Help,with the EtherCAT config
06 May 2024 09:17 #299921 by timaer
Replied by timaer on topic Help,with the EtherCAT config
Hi,there is still an error ,I dont know what it is
Debug file information:
Note: Using POSIX realtime
./cia402.hal:49: Pin 'lcec.0.0.cia-statusword' does not exist
HAL: ERROR: pin 'lcec.0.3.out-01' not found
shutdown.hal:2: unlink failed
6048
Stopping realtime threads
Unloading hal components
06 May 2024 09:20 #299923 by onceloved
Replied by onceloved on topic Help,with the EtherCAT config
Use my latest uploaded xml file and comment this line in the ini file
SHUTDOWN = shutdown.hal
The following user(s) said Thank You: timaer
06 May 2024 09:33 #299924 by timaer
Excellent!it works! there is no errors now! and I runned the panel successfully.
06 May 2024 09:36 #299925 by onceloved
If you want the motor to rotate, you need to set the gear ratio correctly. Servo motors are easy to use. I have never used stepper motors.
07 May 2024 02:03 #299991 by timaer
Thanks a lot.As the "ethercat slaves" info showing ,it seems that I used DM3E EtherCAT stepper motor.Yesterday ,when I runned the pannel and I tried to rotate the motor, the servo displayed an error er824 ,which I checked it from the website meaning "Error description: Invalid process data input mapping", so maybe it just what you advised me to set the gear ratio. but I 'm not sure of it .I'm totally new to the ethercat ,still struggling to use linuxcnc make the motor rotate :(
07 May 2024 03:05 #299997 by timaer
And ,when I tried to run the motor in the linuxcnc pannel ,it return the msg "关节0跟随错误" I dont know what does it exactly mean either :(
07 May 2024 03:50 #299998 by onceloved
Are you Chinese
07 May 2024 05:52 #300002 by timaer
Yes, I'm Chinese.I'm developing a machine with linuxcnc
07 May 2024 10:33 #300026 by onceloved
加我v或者QQ 我远程给你弄 304394405
10 May 2024 05:56 #300293 by timaer
非常感谢!
Time to create page: 0.462 seconds
