  • Quail
  • Quail's Avatar
14 Nov 2025 01:21
M03 Sub Routine File Location was created by Quail
Category: G&M Codes
Currently working on a machine using the QTPlasmaC GUI, and I was wondering if there was any way to access the M03 sub routine file anywhere? I would like to edit it to disable the homing of the Z-axis that it does.
Right now the machine fires the torch using a regular output pin, which works fine when everything is going perfectly, but when a limit is triggered or the E-stop is pressed, it doesn't quite understand that it needs to disable the torch as well.
I was able to almost work around this by messing with the hal file and using an and function to turn off the the torch when the e-stop is pressed, but the problem is when the machine is reset it has a memory of last being told to turn on, and so the torch fires.
My thinking is that if I can go in and mess with the M03 instructions I can just completely disable the Z-homing because all of this has been a work around for that, because my machine has no z-axis.
Thanks!
  • unknown
  • unknown
14 Nov 2025 01:18
Replied by unknown on topic Why is there no BSDCNC?
By what metric have you been testing latency ? Your process and figures would be interesting to see.
The other thing that would be a major obstacle is that there is no real time kernel for BSD in the way that there is for Linux. Syscalls maybe another issue as well, I'm unsure whether the APIs for BSD and Linux are the same.
Linuxcnc isn't "designed for debian" originally the ISO were built for Ubuntu, but licensing became an issue. Linuxcnc can be built for any distro. Years ago I was running Linuxcnc on Slackware and in a moment of pure madness I built it on a system built using the LFS & BLFS way.
As for "stupid back ground processes" it's up to the user what they want to run in the background and what features they want to lose. Do you want the OS to mount a drive when plugged in or do you want to mount & umount the drive manually ? What processes do you sugeest turning off for the best system ?
  • MaHa
  • MaHa
14 Nov 2025 00:40
QCombobox was created by MaHa
QCombobox
Category: Flex GUI
I have a choice of 12 items, and tried the Qcombobox. I was able to populate it, but it seems its not integrated to get the selected item for further processing. I used radiobuttons for a choice of 2 or 3, but for this amount of selections the switchboard is getting too big. Am i doing wrong, or is this not part of flexgui yet?
13 Nov 2025 23:33
Replied by tommylight on topic pulling my hair out please help
Category: Basic Configuration
Do you get any motion now?
13 Nov 2025 23:31
Why is there no BSDCNC? was created by tommylight
There was a build for ARCH Linux a while back, but i do not recall any BSD option, although you can always try building from sources.
  • zoeper
  • zoeper
13 Nov 2025 22:29
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
It's Alive! :)
I reverted back to my old installation and succeeded in clearing all errors except the kinematicsSwitch error.
I then tried a basic config in PnCConf and it worked. (I did not know PnCConf existed)
I am now reading a MPG in halscope, and am confident that by hook or by crook, this mill will run before the year is out.
Thanks to all for the help so far.
#happyChappie
  • PCW
  • PCW's Avatar
13 Nov 2025 21:20
  • djdock99
  • djdock99
13 Nov 2025 20:40
Replied by djdock99 on topic Maho mh800w retrofit
Been trying to get the estop and machine on circuits working properly today with help from marks mh400e information which he kindly sent to me.
just wondering if the older mahos have the same estop chains and components?
  • Route 66 Scott
  • Route 66 Scott
13 Nov 2025 18:31
LinuxCNC + Mesa 7i92TF + Gecko G540. Docs are useless. Help, Please!
Category: PnCConf Wizard
Thank you so much for pointing me in the right direction.
Yes, any AI I asked eventually started hallucinating code that broke things.
I did have someone send me a template HAL & INI set for the machine I am using (a Platform CNC with upgraded linear rails. Excellent hardware, currently being let down by confusing software, and its operator.) I was able to cobble something together that mostly worked, after much iteration. Since this was done manually, it didn't help me with learning and using PnCConf, which I would prefer.
At this point I have everything moving, but until I sort out homing, the Y & Y2 axes are not moving in unison. They are seen as separate Joints 1 & 2. I assumed there would be some way to simply lock them together as one gantry joint(?), but apparently that's not how LinuxCNC works.
  • Route 66 Scott
  • Route 66 Scott
13 Nov 2025 18:12
Yes, I have flashed the G540 firmware to the 7i92 card.
  • Hakan
  • Hakan
13 Nov 2025 17:27
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
I would start looking at
- encoders. With the current stm32f407 the quadrature counters are tied to certain pins, and max 4 such hardware counters. Code is in E3000, would copy that.
- EtherCAT chip, would base it on LAN9252 (which most of the cards use) due to Ax58100 limit of 2x16 pdos. Don't know of a limit for LAN9252, it's not less than 2x16.
- Opto-couplers, would revisit.
If you are thinking of stepper generator with encoder inputs, say for four of them, would base it on E3000 for the user code and extend to four encoders, code is already there. soes library from E7000. Hardware will be based on E3000 around stm32, around E7000 for EtherCAT.
One can think of one card supporting 1 drive. Or 2 stepper drives. And use multiple cards
In linuxcnc 2.10 there is 64-bit integers, so no risk for encoders overflowing. 32-bit isn't quite enough at least for spindles.
Is it just an idea, or are you going to do it?
  • TurboStreetCar
  • TurboStreetCar
13 Nov 2025 14:37
Replied by TurboStreetCar on topic Can MESA work without LinuxCNC?
Category: Driver Boards
Hey thats pretty awesome. Love the monarch also!
Is that using HAl-Core?
Do you have a github? Im looking to do something similar to this but with a custom GUI.
  • vibram
  • vibram
13 Nov 2025 14:37
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
Hello Hakan and thank you for all your work.
If I want to create a small PCB in order to add encoders, compatible with LinuxCNC, which version of your project would you advise in order to modify it?
  • skunkworks
  • skunkworks
13 Nov 2025 14:27
Replied by skunkworks on topic Can MESA work without LinuxCNC?
I am using hal only with a mesa card to control a monarch lathe spindle. (so encoder, 2 analog drives and some i/o)
Works great.
sam
Displaying 11386 - 11400 out of 11530 results.
Time to create page: 0.378 seconds
