  • scsmith1451
  • scsmith1451's Avatar
24 Nov 2025 17:21
Configuring dual Y Axis drivers was created by scsmith1451
I'm in the process of upgrading my DIY router mill to include dual Y axis steppers. The current configuration uses a single Y stepper to move a rather long axis (~ 44 in) on which the X axis rides to provide X/Y motion for cutting.  However, on long, fast moves I sometime notice slight cogging.
I have an extra stepper and Microstepper that matches the current Y Stepper-Microstepper combination that I would like to incorporate to minimize cogging.
The machine uses a MESA 7i76u 5 axis control board. My question is, will the MESA 7i76u provide sufficient direction and step current to drive two Microstepper drives so that both get their signals at the exact same time? Or, do I need to configure separate sections of my HAL and configuration files to drive each driver separately and if so, how would I go about the configuration?
I did find an old post on the subject of two steppers for an axis, but it was for a rather old version of LCNC.  I guessing that 2.9.4 may have a more straight forward approach to configure dual axis drives.
Kind regards,
  • kwanlokto
  • kwanlokto
24 Nov 2025 16:57
Replied by kwanlokto on topic LinuxCNC homing twice in Axis SImulation
Category: AXIS
Thanks for your reply tommylight. Sorry if this sounds stupid but I selected each axis (X, Y, Z) and click the +/- buttons to move it in that direction, but it still doesn't seem like Home All works. It only seems to home the y axis (so j = 1).
Im still getting errors for j = 0 and j = 2
24 Nov 2025 16:46
Replied by tommylight on topic LinuxCNC homing twice in Axis SImulation
Category: AXIS
Simulated switches so you have to move all axis to be able to home again.
  • Murphy
  • Murphy
24 Nov 2025 16:37
I think I might of taken a pic of mine but no originally it was rbobey1989
  • kwanlokto
  • kwanlokto
24 Nov 2025 16:16
LinuxCNC homing twice in Axis SImulation was created by kwanlokto
Category: AXIS
I'm having trouble understanding why my "axis" simulation is getting "Cannot home while shared home switch is closed". This happens once I click "Home All" twice. I'm wondering if I have something setup incorrectly.
My end goal is to be able to do this via python. I have attached my current python code (which I don't think is the issue) and I get the same issue.
  • RotarySMP
  • RotarySMP's Avatar
24 Nov 2025 15:33 - 24 Nov 2025 16:20
Replied by RotarySMP on topic Maho 500 W4 Retrofit
Erledigt.
  • T_D
  • T_D
24 Nov 2025 15:07
Replied by T_D on topic Maho 500 W4 Retrofit
Ich kann das leider über den link irgendwie nicht finden wie ich dich kontaktieren kann bzw ist die mail rinfach nur @rotarysmp ?
  • RotarySMP
24 Nov 2025 14:29
Servus Tom,
Es gibt kein DM funktion hier im Forum. Auf meine YT channel gibt es meine Email adresse.
www.youtube.com/@RotarySMP
Ich kann dir meine Retrofit Notizen zukommenlassen.
Bei meine 400E waren 2 Kannalle der Exe Karte hin. Ich habe 2x 602D EXE's eingesetzt. Die haben zwei vorteilen.
- Brauchen lediglich 5VDC. Der Original 3x Kanal EXE braucht 5VDC und 12VDC.
- Differential Signal, statt bei der 3x Kanal lediglich Single. Obwohl Heindhains Kabel und Schirmung ist so Hochwertig dass es wahrscheinlich wenig unterschied macht.
Mann muss nur aufpassen,. Machen 602D sind 1µm, andere 5µm output. Heindenhains Modelnummerierung sind nicht sehr durchschaubar. Ich glaube 610 EXE sind Resolution auswahlbar.
Ich haben auf meine Schaublin eine etwas erweiterte Bedienpult mit Tastatur, buttons, encoders etc gemacht. Alles ist an der 7i73 angeschlossen, ausgenommen Tastatur (USB) und E-Stop (Hard wired).
MESA 7i97 für die Achsen, Encoders und Spindel Servo
Mesa 7184 I/O
Mesa 7i73 Bedienpult.
Tom's handwheel (Pendant.)
talla83.de/Tshw.html (Peter's website.) Die ZIP file für die Boards kann mann selbe an  JLCPCB herstellen lassen. Sonst Frag Peter ob er einen fertigen Verkauft.
lg,
Mark
  • Hakan
  • Hakan
24 Nov 2025 13:24 - 24 Nov 2025 13:52
Replied by Hakan on topic an CIA402 Stepper/Servo as Spindle
Category: EtherCAT
Yes, that's what I have in the example.
It might work with the cia402pv instead of the standard cia402 also in csp mode.
But I'm not sure, the goal with that component was to add PV, and I may have
broken csp. Not that I meant to, but I didn't check thoroughly.
Also the pv-mode=true and csp-mode=true doesn't work well together,
there should really be a new logic like op-mode=3 (for csp-mode)
  • RotarySMP
24 Nov 2025 12:25
In this case no Tommy. The original poster is also Tom.
" manche Sachen kann man dort übertragen aber gerade das mit diesen Signalen bzw. von Haidenhain Glasmessstäben zu denen die die Mesa versteht ist für mich Neuland . gruß Tom"
  • T_D
  • T_D
24 Nov 2025 12:21
I bougt the maho without the computer but i have read that the haidenhain exe 610 should work for the ls 403 linear glass scales
  • T_D
  • T_D
24 Nov 2025 12:19
Die maho ist die version mit dem 2 stufen getriebe bzw 2 gänge +neutal stufe und dem servo der über einen indramat tkr 6 angesteuert wird . Mein gedanke war erstmal vom ablauf her zu entscheiden welches gui und bedenfeld ich nutzen möchte dann die auswahl der mesa karten zu treffen und dann das ganze zu verdrahten , an und für sich denke ich mal das der weg ja garnicht so schlecht ist aber das bedienfeld zu planen bzw praxisnah zu planen und zu bauen ist ja auch eine schöne winterarbeit , wie bekomme ich das hin dass ich das bedienfeld nutzen kann und dann das handrad zuschalten kann bzw wie ist das mit diesen talla boards wo bekomme ich die ? Ich würde das gerne so machen wie du in dem video aber das layout des bedienfeldes noch um eine industrietastatur und knöpfe erweitern ähnlich wie bei dem originalen also nc start ,achsen verfahren ,kss pumpe an etc , brauche ich dafür extra eine mesa rte für das bedienfeld und wenn ja welche ? Gruß tom
  • RotarySMP
24 Nov 2025 11:52
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
Thanks for taking a swing at that. One thing we can all agree on is that the manual is dogshit :)
Feeding dogshit into AI seems to result in a similar result as when I used to mow over the dried up dog turds on the lawn when I was a kid. :)
This is an old 8214. Specifically EVF81214-E
The VFD doesn't have a built in brake chopper. There are two options, either a "Brake module" with an integrated resister, or a "Brake chopper" which feeds an external resister.
I first bought the external resister due to lack of understanding / research.
.. .before I worked out it does not connect directly to the VFD.
Then I bought the "Brake module" EMB 8252-E, which connects to the UG+ and UG - pins.
adegis.com/media/asset/6e4b8a95789dbed2a...ed149b4af51f912d.pdf
They are connected correctly.
However, that is not the issue. If you look in that video I linked a couple of message further above, at that point in the video, you can see the VFD oscillating back and forth into overcurrent as it tries to brake the spindle motor, without any form of resister added.
Back then, I somehow found out how to set the VFD into a coast down mode.  That must have happed just after I made that video.
When I  hit the spindle stop, the VFD switches straight to "off", and current drops to zero, no attempt at decelleration, no over current. That is how I operated it for the last couple of years.
Before I even connected the brake module, I tried to return the VFD from "coast down" mode to normal brake (which would mean overcurrent without the brake module installed), and failed.
I can see two explanations.
1/ I was informed of, or stumbled onto a parameter setting, or combination of them to set the VFD to coast down. So it no longer follows the C13 deceleration setting, it just disconnects from the motor, and leaves it to coast down. Now I can't find that setting, nor remember what I did.
2/ I blew something in that VFD which was responsible for decelleration current. But there are no other symtoms of anything blown in this drive. It works perfectly, and gives no errors.
Cheers,
Mark
  • Red_D85
  • Red_D85
24 Nov 2025 11:48
Replied by Red_D85 on topic an CIA402 Stepper/Servo as Spindle
Category: EtherCAT
Hello Hakan
can i had 2 instances Cia402
Cia402dBraun for xyz and cia402pv for spindle? did you know that?
Displaying 10711 - 10725 out of 11518 results.
Time to create page: 0.367 seconds
