  • RobotMatic
  • RobotMatic's Avatar
01 Dec 2025 15:13
parport observation in outport out-inverter-1 seems not to work
Category: HAL
2.9.7 I can't manage to start a configuration with inverted output ports.
pin 1-14-17 out-inverter-1 seems not to work
I can change state, but I can't start a setup with an inverted state
  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 14:48
Replied by jaro_p on topic User name rpi-first-boot-wizard
Category: Installing LinuxCNC
Unfortunately, in trixie image_2025-11-10-raspios-lcnc-2.9.7-6-trixie-arm64.zip the command mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid doesn't work. No 7c81 board found.
01 Dec 2025 14:14
Replied by tommylight on topic Ich brauche eure Hilfe beim Tausch meines Boards
Category: Deutsch
Attached should be the config for that board.
  • meandreas72
  • meandreas72
01 Dec 2025 13:54
Replied by meandreas72 on topic Button with toggle
Button with toggle
Category: HAL
Danke. Werde ich mal ausprobieren.
Gruß Andreas
  • vibram
  • vibram
01 Dec 2025 13:50
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
understood, thank you.
I will look for tutorials as i'm beginner with this technology
  • Hakan
  • Hakan
01 Dec 2025 13:41
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
Not sure exactly how that works. TIM2 and TIM5 share things, at least encoder pins, so only one encoder.
Maybe there can be TIM2 on one pin and TIM5 on the other for other purposes, not sure.
You can always do some surgery. Prototype in free-run mode and you don't need sync0 and sync1 which are
on TIM2 CH1 and CH2, so you can free them up and use them for encoder input for the 32-bit encoder.
Solder on tiny wires and melting glue. Has happened before.
  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 12:09
Ok Thank you
01 Dec 2025 12:07
Replied by tommylight on topic User name rpi-first-boot-wizard
Normally this is what is needed to read Mesa boards:
mesaflash --device 5i25 --readhmid
but for SPI i would guess
should work, and it should be safe to try.
If you do have more questions about Mesa boards, use the "driver boards" section of the forum.
  • unknown
  • unknown
01 Dec 2025 12:07
Replied by unknown on topic User name rpi-first-boot-wizard
After looking at the arm64 Trixie repo it appears there are no packages available for mesaflash.
One option would to be build from source.
Or to manually download the bookworm version and install that.
As it is almost 12:00 am I fear I may not be able to respond in a timely manner.
  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 12:01
With Imager version 1.9 it's ok.
Can I also ask what is the replacement for mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --fallback --write.
I found:
halrun
halcmd: loadrt hostmot2
halcmd: loadrt hm2_rpspi
for reading (readhmid).
Or should I ask in a new forum?
  • timo
  • timo
01 Dec 2025 11:53
Replied by timo on topic Probleme beim Bohrfräsen
Category: Fusion 360
Ich verstehe nicht. Wenn der Nullpunkt bei beiden Setups auf der selben Position ist, dann "müsste aber" :-) alles normal funktionieren. Wenn der Nullpunkt für G54 für beide setups unterschiedlich ist (meine Beispielbilder oben) dann wäre es ja richtig, wenn die Maschine falsch fährt.
Ist hier bei dem "operations" tab was verstellt?
  • abs32
  • abs32
01 Dec 2025 11:49
Replied by abs32 on topic Issue with G38.5
Issue with G38.5
Verified - adding the code M66 P0 L0 around all G38 did not eliminate the error. 2.9.7
  • jaro_p
  • jaro_p's Avatar
01 Dec 2025 11:40
So after booting without a password it is also not possible to change anything. But I will try an older version of Imager. Otherwise it offers an update to the new version quite aggressively.
  • unknown
  • unknown
01 Dec 2025 11:25
As I said it can also be set via the first book wizard, but I'm at a loss as why RPi image doesn't allow you to set the customisations, all the while I have been building the various version that has never happened, I had to download the latest version on my Debian Dev machine.
  • unknown
  • unknown
01 Dec 2025 11:21
Replied by unknown on topic Is the wiki down?
Is the wiki down?
http is fine
https does not appear to work
Well from my location on an island somewhere near the Indian Ocean/South Pacific Ocean.
Displaying 10411 - 10425 out of 11519 results.
Time to create page: 0.991 seconds
