  • hellvetica
  • hellvetica
28 Apr 2025 11:33
Replied by hellvetica on topic Beckhoff EK1100 not entering OP mode
Category: EtherCAT
Hi, It turns out I had to reset the power on the device every time i tried a different config.
Suddenly it started working.
  • dm17ry
  • dm17ry's Avatar
28 Apr 2025 11:26
Replied by dm17ry on topic Mitsubishi SSCNET
Mitsubishi SSCNET
Category: Installing LinuxCNC
finally got the thing spinning with with my new hardware
  • alexandrap
  • alexandrap
28 Apr 2025 11:10
Replied by alexandrap on topic Updating pncconf for 7i95t
Category: PnCConf Wizard
bigmactx
I also have a 7i95T card and I have a problem with the configuration. I don't understand your procedure at all...
Please write the most detailed procedure for activating the script and attach the script - I would like to use pnconfig on linuxcnc 2.94.
Thank you
  • hellvetica
  • hellvetica
28 Apr 2025 11:09
Beckhoff EK1100 not entering OP mode was created by hellvetica
Category: EtherCAT
Hi, I'm trying to put together some Beckhoff IO module with ethercat.
I followed the examples and instructions i found on this forum but I can't get my EK1100 to go into OP mode.
I know my ethercat setup is good because I managed to get a servo drive working through ethercat.
Here's some outputs:
$ ethercat master
Master0
  Phase: Operation
  Active: yes
  Slaves: 2
  Ethernet devices:
    Main: 00:d0:b4:04:12:3b (attached)
      Link: UP
      Tx frames:   159376
      Tx bytes:    9588678
      Rx frames:   159375
      Rx bytes:    9588618
      Tx errors:   0
      Tx frame rate [1/s]:    109    110    112
      Tx rate [KByte/s]:      6.4    6.5    6.6
      Rx frame rate [1/s]:    109    110    112
      Rx rate [KByte/s]:      6.4    6.5    6.6
    Common:
      Tx frames:   218598
      Tx bytes:    13259230
      Rx frames:   218597
      Rx bytes:    13259170
      Lost frames: 0
      Loss rate [1/s]:          0     -0      0
      Frame loss [%]:         0.0   -0.0    0.0
  Distributed clocks:
    Reference clock:   Slave 0
    DC reference time: 799152688552526000
    Application time:  799152688552526000
                       2025-04-28 10:51:28.552526000
$ ethercat slaves -v
=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: +
Identity:
  Vendor Id:       0x00000002
  Product code:    0x044c2c52
  Revision number: 0x00120000
  Serial number:   0x00000000
DL information:
  FMMU bit operation: no
  Distributed clocks: yes, 64 bit
  DC system time transmission delay: 0 ns
Port  Type  Link  Loop    Signal  NextSlave  RxTime [ns]  Diff [ns]   NextDc [ns]
   0  MII   up    open    yes             -   1646636850           0           0
   1  EBUS  up    open    yes             1   1646637150         300         150
   2  MII   down  closed  no              -            -           -           -
   3  N/A   down  closed  no              -            -           -           -
General:
  Group: SystemBk
  Image name:
  Order number: EK1100
  Device name: EK1100 EtherCAT-Koppler (2A E-Bus)
  Flags:
    Enable SafeOp: no
    Enable notLRW: no
  Current consumption: -2000 mA
=== Master 0, Slave 1 ===
Device: Main
State: PREOP
Flag: +
Identity:
  Product code:    0x0af93052
DL information:
  Distributed clocks: yes, delay measurement only
  DC system time transmission delay: 150 ns
   0  EBUS  up    open    yes             0   1649051520           0         150
   1  EBUS  down  closed  no              -            -           -           -
   2  N/A   down  closed  no              -            -           -           -
   3  N/C   down  closed  no              -            -           -           -
General:
  Group: DigOut
  Image name:
  Order number: EL2809
  Device name: EL2809 16K. Dig. Ausgang 24V, 0.5A
  Flags:
    Enable SafeOp: no
    Enable notLRW: no
  Current consumption: 140 mA
And my config:
ethercat-test.hal
loadrt threads name1=servo-thread period1=1000000
loadusr -W lcec_conf ./ethercat-conf.xml
loadrt lcec
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
start
ethercat-conf.xml
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
<slave idx="0" type="EK1100" name="D1"/>
<slave idx="1" type="EL2809" name="D2"/>
</master>
</masters>
When I run
halrun -I -kf ethercat-test.hal
and then open halshow I can see all the pins but the devices stay in PREOP mode. I can write to the output pins but nothing changes on the drive. The RUN led blinks on the EK1100 confirming that it's in PREOP mode.
This is dmesg output:
[ 3307.915399] EtherCAT 0: Scanning bus.
[ 3308.163827] EtherCAT 0: Bus scanning completed in 248 ms.
[ 3308.163831] EtherCAT 0: Using slave 0 as DC reference clock.
[ 3308.195067] EtherCAT 0: Slave states on main device: PREOP.
Here i ran halrun -I -kf ethercat-test.hal
[ 3361.575932] EtherCAT: Requesting master 0...
[ 3361.575936] EtherCAT: Successfully requested master 0.
[ 3361.576003] EtherCAT 0: Domain0: Logical address 0x00000000, 2 byte, expected working counter 1.
[ 3361.576005] EtherCAT 0:   Datagram domain0-0-main: Logical offset 0x00000000, 2 byte, type LWR.
[ 3361.576018] EtherCAT 0: Master thread exited.
[ 3361.576020] EtherCAT 0: Starting EtherCAT-OP thread.
[ 3361.589265] EtherCAT 0: Master thread exited.
[ 3361.589274] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 3361.589312] EtherCAT 0: Releasing master...
[ 3361.589313] EtherCAT 0: Released.
Am I doing something wrong?
  • Aciera
  • Aciera's Avatar
28 Apr 2025 10:41
Replied by Aciera on topic Gmoccapy G54 Offsets
Category: Gmoccapy
It appears G10 L2 and G10 L20 assume machine is actually Homed physically, and no amount of data entry can change that.
I don't understand what you are doing. Without homing the machine first there is really no point in setting offsets.
  • khawla
  • khawla
28 Apr 2025 10:34
Replied by khawla on topic joint 0 following error
Hello everyone,
I have a strange problem with LinuxCNC on a machine that has been configured for a long time and was working perfectly.
Until a few days ago, everything was working fine. Then I modified my Python Touchy GUI file (adding dynamic multi-language translation using `set_label` on some buttons), and from that moment the problem appeared:
> "joint 0 following error" immediately after clicking "Start".
The problem still remains even if I completely delete all the translation modifications (`LABELS` and `on_combo_language_changed`);
Code I had added:
LABELS = {
    "en": {
        "title": "Industry 4.0 Monitoring",
        "total_time": "Total machine work time:",
        "current_job": "Current job time:",
        "next_greaser": "Next greaser in:",
        "time_monitoring": "<b>Time Monitoring</b>",
        "email_section": "<b>Email Notification Management</b>",
        "history_section": "<b>Job History</b>",
        "email": "Email:",
        "add": "Add",
        "remove": "Remove",
        "close_door": "Close Door",
        "open_door": "Open Door",
        "machine_on": "Machine On",
        "machine_off": "Machine Off",
        "home_all": "Home All",
        "pause": "Pause",
        "start": "Start",
        "feed_fast": "Fast",
        "feed_slow": "Slow",
        "feed_override": "Feed Override"
    "it": {
        "title": "Monitoraggio Industria 4.0",
        "total_time": "Tempo totale macchina:",
        "current_job": "Tempo job corrente:",
        "next_greaser": "Prossima lubrificazione in:",
        "time_monitoring": "<b>Monitoraggio Tempo</b>",
        "email_section": "<b>Gestione Notifiche Email</b>",
        "history_section": "<b>Storico Lavorazioni</b>",
        "email": "Email:",
        "add": "Aggiungi",
        "remove": "Rimuovi",
        "close_door": "Chiudi Porta",
        "open_door": "Apri Porta",
        "machine_on": "Macchina On",
        "machine_off": "Macchina Off",
        "home_all": "Home Tutti",
        "pause": "Pausa",
        "start": "Avvio",
        "feed_fast": "Veloce",
        "feed_slow": "Lento",
        "feed_override": "Regolazione Avanzamento"
def on_combo_language_changed(self, combo):
    lang = combo.get_active_id() or "en"
    texts = LABELS.get(lang, LABELS["en"])
    # Main Industry 4.0 labels
    self.builder.get_object("title_industria40").set_markup(f"<span size='xx-large' weight='bold'>{texts}</span>")
    self.builder.get_object("label_tempo_totale").set_text(texts["total_time"])
    self.builder.get_object("label_tempo_job_corrente").set_text(texts["current_job"])
    self.builder.get_object("label_tempo_prossimo_greaser").set_text(texts["next_greaser"])
    self.builder.get_object("frame_label_tempo").set_markup(texts["time_monitoring"])
    self.builder.get_object("frame_label_email").set_markup(texts["email_section"])
    self.builder.get_object("frame_label_lavorazioni").set_markup(texts["history_section"])
    self.builder.get_object("label_email").set_text(texts["email"])
    self.builder.get_object("button_add_email").set_label(texts["add"])
    self.builder.get_object("button_remove_email").set_label(texts["remove"])
    # Startup tab buttons
    self.builder.get_object("estop_reset").set_label(texts["close_door"])
    self.builder.get_object("estop").set_label(texts["open_door"])
    self.builder.get_object("machine_on").set_label(texts["machine_on"])
    self.builder.get_object("machine_off").set_label(texts["machine_off"])
    self.builder.get_object("home_all").set_label(texts["home_all"])
    self.builder.get_object("cycle_pausee").set_label(texts["pause"])
    self.builder.get_object("cycle_startt").set_label(texts["start"])
    self.builder.get_object("feed_override_plus").set_label(texts["feed_fast"])
    self.builder.get_object("feed_override_minus").set_label(texts["feed_slow"])
    # Feed Override label, keeping the percentage value
    current_text = self.builder.get_object("feed_override_label").get_text()
    percentage_part = current_text.split(":")[1] if ":" in current_text else " 100%"
    self.builder.get_object("feed_override_label").set_text(f"{texts}: {percentage_part}")
  • Murphy
  • Murphy
28 Apr 2025 10:32
@cakeslob , I had a look at your hal file again and copied your spindle stuff exactly just changed for my pins etc and it's still the same. So I think that rules out a hal file problem. I don't think it's the vfd because I can change the speed manually by pressing the + and - manually in the  Axis GUI and it responses quick with no dips when changing speeds.
  • electrosteam
  • electrosteam
28 Apr 2025 07:50
Replied by electrosteam on topic Gmoccapy G54 Offsets
Category: Gmoccapy
Went back to Axis.
linuxcnc.var has Parameter #5221 = -238.
Ignoring y and z for this description.
Launch Axis, Display is:
- x238,
- G54 x-238.
This shows G54 x correctly as negative, ( whereas Gmoccapy shows G54 x as positive ).
No amount of Touching-Off, G10 L2, G10 L20, etc, by me gets to the final correct values for a job:
- x0,
- G54 x-238.
For jobs, I turn steppers Off, operate the machine controller to the measured table position, then Touch-Off, energize the steppers, and run the job.
Can anyone provide an alternative procedure to set-up the mill ?
John.
  • Soccer Kid
  • Soccer Kid's Avatar
28 Apr 2025 07:35
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
The test results of versions 2.9.3 and 1.6.4 are consistent
  • scotta
  • scotta's Avatar
28 Apr 2025 05:21
Thanks Cakeslob, which board is the H723 being used? This will be a good test to see if we can get PlatformIO working happy with multiple targets. The code will need #ifdef's and compiler defines for each board to select the code changes needed for each H7 variant.
  • rodw
  • rodw's Avatar
28 Apr 2025 01:55
Replied by rodw on topic Homemade, cheap, plasma CNC
Category: Show Your Stuff
I thought you upgraded your machine to a Hypertherm 45XP or similar.
If that is the case, please use the Arc OK output on your plasma cutter as it will save you issues in the future.
You can get the cable (and the interface) for your plasma cutter from QWS in Brisbane
  • PCW
  • PCW's Avatar
28 Apr 2025 01:13
Thought experiment: Let's design a modern THC (+ Closed loop discussions)
Category: Plasma & Laser
An important aspect to keeping as much smarts in LinuxCNC as possible is that
complex control systems (like plasma control) work on all supported hardware. As
long as  LinuxCNC has enough control bandwidth, its an advantage to have a single
portable extensible and flexible solution with a single control locus (that has access
to all motion variables)
Do you really want to re-invent and maintain a control system that LinuxCNC can
do internally just as well? Buffered systems like Mach require this type of external
hardware, real time systems Like LinuxCNC do not.
  • unknown
  • unknown
28 Apr 2025 00:09
Replied by unknown on topic comparing to Grbl, or FluidNC
Category: Milling Machines
but in theory, a Grbl component could completely replace the EMCMot+Stepgen components in LinuxCNC for stepper motors signal generation.
Hmmmm ok
27 Apr 2025 23:50
OK, this i did not need to read twice, but from it now it seems you are searching for a problem that already has a solution, well several solutions.
The reference to old dumb drives is a bit disrespectful to old drives, they built the industrial complex we call modern ages, and it worked perfectly well for over 50 years.
Still, with a bit of tinkering, you can get a decent stand alone THC, probably using an ESP32 as it has 12 bit AD inputs, it can control stepper motors so everything on the Z axis can be controlled by it, it can do very fast PID loops, and adding void detection is as simple as checking the voltage rise time with delta-V/T or time.
A 3D printer screen with encoder, a nice simple menu, and that's about it.
There was a discussion here about adding controls to old plasma sources to change current from LinuxCNC, but that is not important anymore. Some relays would do the trick easily and some HAL wizardry.
This just shows the flexibility of LinuxCNC to adapt it to whatever is required, hence keeping stuff in LinuxCNC seems much more useful.
And, yes, QtPlasmaC has the ability to control plasma sources through RS485.
All this is in no way, shape or form meant to discourage you from trying to make such a thing, and i would gladly help and test whenever possible. I have plenty of CNC machines and plasma sources and ESP32 and 3D printers and... :)
Displaying 16501 - 16515 out of 17168 results.
Time to create page: 0.492 seconds
