  • timo
  • timo
21 Jun 2025 06:04
Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
Just a comment from enduser perspective.
( I already struggle hard to get my small wiring project organized. "cable management" :-) )
Diving into "building Linux from source", and fighting drivers etc. seems to be completely unreal.
Most (or only some?) people already having a hard time with the hal configuration and getting basic UI functions to work.
How many thousand hours do I have to spend extra in sofware research and learning new things, in order to save 60 coins on a control card?
Considering the cost of mechanical components (e.g. for metal working machines), the FPGA card is the least financial problem.
I feel that leaves a very small target group beeing interested in a "race to the bottom" with FPGA card pricing. This target group is also looking into 3d printer firmware and hardware. (cheap, and for some things usable)
  • Hakan
  • Hakan
21 Jun 2025 06:01 - 21 Jun 2025 06:01
Replied by Hakan on topic Do I need a better PC?
Category: EtherCAT
I have had this gravel sound. Starts by sounding like tick, tick gradually transitioning to gravel and going back to tick,tick and disappear.
Repeats itself after some minutes.
It may not be what causes it for you, but in my case it was a slight difference in the DC cycle time and linuxcnc cycle time.
One is running slightly faster than the other. Both nominally 1 millisec, Combined with some latency of the linuxcnc computer
ethercat will send and receive data not from the current servo cycle, but from the previous or the next cycle.
The gravel sound would appear with the transition over this mixed period to stabilize when the cycles are so much out of phase that they always receive data from the same servo cycle phase.
You can check with halscope of the actual position for example. When the gravel sound happens you will see that
the actual position isn't a smooth line anymore as is expected. Instead you will see that it stays on the same
position for a cycle, to maybe jump double distance another. This is worthwhile checking.
Two curves in halscope, commanded position and actual position, with and without gravel sound would be interesting to see.
  • PCW
  • PCW's Avatar
21 Jun 2025 04:58
Using Mesa 7i95T for laser + galvo (xy2-100) control
The TXEN pins corresponding GPIO pins would need to be set as outputs
and into the correct state in the hal file, something like:
setp hm2_7i95.0.gpio.014.is_output true
setp hm2_7i95.0.gpio.014.out false
setp hm2_7i95.0.gpio.017.is_output true
setp hm2_7i95.0.gpio.017.out false
  • djdelorie
  • djdelorie
21 Jun 2025 04:19
M6 shuts off spindle, but no UI confirmation, and program doesn't pause
Category: Basic Configuration
something to try - switch to relative moves, then G1 Z0 ? Even though you're not moving, it may count as a wait point for M3
Or use M66 instead? You could hook that up to a button near the spindle, or a GUI button.
  • tuxcnc
  • tuxcnc
21 Jun 2025 03:42 - 21 Jun 2025 09:23
Maybe I some don't know...
Maybe I do something wrong...
But :
root@HP-15:/temp/temppp# ls -n remora*
-rw-r--r-- 1 0 0 24206 2024-12-19  remora-eth-3.0.c
-rw-r--r-- 1 0 0   894 2024-12-19  remora-eth-3.0.h
root@HP-15:/temp/temppp# md5sum remora*
b447865ec7d51854e3baae2c9649fc65  remora-eth-3.0.c
4d64b37ed9177dbdb67f64479a2985f5  remora-eth-3.0.h
root@HP-15:/temp/temppp# cat remora-eth-3.0.c | grep comp_id,
            comp_id, "%s.enable", prefix);
            comp_id, "%s.reset", prefix);
            comp_id, "%s.status", prefix);
                    comp_id, "%s.joint.%01d.pos-cmd", prefix, n);
                    comp_id, "%s.joint.%01d.vel-cmd", prefix, n);
                comp_id, "%s.joint.%01d.enable", prefix, n);
                comp_id, "%s.joint.%01d.freq-cmd", prefix, n);
                comp_id, "%s.joint.%01d.pos-fb", prefix, n);
                comp_id, "%s.joint.%01d.scale", prefix, n);
                comp_id, "%s.joint.%01d.counts", prefix, n);
                comp_id, "%s.joint.%01d.pgain", prefix, n);
                comp_id, "%s.joint.%01d.ff1gain", prefix, n);
                comp_id, "%s.joint.%01d.deadband", prefix, n);
                comp_id, "%s.joint.%01d.maxaccel", prefix, n);
                comp_id, "%s.SP.%01d", prefix, n);
                comp_id, "%s.PV.%01d", prefix, n);
                comp_id, "%s.output.%02d", prefix, n);
                comp_id, "%s.input.%02d", prefix, n);
                comp_id, "%s.input.%02d.not", prefix, n);
                comp_id, "%s.NVMPGinput.%01d", prefix, n);
Is the PV raw count?
Is the index some input?
Where is position captured at index ?
  • scotta
  • scotta's Avatar
21 Jun 2025 01:00
Hi tuxcnc,
Have a bit more of a look at the module code.
1. Index count is captured in an ISR.
2. When the next servo period runs the module, the index input is set in the data packet so LinuxCNC knows that the index was detected.
3. The index count captured in the ISR is stored in the data packet.
On the LinuxCNC side, if the index enable hal pin is set and the phase Z input (the index input) then the the index count is set with the encoder count, the count that was captured in the ISR.
The ISR latency is the only potential timing miss match.
  • phino
  • phino
21 Jun 2025 00:43
The differential input is because the full XY2-100 interface has a status channel
but its not required for operation.
Ok, in that case the status channel can be skipped as the galvo does not seem to implement it.
So the options are using two step/dir channels, or one step/dir and two sserial  for their tx channels? There's no way to avoid stealing step/dir channels if using the galvo on the 7i95T?
Although, in the end, the 7i78 might be needed anyway.
The serial TXEna pins would end up as GPIO pins and have to be set into the enabled
state in the hal file.
What does this entail?
  • Kieran
  • Kieran
21 Jun 2025 00:26 - 21 Jun 2025 00:28
Replied by Kieran on topic Do I need a better PC?
Category: EtherCAT
I don't think its a servo hardware issue. All of them sound like gravel sometimes. Or they are all smooth. I'm wondering if its something to do with the feedback loop between the servo and linuxcnc? It sounds like they are being commanded unsteady changing speeds at a somewhat high frequency. They only have UVW coming out of the motor. And encoder seems to have standard a/b v+ v- stuff going on. I don't think there's any hall sensor for the rotor.
  • AdelRTP
  • AdelRTP
20 Jun 2025 21:34
Mesaflash 3.4.9 shows "Unsupported ethernet device 7I76EU" despite successful pi
Thanks bro, I try to download it several times but didn't work, until i use an other pc problem in my pc
  • PCW
  • PCW's Avatar
20 Jun 2025 20:58
Replied by PCW on topic Lo ejes dejaron de moverse
Short in the wiring, missing ground or something similar is possible.
Plasma systems are pretty unforgiving due to the massive EMI they
generate at arc start.
The card is likely repairable by replacing U5 and/or U7
Even shielded cables can be a liability if there is a ground error
as they can couple ground noise into the signals.
  • NT4Boy
  • NT4Boy
20 Jun 2025 20:53
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Thanks Andy,
Since writing that I did manage to inadvertently introduce an axis offset via the tool table, so have become super cautious.
  • PCW
  • PCW's Avatar
20 Jun 2025 20:49 - 20 Jun 2025 20:50
You would load the 7I76eu firmware that includes PKTUart support
7i76eu_7i76x1_pktv3d.bin
This file is in the 7i76eu.zip archive downloaded from Mesa's store (in the specifications tab)
You program it with mesaflash, something like:
mesaflash --device 7i76eu --addr 10.10.10.10 --write 7i76eu_7i76x1_pktv3d.bin --reload
  • Johnnysacalu
  • Johnnysacalu
20 Jun 2025 20:42
Replied by Johnnysacalu on topic Lo ejes dejaron de moverse
Menos de 1v antes de encender linuxcnc y 0v cuando lo enciendo en step/dir
pero tengo tierra, cables blindados y filtro emi que pudo fallar?
Displaying 14896 - 14910 out of 15069 results.
Time to create page: 0.792 seconds
