  • Hakan
  • Hakan
27 Nov 2025 06:41 - 27 Nov 2025 08:47
Ethercat drives not responding, mesa error finishing read
Category: EtherCAT
Do you see pll-reset-count increasing?
What's the exact error message you get? I can search the code to see what's going on.
You can always try "ethercat rescan", sometimes it clears errors.
e-stop on when you do this.
Edit: I guess it is PLL error 0x32 error message you get.
Check for other messages in syslog, like missed datagrams.
Improved network latency is the answwer in that case.
Also the pll-reset-count as mentioned above.
  • rodw
  • rodw's Avatar
27 Nov 2025 06:32
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
So the plasma_gcode_preprocessor which comes with Monokrom works for you? I still had no success.
I used sheetcam with the plasmac post processor and let monokrom's filter do the hole processing.
27 Nov 2025 06:26
Replied by tommylight on topic Funny message when reply to a topic
Category: Forum Questions
We are getting battered by spam, today and yesterday i spent from 5:30AM to 7:20AM deleting and banning at a staggering rate, so we are way over our e-mail sending quota, hence the messages.
I did activate a small barrier, so should subside quickly.
Thank you.
  • Z3n
  • Z3n
27 Nov 2025 06:12
Replied by Z3n on topic Funny message when reply to a topic
Saw this happen recently as well, both when I started a new thread here:
forum.linuxcnc.org/27-driver-boards/5795...done-lights-on-7i92m
And when I updated my thread here:
forum.linuxcnc.org/12-milling/57928-conv...5-to-linuxcnc#339302
Screenshots attached,  hopefully this helps with troubleshooting!
  • Z3n
  • Z3n
27 Nov 2025 06:08
Replied by Z3n on topic Converting a Brother TC215 to LinuxCNC
Category: Milling Machines
Well, some good news and some bad news. I did get all the servos moving and confirmed all the controllers work via USB connection and the DMM software (hooray!). I also got the latest versions of mesaflash, MesaCT, and got things mostly figured out for the estop configuration in linux CNC.
Unfortunately - I also discovered that my Anything IO board appears to be bricked, so that throws a wrench in making progress for a bit. Started a thread in the appropriate section on that here: forum.linuxcnc.org/27-driver-boards/5795...done-lights-on-7i92m
Two steps forward, discover you're one step back, so it goes!
  • Z3n
  • Z3n
27 Nov 2025 06:03
Red Init & Done Lights on 7i92M was created by Z3n
Category: Driver Boards
I'm midway through converting a Brother TC215 to LinuxCNC control (I started a thread here: forum.linuxcnc.org/12-milling/57928-conv...er-tc215-to-linuxcnc ), and I've been learning a lot / things have been going well, but I've gotten to the point where I wanted to test the MESA cards in the mill and I've discovered that when I power up the MESA 7I92M board, the Init and Done lights stay red. It won't respond to ping, and doesn't show a link light via ethernet on either side of the cable.
I saw a post from PCW ( forum.linuxcnc.org/27-driver-boards/4431...-7i96-flashing-error ) that says the Init and Done lights staying illuminated indicate corrupted flash memory. If this is the case, I'm assuming the best option is to get in touch with MESA and see about having them reflash it? Any guidance welcome.
Also, I've got a 7I76 and a 7I77D in the mill, and now I'm concerned that if there's an issue with the 7I92M that there's a problem with those boards as well. If I power those with 5v via the appropriate terminals / jumper settings, will I be able to verify if they work via looking at the lights on the boards?
Thanks for any help / guidance, it's really amazing to have this forum as a resource!
  • Dudelbert
  • Dudelbert
27 Nov 2025 05:44
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Yeah, you’re probably right, and I’m leaning toward LinuxCNC anyway.
  • smc.collins
  • smc.collins
27 Nov 2025 05:08
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
Category: Turning
Personally, I'd just buy a servo and rip oit all the crap on the spindle, you can get a 5kw spindle and drive on Alibaba for $400 shipped or less. That'll give you what you're after for a lot less hassle. Pull out the pulley system and all and just direct drive. Get a 5000rpm servo that should give you way more cut powe than you have.
  • nanowhat
  • nanowhat
27 Nov 2025 02:27
Category: EtherCAT
The PLL fault doesn't freeze or kill the process: one drive will stop responding to cyclic position commands. The only reset function I've built into my code so far toggles cia402.x.enable and cia402.x.fault-reset, and that doesn't seem to be enough to reestablish communication with the drive.
  • drdyna
  • drdyna
27 Nov 2025 01:56
Incremental Axes U, V, W support? was created by drdyna
Hi
I'd like to use LinuxCNC to simulate some lathe g-code before I run it on my actual machine.
I have linuxCNC installed, and have the gmoccapy lathe simulations installed, but when I try to run my g-code, I get an error about "invalid character U". My physical machine has incremental axes U and W that correspond to X and Z. U and W are incremental moves, and X and Z are absolute moves. So if you're at X1.0 and you move U3.0, you'd end up at absolute X4.0, or if you're at X1.0 and move U-3.0 you'd end up at X-2.0
Does linuxCNC support incremental axes like U and W? Do I need to set them up somehow in the simulation machine's HAL file?
  • qiwating
  • qiwating
27 Nov 2025 01:45
Replied by qiwating on topic Fanuc encoders
Fanuc encoders
for Fanuc Encoders you can check here panasonicservomotor.com/fanuc-encoder. include code Fanuc code list
  • jmelson
  • jmelson
27 Nov 2025 00:47 - 27 Nov 2025 00:48
Replied by jmelson on topic LinuxCNC Hardware Survey
A google search for servo-to-go comes up pointing to alvarestech.com, that brings up the original servo-to-go main page from 20 years ago. I was real surprised to see that pop up! But, they have been out of the business since about that time. I can imagine there might be some hermit still running an STG card somewhere, but that's a stretch.  (I sold mine 20 years ago!)
Jon
  • andypugh
  • andypugh's Avatar
27 Nov 2025 00:30
Unexpected EtherCAT was created by andypugh
Unexpected EtherCAT
I was trying to find out if the Vital Systems Motenc card is still a current product, and it seems that it is (it's been supported by LinuxCNC since 2005)
But on their web site I found that they also have EtherCAT hardware.
www.vitalsystem.com/motion/ethercat/ECS1.php
  • andypugh
  • andypugh's Avatar
26 Nov 2025 22:58
Replied by andypugh on topic LinuxCNC Hardware Survey
Servo2Go seems to still exist, but I don't see anything like the original Servo2Go ISA bus interface card on their web page
I am not sure if servo2go is the same as servotogo.
The servotogo.com address now seems to redirect to an Indonesian lottery site.
  • Hakan
  • Hakan
26 Nov 2025 22:51
Category: EtherCAT
PLL was documented not long ago. Wasn't aware it can stop linuxcnc, that's a bit excessive.
github.com/linuxcnc-ethercat/linuxcnc-et...istributed-clocks.md
Displaying 10636 - 10650 out of 11519 results.
Time to create page: 4.330 seconds
