30 Sep 2025 01:35
Replied by tommylight on topic Extremely confused - Nonworking limit switches
Ok i just saw the attachments,
this is on Taig new
net min-x <= hm2_7i96s.0.gpio.001.in
while this is on Modlathe
net min-home-x <= hm2_7i96s.0.inm.00.input-00-not
not the same pins, and i do not mean the number, probably choosing the pins on the wrong page of the wizard ???
Damn, i am making a lot of assumptions tonight, i better go sleep, it is 3:33AM here! :)
30 Sep 2025 01:27
@LangdonS, he has 2 of Mesa 7i96S, so why are you suggesting he use parallel port testers?
Not helpful, just confusing.
@ffffrf
trying to clear things a bit, so you have
1 single PC
2 of Mesa 7i96S
2 of separate machines
Is that correct? Assuming yes
From that, PC works properly with Mesa1, machine works properly with Mesa1, correct? Assuming yes
That same PC with the Mesa 2 works for steppers but IO does not work, right? Assuming yes
Do you need to run both Mesa/machines at the same time? Assuming no
I am pretty sure 2 Mesa can be run, but not two instances of LinuxCNC, although there was some talk about that.
Assuming all of the above is correct:
-There is no need to change Mesa board address, nor change PC address at all to use both cards, but not at the same time. Leave the PC at 10.10.10.11 and both Mesa at 10.10.10.10. That reminds me, the networking on your PC is not set correctly despite working intermittently as it has two different names assigned to the same interface, and this must be corrected for reliable connection.
-regarding non working IO, i suspect you might have changed the serial ports on the PncConf wizard, but again, this is my assumption and as such might be wrong.
-easiest way = make a new config, do not change serial ports numbers, see if that works
or
-open both hal files, for Mesa1 and Mesa2 with a text editor (do not use office stuff) and check the "loadrt" lines at the top of the files, see if they are the same and if the sserial string is the same
Just in case, you can make as many config as you like, you can have several configs for the same machine with say different speeds or different accelerations or different limits or.... so feel free to make new configs till you get things working as you like them to.
Wow this was long.... :)
  • ffffrf
  • ffffrf
30 Sep 2025 01:26 - 30 Sep 2025 01:29
Hopefully I am using the correct terminology, by config I just mean associated hal / ini files
so my taig (config 2) represents the second machine using (mesa2) and my MODLATHE (config 1) was paired with my mesa1 board
Typing halcmd show param hm2*packet* only brings up error-decrement (value 1), error-increment (value 2), error-limit (value 10) and read-timeout (value 80), I do not see a total packet error parameter
  • PCW
  • PCW's Avatar
30 Sep 2025 01:09
Can you post the two configurations?
Are you dropping packets?
That is, what is:
hm2_7i96s.0.packet-error-total
Sounds like something very basic is broken
  • jschulze
  • jschulze
30 Sep 2025 01:07
Replied by jschulze on topic Wrapped Rotary on Non Rotary Axis Letter.
Category: Basic Configuration
What axes does your setup have?
Perhaps having unlimited "WRAPPED_ROTARY" axes on any axis letter is a feature should be added to the source code.
I'm using XYZACW.  It's a router with an CA style head.  The W axis is an additional "C" axis rotary table, but I didn't want to use B because the kinematics file I'm using for TCP has a B axis and I don't know how to mess with the kinematic enough to make it ignore the B axis commands.
  • ffffrf
  • ffffrf
30 Sep 2025 00:48
sorry not super tech savvy, I think so though?
All of this is on a single computer with a single ethernet port (computer1)
1. I started with my mesa1 (mesa1, config1) board set at 10.10.10.10, which was working all correctly for machine1 on computer1
2. Purchased second mesa 7i96s for a second machine (mesa2, config2) for computer1, and gpio and steppers work in pncconf for config2 but when running config2, none of my GPIO work, but steppers work
3. When I run config1 on mesa2 on computer1, the GPIO works as normal
4. I tried changing mesa2 to 10.10.10.11 per my above code, and ran config2, but it did not fix the issue
5. when I run a custom halrun (per above post) with mesa2, the GPIO does work, but still doesnt work when i run config2
I never ran ip command at all except for the related code in my above post
I have thus far never had success with config2 and mesa2 gpio working under any circumstance
  • Ilysha
  • Ilysha
30 Sep 2025 00:39
Replied by Ilysha on topic Can the OPI5 be Configured to Run LCNC?
Hi everyone! I’m new to Linux and Orange Pi, but I’m really eager to learn and figure things out. I would be incredibly grateful for your help. Could someone write a simple, step-by-step guide—from a fresh Armbian installation to a fully working setup, including using files from a disk? I’m really trying to understand everything and I’ve already exhausted ChatGPT! Please, I would deeply appreciate any guidance you can give
  • PCW
  • PCW's Avatar
30 Sep 2025 00:26 - 30 Sep 2025 00:28
So LinuxCNC setup (2.9.4) with 7i96S initially set at IP address 10.10.10.10:
mesaflash --device  7i96s --addr 10.10.10.10 --readhmid
(works)
LinuxCNC with 10.10.10.10 IP address works and inputs work
mesaflash --device  7i96s --addr 10.10.10.10 --set ip=10.10.10.11
mesaflash --device  7i96s --addr 10.10.10.10 --reset
mesaflash --device  7i96s --addr 10.10.10.11 --readhmid
(works)
LinuxCNC with 10.10.10.11 IP address works and inputs work
mesaflash --device  7i96s --addr 10.10.10.11 --set ip=10.10.10.10
mesaflash --device  7i96s --addr 10.10.10.11 --reset
(works)
Did nothing else (never ran ip command at all)
  • ffffrf
  • ffffrf
29 Sep 2025 23:33 - 30 Sep 2025 00:20
I do power cycle the card each time, this is what it outputs with ip a:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 34:17:eb:c5:16:36 brd ff:ff:ff:ff:ff:ff
altname enp0s25
inet 10.10.10.1/24 scope global eno1
Keep in mind after using mesa flash to change my card's ip to 10.10.10.11, I can ping it but linuxcnc wont connect to it until I do:
sudo ip addr flush dev eno1
sudo ip addr add 10.10.10.1/24 dev eno1
sudo ip link set eno1 up
sudo ip neigh flush dev eno1
ping -c2 10.10.10.10
and if i restart my computer I have to redo that code, but I imagine I just need to set it as permanent, but nontheless it does not fix my issue even when linuxcnc and pncconf can communicate with the board on its new ip address
EDIT:  when I run a temporary hal instance via
halrun
loadrt hostmot2
loadrt hm2_eth board_ip=10.10.10.11
loadrt threads name1=servo-thread period1=1000000
addf hm2_7i96s.0.read  servo-thread
addf hm2_7i96s.0.write servo-thread
start
and use getp to get the value of the pin, the limit switch DOES work
  • ShemJ
  • ShemJ's Avatar
29 Sep 2025 23:17
can't pass a home-mode negative number to ethercat drive with setp in HAL file
Category: HAL
I've got Leadshine EL8 servo drives talking over ethercat and am trying to get sensorless homing to work.
With the help of the forums, specifically this post , I've found a way to request a specific homing mode. In the EL8 drive documentation, all the torque based sensorless homing modes are a negative number.
setp lcec.0.0.home-mode -6
is what I'm after. Other modes such as mode 35 which homes in place, works just fine so everything appears to be in order. As far as I can tell, the positive number homing modes work fine, but not the negative ones. I can't tell if this is a drive problem or a linuxcnc problem.
Would there be any reason why I can't pass a negative number? Syntax maybe?
HAL file
#  AXIS X
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale 1677721.6
[b]setp lcec.0.0.home-mode 35[/b]
setp lcec.0.0.home-hi-speed 500000
setp lcec.0.0.home-lo-speed 500000
setp lcec.0.0.home-acc 100000
  • PCW
  • PCW's Avatar
29 Sep 2025 23:12
Edit3: I have successfully changed the IP address to 10.10.10.11 and connected it back to my computer and it STILL only works in pncconf but NOT when i run my linuxcnc!!!!!
What is the host IP address set to?
The command:
ip a
will report this.
Also note that when you change the 7I96S EEPROM IP address, you must power cycle the card
or issue a reset command before the new EEPROM information is applied.
29 Sep 2025 22:51
What informs the location of the virtual spindle in the GUI
Most probably from the ini file and the respective values for each axis/joint and in correlation to kinematics used.
That is just off the top of my very tired head, so might want to wait for someone to confirm or deny that.
And i would not call it "virtual", it is an actual representation of the machine, but i am sure it can be argued both ways.
29 Sep 2025 22:46
Replied by tommylight on topic LinuxCNC 2.9.5 has been released
Category: LinuxCNC Announcements
If you somehow find yourself here, do not use 2.9.5, use 2.9.6. More info here:
forum.linuxcnc.org/29-forum-announcement...xcnc-v2-9-6-released
29 Sep 2025 22:45
Video : Plasma Cutting With Different Gases Tested
Category: Plasma & Laser
Bump to remove it from "no replies" list.
29 Sep 2025 22:26
Replied by tommylight on topic FreeCAD 1.0 Who's using it?
Category: CAD CAM
Did all this and some more 2 days ago while i was building a small 4 axis cnc machine and waiting for it's parts to print (not shown here, but the round teethed thing shown here is also for that machine).
Notice the changes on the FreeCAD GUI, made it much more enjoyable to use
Displaying 11866 - 11880 out of 14147 results.
Time to create page: 0.624 seconds
