Ethercat random jitter fix
6 months 2 weeks ago - 6 months 2 weeks ago #345496 by papagno-source
What parameters should I check?
the name the pin
Last edit: 6 months 2 weeks ago by papagno-source.
The following user(s) said Thank You: grandixximo
6 months 2 weeks ago - 6 months 2 weeks ago #345497 by grandixximo
Sorry, not a pin
it is the output to the terminal when you send this command
ethercat master
in a terminal window
it will list various things, I am interested in DC reference, and APP time, they are near the end
ethercat master command outputs
Master0
Phase: Operation
Active: yes
Slaves: 20
Ethernet devices:
Main: 00:e0:b4:68:34:0a (attached)
Distributed clocks:
Reference clock: Slave 0
DC reference time: 829391683702736097
Application time: 829391693979787340
the above is what I'd like to see, thank you
Last edit: 6 months 2 weeks ago by grandixximo.
6 months 2 weeks ago - 6 months 2 weeks ago #345498 by grandixximo
I have commit a small change to enable you to set drive 1 as the reference clock please update the code from
github.com/grandixximo/linuxcnc-ethercat
and run with this xml
File Name: deb13_2026...13-2.xml
File Size:17.35 KB
and confirm that DC reference clock is slave 1 and not 0 by running
ethercat master
in a terminal, I expect
Reference clock: Slave 1
6 months 2 weeks ago #345500 by papagno-source
I don't understand how can attachment file.
This test, are without your last fix.
I have executed N°3 test for refClockSyncCycles="1" and refClockSyncCycles="-1"
1° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Main: 68:ed:a4:79:15:bb (attached)
Link: UP
Tx frames: 105648
Tx bytes: 22401382
Rx frames: 105647
Rx bytes: 22401017
Tx errors: 0
Tx frame rate [1/s]: 1053 1050 752
Tx rate [KByte/s]: 360.7 359.5 216.8
Rx frame rate [1/s]: 1053 1050 752
Rx rate [KByte/s]: 360.7 359.5 216.8
Common:
Tx frames: 105648
Tx bytes: 22401382
Rx frames: 105647
Rx bytes: 22401017
Lost frames: 0
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
DC reference time: 829434877492390059
Application time: 829434927369399203
2026-04-13 22:35:27.369399203
2° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 201920
Tx bytes: 55838998
Rx frames: 201919
Rx bytes: 55838617
Tx errors: 0
Tx frame rate [1/s]: 1055 732 844
Tx rate [KByte/s]: 376.3 246.9 277.6
Rx frame rate [1/s]: 1055 732 844
Rx rate [KByte/s]: 376.3 246.9 277.6
Common:
Tx frames: 201920
Tx bytes: 55838998
Rx frames: 201919
Rx bytes: 55838617
Lost frames: 0
Loss rate [1/s]: 0 -0 0
Frame loss [%]: 0.0 -0.0 0.0
Distributed clocks:
DC reference time: 829435021988989029
Application time: 829435029703007959
2026-04-13 22:37:09.703007959
3° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 335803
Tx bytes: 102363460
Rx frames: 335802
Rx bytes: 102363095
Tx errors: 0
Tx frame rate [1/s]: 1062 800 845
Tx rate [KByte/s]: 375.7 272.1 283.3
Rx frame rate [1/s]: 1062 800 845
Rx rate [KByte/s]: 375.7 272.1 283.3
Common:
Tx frames: 335803
Tx bytes: 102363460
Rx frames: 335802
Rx bytes: 102363095
Lost frames: 0
Distributed clocks:
DC reference time: 829435160651165030
Application time: 829435171294192841
2026-04-13 22:39:31.294192841
1° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 394894
Tx bytes: 122081343
Rx frames: 394893
Rx bytes: 122080980
Tx errors: 0
Tx frame rate [1/s]: 1056 1001 811
Tx rate [KByte/s]: 345.4 327.0 265.2
Rx frame rate [1/s]: 1056 1001 811
Rx rate [KByte/s]: 345.4 327.0 265.2
Common:
Tx frames: 394894
Tx bytes: 122081343
Rx frames: 394893
Rx bytes: 122080980
Lost frames: 0
Distributed clocks:
DC reference time: 829435219977025031
Application time: 829435246614056284
2026-04-13 22:40:46.614056284
2° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 466209
Tx bytes: 145310656
Rx frames: 466208
Rx bytes: 145310307
Tx errors: 0
Tx frame rate [1/s]: 1055 865 766
Tx rate [KByte/s]: 345.2 278.2 243.7
Rx frame rate [1/s]: 1056 865 766
Rx rate [KByte/s]: 345.5 278.2 243.7
Common:
Tx frames: 466209
Tx bytes: 145310656
Rx frames: 466208
Rx bytes: 145310307
Lost frames: 0
Loss rate [1/s]: -1 -0 0
Frame loss [%]: -0.1 -0.0 0.0
Distributed clocks:
DC reference time: 829435319890377036
Application time: 829435334302407866
2026-04-13 22:42:14.302407866
3° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
aster0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 555839
Tx bytes: 174885365
Rx frames: 555839
Rx bytes: 174885365
Tx errors: 0
Tx frame rate [1/s]: 1054 901 812
Tx rate [KByte/s]: 345.2 292.8 259.7
Rx frame rate [1/s]: 1054 901 812
Rx rate [KByte/s]: 345.2 292.8 259.7
Common:
Tx frames: 555839
Tx bytes: 174885365
Rx frames: 555839
Rx bytes: 174885365
Lost frames: 0
Distributed clocks:
DC reference time: 829435419653140029
Application time: 829435435462157958
2026-04-13 22:43:55.462157958
6 months 2 weeks ago #345501 by papagno-source
Because dcRefClock="true" only for drive 1 and not for all drive ?
6 months 2 weeks ago - 6 months 2 weeks ago #345502 by grandixximo
Yes, the reference is only one, and right now is 0, and that I/O might not be doing DC properly.
So I'm try to move it to the servo.
The ethercat master, I'm only interested in two values
DC reference time:
Application time:
And three times on the same run, not one time per run. Sorry about not being clear about it. Appreciate it if you could test it, thank you.
Manda il comando tre volte dopo aver iniziato, non una volta per avvio.
Time to create page: 0.081 seconds
