  • DarkPhoinix
  • DarkPhoinix
07 May 2025 10:48 - 07 May 2025 13:19
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
Next i upload the DMA txt version for mi NVEMV5  RT1052 the problem is back and now need only 5 videos 4k without rustdek opened to see junction error!
I don't know what else to do. Except look for a motherboard that has video output.
Or maybe buy new hardware?
No activity
5 youtube video 4k windows
5 youtube video 4k windows and rustdesk connection
  • jochen91
  • jochen91
07 May 2025 10:41
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
In case it didn't work in solidworks here it is in ASCII format. In Fusion you have to take some extra steps to export it in ASCII format.
  • cmorley
  • cmorley
07 May 2025 10:17
Replied by cmorley on topic G-code file loading at G53 instead of G54
Category: Qtvcp
Also it looks like you have rotational offsets set.
  • cmorley
  • cmorley
07 May 2025 10:15
Category: Qtvcp
It looks right to me. G54 X and Y offsets are zero, so are in the same place as G53.
What were you expecting to see?
  • DarkPhoinix
  • DarkPhoinix
07 May 2025 09:35
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
DarkPheonix - that one got lost in translation. i kind of understand but if you can take a short video that would be great
Solved is remote desktop keyboard keys problem!! with direct Keyboard the JOG work correctly.
  • Aciera
  • Aciera's Avatar
07 May 2025 09:25
I'll try to open it in solidworks and reexport it as Ascii.
  • meister
  • meister
07 May 2025 09:24
there are two versions of STL files, ASCII and Binary, you have a binary file and vismach can only read the ASCII format
  • unknown
  • unknown
07 May 2025 08:54
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Here's the Mesa interface snippet from /etc/network/interfaces, note no DNS nor Gateway as mentioned previously.
Sorry for the delay in answering.
# Ethernet Static for Mesa card at 10.10.10.10
# Computer at 10.10.10.100
auto eth0
allow-hotplug eth0
iface eth0 inet static
	address 10.10.10.100
	netmask 255.255.255.0
	hardware-irq-coalesce-rx-usecs 0
  • jochen91
  • jochen91
07 May 2025 08:53 - 07 May 2025 08:54
I exported it in STL and OBJ. I had problems getting Fusion STL export into vismach. OBJ worked flawless. Thank you!
  • Aciera
  • Aciera's Avatar
07 May 2025 07:56
  • babinda01
  • babinda01
07 May 2025 07:09
Machine On Timer was created by babinda01
Machine On Timer
Hi
I have a small but little annoying problem that I am hoping someone can point me in the right direction to.
I am running the Axis UI, and when I click the estop button and then the machine on button, my servo drives are initialized and then enabled.  My problem is that it takes approx. 10sec for my servos to startup, if I try and jog or home before my servos start the dros click over but no motion is done.  Is there a way I can put a timer in the system that won't allow any motion for that initial 10sec or so after the machine on button is pressed?
Regards
Andrew
  • Farzad
  • Farzad
07 May 2025 06:02
Beginner Building a CNC - Questions About EtherCAT with Delta A2 and In
Hi, thank you for your help.
I believe I’ve found the ideal combination: using a Mesa 7i95T together with a 7i85
7i95t for 6 axis xyzca and in future spindle servo and 7i85 for toll changer
If I’m mistaken or missing something, I’d appreciate your corrections.
  • Hakan
  • Hakan
07 May 2025 06:02
Replied by Hakan on topic General Questions about using ethercat
Category: EtherCAT
The config should be ok now and I don't know of any obvious thing to do..
I made a quick search and there seems to be a problem with the CL3-E57H, in which order power, linuxcnc and network cable are activated, I might have got that wrong. Maybe you find something in that thread
forum.linuxcnc.org/ethercat/47534-etherc...e-configuration-woes
  • cakeslob
  • cakeslob
07 May 2025 03:01
Spyder - yes, the .not is used to invert the pin without having to use a linuxcnc not component. the probe looks good, the estop latch might not get reset for some reason leaving it in estop if i understand the logic of it from here.
adm1n - most of this one can be used but we gotta modify the nvmpg inputs to be normal ones
github.com/scottalford75/Remora-RT1052-c...ic/remora-nv-mpg.hal
  • onceloved
  • onceloved's Avatar
07 May 2025 01:49
Ls L7nh CİA402 servo Drive ethercat op and preop problems
Category: EtherCAT
You can also add me on Discord. My username is onceloved.cn
Displaying 15991 - 16005 out of 17067 results.
Time to create page: 1.992 seconds
