LinuxCNC S-Curve Accelerations
  • tiagounderground
  • Junior Member
  • Junior Member
23 Apr 2025 14:00 #326958 by tiagounderground
Replied by tiagounderground on topic LinuxCNC S-Curve Accelerations
tried here, it works with the original trajetory planer on the rip install, when i change to tpmode=scurve i need to desable homing on the gantry axis and i can do jog movements but when running gcode the machine seens to be stoped but it is runing with an extremaly low aceleration, near 1 minut to move 1mm
23 Apr 2025 15:25 #326963 by Grotius
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Hi Tia,
It is : tpmod_scurve
And check if you use values for the trajectory :  vel + acc.
 [code]# Trajectory planner section --------------------------------------------------
[TRAJ]
TPMOD = tpmod_scurve
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 208.33
MAX_LINEAR_VELOCITY = 208.33
DEFAULT_LINEAR_ACCELERATION = 350
MAX_LINEAR_ACCELERATION = 350
POSITION_FILE = position_mm.txt
[/code]
I just isnstalled debian 13 on the desktop pc and installed the same software, but the ethercat-master from the codeberg repo.
It also runs ok. So that's a good sign.
23 Apr 2025 15:30 #326964 by Grotius
Hi Rod,
The Cia-402 i have seen the source code. It does not much.
It sends and recieves position, velocity, torque  trough a can protocol?
  • tiagounderground
  • Junior Member
  • Junior Member
23 Apr 2025 16:48 #326969 by tiagounderground
this is from my INI file. i raised the values but see no difference.
before i tried with the values you send, is the same on the ethercat config example
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
DEFAULT_LINEAR_VELOCITY = 20800.33
MAX_LINEAR_VELOCITY = 20800.33
DEFAULT_LINEAR_ACCELERATION = 350000
MAX_LINEAR_ACCELERATION = 350000
23 Apr 2025 17:57 #326973 by Grotius
Hi Tia,
I don't know why it won't run with cia-402.
We have more users with the same problem.
However the cia-402 source code does nothing with acceleration. Only torque, vel, pos.
Is there a alternative to the cia-402?
23 Apr 2025 18:26 #326974 by PCW
Replied by PCW on topic LinuxCNC S-Curve Accelerations
Tried to compile but got this:
In file included from emc/planner/curve.h:14,
                 from emc/planner/feed.h:15,
                 from emc/planner/feed.c:12:
emc/planner/emcmot_segment.h:27:10: fatal error: segment.h: No such file or directory
   27 | #include "segment.h"
  • tiagounderground
  • Junior Member
  • Junior Member
23 Apr 2025 18:49 - 23 Apr 2025 18:51 #326975 by tiagounderground
Hi Tia,
if you want to access my machine remotely i can give you access
Last edit: 23 Apr 2025 18:51 by tiagounderground.
23 Apr 2025 21:17 #326981 by rodw
Replied by rodw on topic LinuxCNC S-Curve Accelerations
Hi Rod,
Yes, the cia402 protocol defines a state machine to turn on a machine using a standard control word and a status word confirming current machine state. The attached PDF is a good summary
There are also a loosely defined  set of PDOs
What we really need is a component that just defines the turn on sequence and then a seperate homemod for drive homing. It may be possible to do the turn on in the homemod so there is only one module but it might then sit outside the hal lcec Ethercat loop so it may run one servo thread cycle behind.
24 Apr 2025 07:45 #326987 by Grotius
@Pcw,
Thanks for your effort. Not everything is installed by the makefile.
I think you need to look at the ./installer file, wich install's locally :
libclothoid3d
libscurve
segment.h is part off libclothoid3d and is installed in /usr/local/include
Then finally there is done a ldconfig.
I hope it works for you then.
The following user(s) said Thank You: zmrdko
24 Apr 2025 09:27 #326992 by Grotius
@Rod,
In the mean time, have done some reading about the cia-402.
  • The
    0x6065
    : following error window is not used or set by linuxcnc.
  • Velocity mode in combination with a tuned linuxcnc pid could be a try out.
@Tia,
We could verify iff all is installed ok. Like the libclothoid is in place etc.
But i think you already used the ./installer. It can be the installer failed at some step.
For the rest i don't know much about the cia-402.
Time to create page: 0.211 seconds
