUT, 1, slave_1_pdos + 1, EC_WD_DISABLE},
{0xff}
cnc@raspberrypi:~$
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60b8, 0x00, 16},
{0x603f, 0x00, 16},
{0x6041, 0x00, 16},
{0x6061, 0x00, 8},
{0x6064, 0x00, 32},
{0x60b9, 0x00, 16},
{0x60ba, 0x00, 32},
{0x60fd, 0x00, 32},
{0xff}
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60b8, 0x00, 16},
{0x603f, 0x00, 16},
{0x6041, 0x00, 16},
{0x6061, 0x00, 8},
{0x6064, 0x00, 32},
{0x60b9, 0x00, 16},
{0x60ba, 0x00, 32},
{0x60fd, 0x00, 32},
{0xff}
cnc@raspberrypi:~$
- onceloved
06 May 2024 09:09 - 06 May 2024 09:10 #299918
by onceloved
Try using these two files
Pay attention to changing the file name of the hal file.
Last edit: 06 May 2024 09:10 by onceloved.
- timaer
06 May 2024 09:12 #299919
by timaer
Thanks a lot ,I 'll try it now
- onceloved
06 May 2024 09:17 #299920
by onceloved
The three errors in the xml file have not been changed. Use the xml file I re-uploaded.
Time to create page: 0.260 seconds
