  • 858PSJ
  • 858PSJ
09 Sep 2026 08:09
Poll: who still uses RTAI-only hardware drivers? (STG, Motenc, VTI, EVOREG, AX5
Moderator tommylight indicates that no 8255 is installed, instead, there's just a parallel port?  I'm using the "native" parallel port on the Compaq Presario,  Running dmesg on the rtai kernel says:
parport_pc 00:07 reported by plug& play ACPI
parport0 PC-style @ 0x378 irq 7 [PCSPP,EPP]
lp0: using parport0 (interrupt driven)
This could mean there is a version of linuxcnc kernel that already supports a "native" parallel port.  Certainly if there's an ISO image that already supports a parallel port my hardware setup isn't going to have the desired affect of testing against an 8255.
  • Lcvette
  • Lcvette's Avatar
09 Sep 2026 07:55
  • andypugh
  • andypugh's Avatar
09 Sep 2026 07:49
Replied by andypugh on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
The problem arises when the cam limit switch (Pin 28) is triggered: the motor shuts off, but the carousel ends up positioned between two pockets. The motor needs to rotate another 180° so that the cutout aligns with the sensor.
Which version of "carousel"? The newer version supports a slow-speed search for the index marker.
Settting decel-time and align-dc should activate this behaviour.
linuxcnc.org/docs/stable/html/man/man9/carousel.9.html
If the sense of the index marker is wrong, then you can typically connect to the inverted HAL input signal that most drivers support.
For example Mesa cards have pins like hm2_5i24.00.7i64.0.0.input-00-not which is an inverted version of hm2_5i24.00.7i64.0.0.input-00
  • Hannes
  • Hannes
09 Sep 2026 07:45
Replied by Hannes on topic Xenomai RT kernel
Xenomai RT kernel
Hi
Meanwhile, there is Xenomai3 and Xenomai4 support in master branch.
Details:
github.com/LinuxCNC/linuxcnc/issues/3878
Prebuilt Kernels and Linuxcnc 2.9.10 back-port for Xenomai4:
github.com/hdiethelm/xenomai3-linuxcnc
github.com/hdiethelm/xenomai4-linuxcnc
For me, it works well and I fully switched to Xenomai4.
  • Hannes
  • Hannes
09 Sep 2026 07:34
Replied by Hannes on topic How build Linuxcnc with xenomai3?
Category: Installing LinuxCNC
Hi All
Meanwhile, I fixed Xenomai3 support.
Additionally, I added Xenomai4 including support Ethernet mesa cards.
Details:
Is someone using Xenomai3 actively? Xenomai3 support for Ethernet mesa cards is available in a private branch but not (yet) merged.
  • andypugh
  • andypugh's Avatar
09 Sep 2026 07:24
Replied by andypugh on topic gearchange
gearchange
Rather than LUT5 look at using a match_8 for each gear.
Alternatively, a mux_generic with 6 bit inputs could provide the gear number, or a pair of them could provide the speed limits.
loadrt mux_generic config="ff64,ff64,ff64" names="gear,max,min"
Your HAL file would only need to define inputs for the valid gear positions, not for all 64 possibilities.
  • andypugh
  • andypugh's Avatar
09 Sep 2026 07:09
Has anyone gotten Tooledit gui working in PathPilot?
Category: PathPilot
The latest version of the Python Tooledit widget might suit you better, as of this commit it looks like it can run standalone.
github.com/LinuxCNC/linuxcnc/commit/fc24...a518b07987c9e20fd30e
  • tuxcnc
  • tuxcnc
09 Sep 2026 07:05
I don't recommend this kind of fun to anyone, but LinuxCNC with Trixie can be installed and run from an 8 GB partition.
For a standard xfce4 installation, 16 GB is enough.
I'm talking about just LinuxCNC without any CAD/CAM or other utilities.
Of course, today it is difficult to buy such a small disk and there is no technical or economic justification for it, but it gives you an idea of ​​how much is needed.
  • grandixximo
  • grandixximo's Avatar
09 Sep 2026 06:28
40 GB would be plenty, if you could run gparted and move your partitions around making space for a third system, and install debian trixie, maybe with xfce, we could try and develop support for pci 8255 on the preempt-rt kernel, and you could test it out.
preempt-rt kernels are easy to install,
sudo apt install linux-image-rt-amd64 linux-headers-rt-amd64
Is all you need for that, you will have to run in place, so you want to git pull the repo, and build locally uspace and run in place.
Once you got that working, let me know, and I will prepare something for you to test.
  • Waldemar
  • Waldemar's Avatar
09 Sep 2026 04:49
Replied by Waldemar on topic GrooveCam
GrooveCam
Category: Show Your Stuff
Sure thing, I'll try and put one together in the next couple of days.
  • rodw
  • rodw's Avatar
09 Sep 2026 03:49
Industrielle Linux CNC 5achs Fräsmaschine
I would suggest qtdragon-hd with a 1080p touch screen. Several probing methodologies are included.
Linuxcnc includes a  (large?) number of Sims.
There is an extensive thread about Ethercat jitter which you will see died out once issues were resolved.
forum.linuxcnc.org/ethercat/58103-ethercat-random-jitter-fix
Part of the solution  is tuning the system for RT performance and it was comforting for me to see it acknowledged that my tuning  methods were needed. I might add, the same applies for mesa network cards.
The fundamental difference between mesa and Ethercat is that mesa requires a dedicated point to point railway track. Packets hop on the train and get off at the end. Then packets get on the train and go back to the PC.
Ethercat is more like a streamlined bullet train which goes past a number of stations (slaves). Packets get on and off at each station (slave) without the train stopping. Hence why I say its more efficient.
The other difference is that mesa has pncconf to build your config and ethercat need you to build your config from a template just like I had to do on my first machine that used a Mesa 7i76e that was not supported by LinuxCNC at the time.  Having a similar Ethercat dsonfig tool is unlikely. It hard enough to do for the family if mesa cards, imagine how hard it would be with thousands of devlces, some of which are rarely found on a CNC machine. Then ask a machine to home itself without LinuxCNC's knowledge or control....
  • rodw
  • rodw's Avatar
09 Sep 2026 03:18
Replied by rodw on topic 4WD 4WS gps guided lawnmower.
Category: HAL
It seems to me the lawn is really an XY plane with no motors on the axes and the tyres follow a tangential arc and provide the drive.
I think the new motion.interp.heading pin in master branch could solve this. You give the mmachine fake XY g1/g2/g3 moves including the arc at the end and tell the tyres (eg A axis) to follow the heading. If the front and rear wheels need to follow differing arcs on a turn, you might need to adjust/scale the heading using a real time component. Perhaps the spindle speed (S command) might set the rpm on the wheels.
I think with this new feature, solving your problem is a lot simpler than you think.
  • MisterXmin
  • MisterXmin
09 Sep 2026 02:47
Replied by MisterXmin on topic Industrielle Linux CNC 5achs Fräsmaschine
Some more questions:
What's the best touch GUI in your opinion? Later I must implement custom multi spindle tool probing etc, so that should be possible.
Can someone give me some tips how to set up a machine simulation? It would be great if that also hast a collision detection. Is that possible?, how does that integrate into a GUI?
  • Johnsinski
  • Johnsinski
09 Sep 2026 02:39
Replied by Johnsinski on topic 4WD 4WS gps guided lawnmower.
Category: HAL
Please excuse the crudity of these drawings. I didn't have time to build it to scale. (Doc Brown BTTF reference) ;)
  • MisterXmin
  • MisterXmin
09 Sep 2026 02:39
That sounds great, where do I find more information about that?
Displaying 1141 - 1155 out of 11356 results.
Time to create page: 0.357 seconds
