- Thank you received: 410
last time when I was using the syncToRefClock instead of negative cycles there was an error of synchronization ...There is actually a bug in the code when you use both the "-" sign and the syncToRefClock option.
Both will switch on the pll code.
The bug is corrected, so depending on if you have that version or not.
Fix: don't use the "-" sign to switch on/off the pll code. Use only the syncToRefClock option.
