  • m3chanist
  • m3chanist's Avatar
16 Jun 2025 11:49
Replied by m3chanist on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
"What's wrong? I'm using Stepperonline A6 motors, but they're the same as the EL8, just with a different name. "
Are you sure?
I had a look at those A6 drives, from appearance they look nothing at all like my EL8's. Similar form factor, that's about it.
  • tar_san
  • tar_san
16 Jun 2025 11:43
Replied by tar_san on topic Missing link in homing LC10E
Category: EtherCAT
Hello everyone.
I need help for homing LC10E.
I've read cia402.comp and cia402_homecomp.comp ( the latest version )
1)
This line was commented out in last commit in cia402_homecomp.comp Line 217.
//customH[joint_num].request_custom_homing = 1;
2)
In HAL,
net x-home-request joint.0.request_custom_homing => cia402.0.home
I think cia402.opmode doesn't change to homing mode(6) because of it.
Should I use older version of cai402_homecomp to get driver-homing work?
(if in this situation, which version should I use ? )
  • Hakan
  • Hakan
16 Jun 2025 11:41
Cumark Closed-Loop VFD with EtherCAT (non-CiA402) Configuration
Category: EtherCAT
One need a vfd expert rather than an EtherCat expert I would say.
You say you get the same results using TwinCAT, that's good since it rules out linuxcnc being the problem.
Unless you get some good tips here you should probably go to the seller/manufacturer and ask them to provide details to make the vfd work.
But the behavior of the vfd doesn't seem correct.
Anyway, I looked at the config and manual and it may perhaps be that the start command should only be given a short time, really only one cycle. So give start 882 and immediately after 880. Same for stop: 881 followed by 880. Just a possibility, you must test to verify. If that turns out to be the case you can use the "oneshot" hal component.
Not sure what you mean regarding 06.05. 06.05 is the controlword you send to the vfd, right?
  • Jens23
  • Jens23
16 Jun 2025 11:39
Replied by Jens23 on topic Einbindung AX5000 und EL3104
Category: Deutsch
Hallo,
hast du den AX5106 jemals zum Laufen bekommen? ich möchte den für meine nächste Spindel nutzen, da die einen Encoder drin hat und die Position regeln soll.
Würde mich interessieren.
  • my1987toyota
  • my1987toyota's Avatar
16 Jun 2025 10:10
Replied by my1987toyota on topic Linux vs Windows value
A Linux command I remember seeing is ( killall windows ) if only that were truly possible. (sigh)
  • JAMSys
  • JAMSys
16 Jun 2025 08:50
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
Is it possible to create an auto-login for the raspberryPi in order to create a keyboard less system with gmoccapy?
  • Edi_48
  • Edi_48
16 Jun 2025 08:44
Replied by Edi_48 on topic Rote LED
Rote LED
Category: Deutsch
Netzteil 5 volt 10 Amper
  • Edi_48
  • Edi_48
16 Jun 2025 08:35
Rote LED
Category: Deutsch
60000 packets transmitted, 59992 received, +8 errors, 0.0133333% packet loss, time 60099ms
rtt min/avg/max/mdev = 0.048/0.133/6.074/0.075 ms, pipe 9
Beim starten von Linuxcnc und Steuerung sind alle 4LED grün nach dem Test brennen nur 2 LDS
  • mc_cubus
  • mc_cubus
16 Jun 2025 08:16 - 16 Jun 2025 08:22
Replied by mc_cubus on topic Probe tripped during non-probe move
Category: Basic Configuration
Hey, thank you for your insights. They can definitely be helpful. I solved the problem bit differently and if someone will ever need that I will just post it here:
I did set the digital output pin and connected it together with the actual probing trigger using AND component. So basically in .hal it looks like that:
[code]net probe-enable motion.digital.out-00 => and2.0.in0 # Sets and2.0.in0 based on M64 / M65
net near-window near.0.out => and2.0.in1 # Sets and2.0.in1 if sensor is in probing window range: near.0.out
net gated-probe and2.0.out => motion.probe-input
[code][code][code][code]M64 P0              # sets digital output pin P0 to TRUE: enable probing
G38.3 Z-180 F150    # Do the probing movement
M65 P0              # sets digital output pin P0 to FALSE: disable probing
[code][code]Maybe it's not the cleanest solution, but at least it works :)
[/code][/code][/code][/code][/code][/code][/code]
  • DMNZ
  • DMNZ
16 Jun 2025 07:28
Replied by DMNZ on topic Error finishing read... *sigh*
cheap Pentium J2900. i just posted my test results with settings few days ago in a thread called Pentium J2900 fanless pc test results, you can compare it with yours.
  • meister
  • meister
16 Jun 2025 05:32
I'm afraid there is still a bug when generating the ini/hal.
scale in need to be set in the encoder config (signals -> scale):
and out in the joint pwm/dir config (joint -> General -> Scale):
  • SebastianM
  • SebastianM
16 Jun 2025 03:38
Replied by SebastianM on topic Email Notification?
Email Notification?
Category: Forum Questions
I do get emails if I request a new password, but I never get any notifications for new replies.
  • SebastianM
  • SebastianM
16 Jun 2025 03:36 - 16 Jun 2025 03:45
Replied by SebastianM on topic Error finishing read... *sigh*
Will post a latency histogram on Thursday after a business trip.
Which hardware/ pc are you using?
  • cmorley
  • cmorley
Displaying 14971 - 14985 out of 15377 results.
Time to create page: 0.439 seconds
