  • Ul
  • Ul
24 Nov 2025 10:40
Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Teste mal sowas hier: de.aliexpress.com/item/1005009918532948.html
Wäre interessant zu wissen, ob sowas plug & play ist, oder ob man Firmware o.Ä. braucht.
Bei dem Preis lohnt es sich jedenfalls nicht Arbeit und Zeit in ESP32 zu investieren.
  • BoMadsen
  • BoMadsen
24 Nov 2025 09:39
Replied by BoMadsen on topic 7i76eu steppers don't move
Category: Driver Boards
Hmmm, the plot thickens. If I run the qtdragon interface,as in the config file I have uploaded, I get the following error. But if I switch the UI to axis in the ini file, no other change, it works...any ideas how that can be?
  • vpomerleau
  • vpomerleau
24 Nov 2025 09:38
Replied by vpomerleau on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Murphy
No but I will start my lathe project as soon as the mill is done. Was it you that posted a picture of the octocoupler bypass, I wanna try rigid tapping with the mill but I can't find the picture of the board modification.
  • Hakan
  • Hakan
24 Nov 2025 09:32
EtherCAT + CiA402 Servo: OP state reached, but axis won’t move (only Following E
The stat-zero-speed comes directly from the drive, 12th bit of the statusword.
No other processing is done. It seems there is some tolerance for zero.
Maybe your drive has some tolerance setting for this, mine didn't.
If the position is drifting in one direction I think you can check actual-velocity in hal
and switch modes when actual-velocity == 0.
Might combine this with oneshot component, so when actual-speed == 0,
you start oneshot to wait say 0.5 second before switching modes.
All done in hal at least when prototyping.
  • Hakan
  • Hakan
24 Nov 2025 08:42
QtPlasmaC make the top row slightly taller?
Category: Plasmac
Thanks. Awesome. 6 pixels was all that was needed
  • Edi_48
  • Edi_48
24 Nov 2025 08:36
Rack ATC was created by Edi_48
Rack ATC
Category: QtPyVCP
Hello
I have a question. Which *.ngc files and variable entries do I need if I want to use a Rack ATC with LinuxCNC 2.9.7 and a Mesa 7i76e?
Regards,
Hilton
  • abs32
  • abs32
24 Nov 2025 07:59 - 24 Nov 2025 08:03
Replied by abs32 on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
Colleagues, I installed kernel 5.4.258-rtai-amd64 + LinuxCNC 2.9.4 (kernel 290 too). In all cases, the AXIS interface is launched only when you specify additional kernel options such as isolcpus=1 (I have two cores), etc. But it starts and shows good jitter.
However, the actual work does not last long, but is interrupted due to a constantly appearing error -
joint 1 following error(motor number may change).
Is this treatable?
  • meister
  • meister
24 Nov 2025 07:57
Replied by meister on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
bin gerade am testen von smartserial auf esp32 und raspberry-pico, so als günstige IO erweiterung.
  • Gartenzwerg
  • Gartenzwerg
24 Nov 2025 07:36
Replied by Gartenzwerg on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Ich hab die 7i92 auch schon bekommen, aber werde wohl erst in den Weihnachtsferien dazu kommen.
Dass kein Adapter auf den DB25 Port dabei ist habe ich zu spät mitbekommen, den muss ich mir noch besorgen.
Im der Krabbelkiste findet sich leider kein Flachbandkabel mit passendem Stecker..
  • melayate
  • melayate
24 Nov 2025 07:24
QtDragon M6 Remap Tool Measurement - Inconsistent/Wrong Offsets with VersaProbe
Category: Qtvcp
I’m setting up automatic tool measurement on a 6-axis CNC mill using QtDragon with VersaProbe and running into calculation errors. The M6 remap executes successfully but produces incorrect/inconsistent tool offsets.
Machine Configuration:
    •    LinuxCNC 2.9.7
    •    GUI: QtDragon 1.4
    •    Interface: Mesa 7i96s Ethernet
    •    Axes: 6-axis (dual X gantry: X1, X2, Y, Z, A, B rotary)
    •    Tool change: Manual (no ATC)
    •    Fixed tool setter at machine coordinates X=397, Y=680, Z=-100mm
    •    Touch plate height: 41.54mm
    •    Actual physical tool length difference: ~22mm
What Works:
✓ M6 remap executes without hanging
✓ Machine moves to tool setter position correctly
✓ Probe successfully touches tool setter
✓ Returns to safe position
✓ tool-prepare-loopback HAL connection working
The Problem:
Tool offsets in the tool table are completely wrong and inconsistent:
Test Run 1:
    •    Tool 1: -29.113mm
    •    Tool 2: -7.077mm
    •    Difference: 22mm ✓ (correct!)
Test Run 2 (same tools, same setup):
    •    Tool 1: 0.070mm
    •    Tool 2: -22.105mm
The relative difference is consistently correct (22mm), but the absolute values shift by 30-50mm between runs. Sometimes offsets are even positive when they should be negative.
My Workflow:
    1.    Home all axes
    2.    Clear all tool offsets (set Z to 0.0)
    3.    Jog tool to table surface, run G10 L20 P1 Z0 (set G54 Z=0)
    4.    Run T1 M6 - measures Tool 1
    5.    Run T2 M6 - measures Tool 2
    6.    Check tool table - offsets are wrongQuestions:
    1.    Should I be using G10 L1 (absolute) or G10 L10 (relative) for tool offset?
    2.    Is capturing #5420 before switching to G91 the correct way to get machine Z position?
    3.    After probing in G91 mode, is #5063 the incremental distance traveled, or does it contain machine coordinates?
    4.    Should the calculation be:
    •    probe_machine_z - probe_height (current), or
    •    tool_setter_Z - probe_machine_z + probe_height, or
    •    Something else entirely?
    1.    I’ve read that some people use Tool 99 as a reference probe - is that required, or should direct tool measurement work?
Related threads I’ve studied:
    •    forum.linuxcnc.org/40-subroutines-and-ngcgui/52490-remap-m6-tool-setter
    •    forum.linuxcnc.org/qtvcp/51138-qtdragonhd-tool-sensor-help-for-a-maker-space
Any help would be greatly appreciated! I can provide additional config files or testing results if needed.
5_axis.ini (VersaProbe section):
[VERSA_TOOLSETTER]
X = 397.000
Y = 680.000
Z = -100
Z_MAX_CLEAR = -50
MAXPROBE = 80
custom_postgui.hal:
net probe-in => qtdragon.led-probe
net tool-change      iocontrol.0.tool-change       => hal_manualtoolchange.change
net tool-changed     iocontrol.0.tool-changed      <= hal_manualtoolchange.changed
net tool-prep-number iocontrol.0.tool-prep-number  => hal_manualtoolchange.number
net tool-prepare-loopback   iocontrol.0.tool-prepare  =>  iocontrol.0.tool-prepared
qt_auto_probe_tool.ngc (key sections):
# Line 54: Clear offset before measurement
G10 L1 P#<tool> Z0
# Lines 56-57: Move to tool setter
G53 G0 X[#<_ini[VERSA_TOOLSETTER]X>] Y[#<_ini[VERSA_TOOLSETTER]Y>]
G53 G0 Z[#<_ini[VERSA_TOOLSETTER]Z>]
# Line 61: Capture starting Z (attempted fix)
#<start_machine_z> = #5420
# Line 63: Switch to incremental mode
G91
# Lines 64-71: First probe (fast)
G38.3 Z- #<_ini[VERSA_TOOLSETTER]MAXPROBE>
G0 Z #<_hal[qtversaprobe.backoffdist]>
# Lines 75-78: Second probe (slow)
G38.3 Z- [#<_hal[qtversaprobe.backoffdist]> *1.2]
# Lines 79-80: Calculate machine Z position
#<probe_distance> = #5063
#<probe_machine_z> = [#<start_machine_z> + #<probe_distance>]
# Line 82: Return to absolute mode
G90
# Line 88: Set tool offset (THIS IS WHERE THE PROBLEM IS)
G10 L1 P#<tool> Z[#<probe_machine_z> - #<_hal[qtversaprobe.probeheight]> + #<_hal[qtversaprobe.blockheight]>]
  • unknown
  • unknown
24 Nov 2025 07:09
Replied by unknown on topic wifi adapters
wifi adapters
Thanks for the info, nice to see a Vendor have some proper support for Linux.
  • Sekai
  • Sekai
24 Nov 2025 05:44 - 24 Nov 2025 18:14
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
This is mini pc fujistu Q920
i disable about everything in the bios.
Still nothing
This is my current boot parameters with grub.
sudo chrt 99 ping -i .001 -q 10.10.10.10 -c 60000
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60239ms
rtt min/avg/max/mdev = 0.101/0.251/5.325/0.141 ms
Edit: I put linuxcnc on miniatx motherboard with intel i5 4460 and realtek RTL8168 ethernet.
  • unknown
  • unknown
24 Nov 2025 04:27
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Why did windows dominate the market?
The PC clone, which allowed many vendors to get in, sell at competitive prices and with PCs coming pre installed with Windows it was a no brainer. Old self proclaimed Dr\Farmer Gates was pretty aggressive.
TBH it took Linux a while to have a polished Desktop. A lot of misinfo about having to be a programmer to use Linux, mostly coming from a half generation that weren't aware MSDOS was command line only for many years. I think it's only us guys old enough to grow White Whiskers remembers early Linux and would have run it on a 486.
Until the wide spread adoption of the internet any security issues weren't exposed as they would be post internet, yes there were viruses around, but their source was either from physical media or BBS's.
As for Banks, most of the behind the scenes stuff would of been carried by ancient IBM systems, or Unix. My old ma remembers working in banks where one machine would take up a whole room (1970 or there about), living Down Under the aircon was great in summer.
They are quite a few local government locales in Europe & South America that have broke away from Windows.
The whole Third World Infrastructure is probably run by the West's Ewaste running pirated copies of XP, I don't think anyone is desperate enough to run Win2k unless it's a machine that has no connection to the outside world inside a Cold War bunker. Word has it that Win2k could catch the common cold from a user.
Betamax was superior to VHS, but VHS won out. The World's an imperfect place, I'm sure the Open BSD & Net BSD guys laugh at us Linux users. I wont talk to much about the Emacs \ Vi (Vim) flame wars, alot of good people perished.
24 Nov 2025 02:28
Category: Gmoccapy
Might be best to read the github page regarding some sites using warpinator.com domain.
Dang it, i was not aware of that mess, so yeah
DO NOT USE THE WEBSITE warpinator dot com
Use GitHUB
For Linux it is
sudo apt install warpinator
  • Lcvette
  • Lcvette's Avatar
24 Nov 2025 02:20
problems with Y-Axis, elliptic deviations after several changes -Probe Basic V.5
Category: QtPyVCP
Ah, bummer, sorry to hear that, hopefully it's repairable! Keep us posted!
Displaying 10726 - 10740 out of 11518 results.
Time to create page: 0.535 seconds
