- Thank you received: 410
Syste is debian 10 buster x86_64
Kernel: 4.19.0-27-rt-amd64 #1 SMP PREEEMPT RT Debian 4.19.316-1 (2024-06-25) x86_64 GNU/Linux
Ethercat : IgH ETHERCAT master 1.5.2 unknow
Etherlabmaster-1.5.2+20190904hg33b922p8ea394
LINUXCNC 2.9.0-pre0
When axis opens the gui, the axis dimensions are already present. From tests done, when I had the same problem with debian 12, as soon as it reads the loadrt lcec command, the dimensions appear on the pins in hal, relating to the individual axes.
gitlab.com/grandixximo/ethercat/-/jobs/1...ad?file_type=archiveI have installed linuxcnc-ethercat...0.9.5-retro1.5.2-rc1, without error, but if coomand ethercat version have reult 1.6.9
But I think, this is not the Igh part, but the lcec driver, right?
I have a version running in place in another directory, do I need to copy or link something to test?
On Debian 10 , in direcory bin the linuxcnc , i have only lcec_conf and not have lcec_coffingen
