  • abs32
  • abs32
  • andypugh
  • andypugh's Avatar
  • abs32
  • abs32
30 Nov 2025 17:56
Replied by abs32 on topic Issue with G38.5
Issue with G38.5
If you insert M66 P0 L0 between the probe moves then the queue might be cleared as a side effect.
Great news, thanks for the idea. I'll check it out tomorrow with version 2.9.7 and let you know the results.
  • andypugh
  • andypugh's Avatar
30 Nov 2025 17:55
Replied by andypugh on topic stepgen maxvel too big and SRO problem
Category: Gmoccapy
The GUI's don't always "know" that you have changed an override.
Which GUI are you using? And how are you overriding (ie, which HAL pins are the counts going to?)
  • andypugh
  • andypugh's Avatar
30 Nov 2025 17:20
Replied by andypugh on topic The Current Bread & Butter Setup?
For reproducible hardware the Pi5 is probably a good choice. It's not the absolute best of platforms, but it is a known quantity and that would be useful if you are making multiples of the system.
  • Billy Boy
  • Billy Boy
30 Nov 2025 17:13
The Current Bread & Butter Setup? was created by Billy Boy
I'm looking for suggestions for a simple bread & butter Linux CNC install.
It seems like an Raspberry Pi 5 + Mesa 7i96S might be the current standard, but it's not super clear? A while back it seemed like the Beaglebone was a good option, but it seems things have not gone that way?
Background...
I've built/retrofitted a number of machines with Linux CNC, but not for perhaps 10 years.  I've done a lot of machining and I'm fully competent with Linux.
I've got a new project that wants to integrate 2 Sherline CNC chucker lathes with some additional widgets.  Each lathe would get its own LinuxCNC hardware & software and the integration would be via ssh/linux command line.
If I can get the system working well, I might get orders for 10 or 50 of these systems over the next few years, so I would really like to use a stable, easy to get, standardized off-the-shelf parts, that can be expected to remain available for the next 5 years. I'm *not* looking to cobble something together out of 10 year old PCs, and I'd prefer not to build on some wierd/cheapo/legacy PC off Amazon which may go away in 3 months.
I'm looking for a simple reliable bread & butter LinuxCNC platform.
Suggestions?
BB
  • andypugh
  • andypugh's Avatar
30 Nov 2025 17:11
Replied by andypugh on topic Issue with G38.5
Issue with G38.5
I am quite proficient with build-install-clone commands and have the ability to simultaneously have and use all the versions
I realised that several posts later, and could have saved myself a great deal of typing.
It is unable to work due to this, forum.linuxcnc.org/38-general-linuxcnc-q...bing?start=10#338958, bug[/b][/b][/b]
I will try to look into this, probably with a simulated probe input for simplicity.
Have you tried inserting an explicit queue-buster between the successive probe moves? (I almost feel that we should have a specific code for that, maybe related to M70)
Doing some offline research about this I found wiki.linuxcnc.org/cgi-bin/wiki.pl?QueuebustersRevisited which whilst not immediately relevant does discuss some of the issues around the motion queue.
  • Hakan
  • Hakan
30 Nov 2025 17:10
  • RotarySMP
  • RotarySMP's Avatar
30 Nov 2025 17:02
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
Hi Unlogic,
I took a look at using your code, but I have the opposite problem. Your spindle stops abruptly with max braking with the enable pin deactivated, but mine just disconnects the power section and lets it coast down.
  • gravedigger
  • gravedigger
30 Nov 2025 16:55
Replied by gravedigger on topic stepgen maxvel too big and SRO problem
Category: Gmoccapy
I don't actually need the rapid overlay. If I could operate rapid and normal feed with the same encoder, that would also be OK.
  • andypugh
  • andypugh's Avatar
30 Nov 2025 16:54
Replied by andypugh on topic Locations of LinuxCNC
Category: Installing LinuxCNC
Released debs (ie officially released 2.9 versions) are also now available from Github.
github.com/LinuxCNC/linuxcnc/releases
This covers Trixie and Sid and has both AMD64 and ARM64 packages.
It is not yet clear whether the buildbots will continue in the future, but at the moment they are how the docs get to the website.
  • gravedigger
  • gravedigger
30 Nov 2025 16:52
Category: Gmoccapy
The encoder works on the spindle and for normal feed rates. However, if I switch the input in the Mesa software to rapid feed rate overlay, the bar does not move with the same encoder as for normal feed rates and the same wiring.
  • Ul
  • Ul
30 Nov 2025 16:04 - 30 Nov 2025 16:16
Ich brauche eure Hilfe beim Tausch meines Boards
Category: Deutsch
Das ist nicht das Problem. Das Problem ist, dass es gar nicht angeschlossen und ausprobiert hast.
In Mach3 werden physische Pins des Parallelports angegeben. Wenn die Belegung nicht stimmt, ist es entweeder der falsche Motor (falsche Achse bewegt sich), er läuft in die falsche Richtung oder er macht bei Richtungswechsel nur einen Schritt (Takt und Richtung vertauscht).
Nachdem du den Strom über die DIP-Schalter eingestellt hast, schließt du die Motoren und die Spannungsversorgung über die Schraubklemmen an die Karte an (und trennst die auch nicht unter Spannung) und verbindest die Karte mit dem Parallelport. Dann testest du ob es läuft. Die Wahrsagerei ob die Pinbelegung richtig oder falsch ist oder Beschwerden über richtige und nicht richtige / unpassende Datenblätter aus dem Internet bringen hier keinem was.
Auch kann hier im Forum niemand wissen was "die alte Karte" ist, daher macht diese Referenz keinen Sinn. Was soll dieses "sowas", auf das du dich beziehst, sein und wie soll jemand wissen was es ist, ohne dass du es vorher geschrieben hast? Die ist aber sowieso nicht relevant, da deine Endstufe einfach an den Parallelport angeschlossen wird.
  • Masiwood123
  • Masiwood123's Avatar
30 Nov 2025 15:59
Replied by Masiwood123 on topic Physical buttons to 7i96s+7i77
Category: HAL
I tried with this example, but it gives me an error at the start, or scale.1. gain not found or when I comment on it analogin0 not found, in the example I replaced the pins on hm2_7i96s.0.7i77.0.0.analogin** they exist as you can see in the photos
  • my1987toyota
  • my1987toyota's Avatar
30 Nov 2025 15:44
Replied by my1987toyota on topic 3D printed stuff, showcase it here
Category: Additive Manufacturing
Came across this video today. I wonder how many people still think 3D printers are still just a toy? Admittedly before I got one
I used to think so myself.
Displaying 10471 - 10485 out of 11519 results.
Time to create page: 0.380 seconds
