  • unknown
  • unknown
20 Oct 2025 08:07
Replied by unknown on topic 1000 pulse per rev limit?
When you start talking tenths, you have to start looking an thermal expansion.
  • meister
  • meister
20 Oct 2025 05:31
Replied by meister on topic 1000 pulse per rev limit?
It always depends on the speed (rpm) and the hardware you are using. You should describe what you have in more detail.
  • Ayden25
  • Ayden25
20 Oct 2025 03:36
1000 pulse per rev limit? was created by Ayden25
Hey all. I have dropped it to 800 so it works but I would like a higher resolution. I'm just wondering how I can get 1600 plus per rev in linux cnc so I can have .0001" per step
Thanks in advance.
  • DavidR8
  • DavidR8
20 Oct 2025 03:28
New Probe Basic install - error during install.
Category: QtPyVCP
As a LinuxCNC rookie I'd be happy to test-drive any documentation.
  • unknown
  • unknown
20 Oct 2025 01:23
Replied by unknown on topic burning iso to USB drive
Use win32diskimager.org/ to write the ISO to the USB drive. It's dumb in the way it will just write byte by byte and not try to do anything fancy.
  • unknown
  • unknown
20 Oct 2025 01:18
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Category: Installing LinuxCNC
Despite my misgivings and boneheadedness I shall experiment with your suggestion.
If anything goes wrong I shall visit the local coven and take appropriate action. ;)
My work experience has been a little different, many years labouring and doing install and repairs to play equipment, road work and traffic control. What this has taught me is that people aren't that a fair percentage of people are lucky to breathe and walk at the same time. So I try to accommodate for the lowest common denominator.
Take for instance when I used to work on the railways during a weekend shutdown. Signs every informing passengers the train service has been replaced by a bus service. Panels of track that have been pulled up, and people sitting on the platform asking when the nest train is due.
So yeah no actual experience in the computer field as a professional, but way too much dealings with The General Public hahaha.
Tho there were times as a Traffic Controller when the temps were in the high 40c that some residents would offer cold drinks. Or night shift in the middle of winter when someone would bring out a hot chocolate.
  • scsmith1451
  • scsmith1451's Avatar
19 Oct 2025 23:17
linuxcnc.command().mdi() vs .program_open() was created by scsmith1451
Can anyone tell me the difference(s) between calling an ngc routine with .mdi("o<myfunction> call") and .program_open("myfunction.ngc")?
  • Lcvette
  • Lcvette's Avatar
19 Oct 2025 23:06
Replied by Lcvette on topic Probe Basic Probing Location
Category: QtPyVCP
Glad you got it sorted out! Enjoy probing!
  • Lcvette
  • Lcvette's Avatar
19 Oct 2025 23:03
Replied by Lcvette on topic increment 4 MPG jog wheels with Basic Probe
Category: QtPyVCP
That's a much easier method! Glad you got it sorted out!
  • Lcvette
  • Lcvette's Avatar
19 Oct 2025 23:02
Category: QtPyVCP
Glad you got it sorted, I will add this to the docs for the next release
  • sconisbee
  • sconisbee
19 Oct 2025 20:36
Feed per rev G95 way too fast was created by sconisbee
Category: Basic Configuration
Hi, Sorry, please bear with me, I'm new here and relatively new to LinuxCNC.I've been converting an old Boxford 240 TCL to LinuxCNC running on a Pi5.
Everything is running fine(ish) there are still some glitches and errors that crop up and the odd latency warning too (stepping is done on an EC300 running remora so I'm not so worried about the latency warning).
However... i've gotten to the point of testing, and for some reason in G95 and feeding at 0.1mm/rev the axis runs at way faster rate, 10x maybe more.Anyone have any idea what is going on?  The only other thing to note is that I am having issues with LinuxCNC seeing my index pulse, but it is seeing the count from the single encoder (100 slot disk with a second slotted opto switch for index so not quadrature).
I'm assuming that its possible the feed issue could be linked to that.
The other issue I am having is when i run a program, it won't run through automatically.  The only way it will run is by me hitting the single step through button.  I'm wondering if that is linked to the encoder also as perhaps LinuxCNC isn't seeing "at speed" so isn't letting the program run?
hal and ini attached.  Please forgive the messy files, once they are running right I'm planning on cleaning them up.
  • sconisbee
  • sconisbee
19 Oct 2025 20:13
Replied by sconisbee on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good Evening,
I'm relatively new to LinuxCNC having come from Mach 3 on mills previously.  Having found mach3 limited for lathes I have moved over to LinuxCNC.  I have been/have converted an old Boxford 240 TCL to run on new steppers, and LinuxCNC running on a Pi5 connected to an ec300 running the remora firmware.
Everything in general is working fine, except the spindle encoder.  Annoyingly, it is not a quadrature encoder.  It is a 100ppr slotted disk with an additional index pulse.  Currently, this is feeding directly into the Pi5, which is reading the 100ppr but missing the index.
So, my plan is to move the encoder and index over to the ec300.  While i understand that the ec300 has a dedicated index input, I am unsure on using an encoder with remora.  I've read the docs, and have run through this thread but my head is spinning trying to get things straight.
Does the EC300 have the ability for a hardware encoder?  if not, software would work too, I'm just not sure how to set up the encoder component as I do not have a B phase.
On the hardware side, I'm going to have to work out some electronics as the encoder as it stands is running on 3.3v with schmitt triggers for conditioning.  So I will have to come up with something to level shift this to 24v.
Any help that could be given on the remora side of things would be greatly appreciated.
  • clayton2ndtry
  • clayton2ndtry
19 Oct 2025 20:09
Replied by clayton2ndtry on topic burning iso to USB drive
9660. The DVD drive fails BIOS diagnostics. Spindle error. I am ordering a replacement drive. In the meantime, I used a USB DVD drive. The 2.9.2 disk would not boot. But an ancient disk from Sherline called EMC2 did boot and install from that USB DVD drive. This is so ancient that Update Manager does not work. I put 2.9.4 on the DVD. While trying to install, it complained about unmounting media failing. I suspect 2.9.4 ISO lacks the smarts to handle a USB DVD drive. I have successfully installed 2.7.14 before so that is next.
  • Sandro
  • Sandro
19 Oct 2025 19:53
Replied by Sandro on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
Hello everyone
After seeing your video (looks really great by the way), I wanted to check out MonoKrom as well. However, following the instructions on the QtPyVCP repo, I fail at the step of installing MonoKrom itself. The apt source seems not be available anymore.
www.qtpyvcp.com/install/apt_install.html
$ sudo apt install python3-monokrom
Greetings Sandro
  • ihavenofish
  • ihavenofish
19 Oct 2025 19:46
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
Progress. I cut the end frames down from the old machine so chips don't build up at the ends of the rails. this lets me reduce the safety margins and I get about 310mm y travel now. Also made a new top plate for the Z which increases clearance 10mm, and ups the travel to 112mm. Much smaller than the new version, but we don't have that yet sooo :P
Displaying 12076 - 12090 out of 13404 results.
Time to create page: 1.525 seconds
