  • BloodyT
  • BloodyT
18 Apr 2025 13:53
Replied by BloodyT on topic 7i95T & 7i77
7i95T & 7i77
Category: Basic Configuration
Thanks a lot!
if I understand correctly, you mean the FW is fine for using either step/dir on 7i95T or Analog on the 7i77? All I need to change is in ini, if I at some point have to/want to change motors?
i made it a step further. sadly the mesact tool also knows nothing about that card match, I used the 7i97T in the tool to get a basic Hal/INI and search/changed 7i95 to 7i95T. wich also wanted to startup. I kind of hacked something together. Now the machine starts at least, I see pins in halshow. so a win I guess?!
The conig is quite minimalistic. I just added the Axis xyz. the idea was to start with the basics and just go step by step - adding outputs and inputs later on, to minimize error.
my idea was to just have axis, jog them, watch for +10/-10v output in halshow.
sadly I already ran into another issue I don't quite understand. hope it is fine to ask another question in this thread.
The issue: I can "power" the machine and as I try to jog an axis I get "follow error". I don't see any feedback/encoders configured. why?!
Also I don't see any voltage output on the analog ports. maybe there is something wrong with my ini/hal or I am looking in the wrong place in halshow. I don't really know...
I share my Hal and ini if someone wants to take a look
  • pgf
  • pgf
18 Apr 2025 13:16
Are the program's extents available to the g-code?
I see why that should work.
The problem is that, because the machine is homeless, I set the soft limits to about twice as much as I actually have. This means I can home wherever I like, then set up G54, and it just works, without ever having to move to an actual home position on startup. And I can usually tell if my carve will exceed limits, so it's usually not an issue.
I'll think about changing that workflow.
  • spumco
  • spumco
18 Apr 2025 13:01
tormach 1500mx modifications, 4th axis, fast I/O expansion, auxilary spindle.
Category: PathPilot
Well, that's one way to skin the cat.
If you struggle with PathPilot and the USB IO, maybe a combination with the PLC would be the best solution.  Use the last remaining high-speed input and output to trigger the PLC to do the automation stuff and report back to PathPilot?
I'd imagine the cut-off saw spindle motor could be triggered by a USB output, since that can just run all the time.  And the saw motion connected to as the "A" axis so you can control saw infeed speed.
Let the PLC handle the clamping/unclamping, stock advance, and remnant eject, and then signal PathPilot to continue the G-code loop.
  • spumco
  • spumco
18 Apr 2025 12:52
Need help making rotary axis behave like second spindle
BINGO, adding the halui line did the trick. Thank you PCW and spumco, you guys are amazing (and lighting fast responders).
Thanks for reporting back, and glad to hear it's sorted out.
BTW, the "=>" and "<=" in the line are just characters to help the user visualize the pin to signal connection.  They are not required, and are ignored by LCNC.  I personally find single-line HAL entries nearly impossible to read, but breaking them up in to multiple lines does make for a much longer HAL file.
For example, the single line:
net machine-is-on hm2_7i76e.0.stepgen.04.enable halui.machine.is-on
is the same to LCNC as:
net machine-is-on  <= halui.machine.is-on
net machine-is-on  => hm2_7i76e.0.stepgen.04.enable
  • PCW
  • PCW's Avatar
18 Apr 2025 12:50
Replied by PCW on topic 7i96s Watchdog Ethernet
Category: Deutsch
It's worth a try, but...
Did you actually disable AMT?
Still don't know where base.tmax" and "servo.tmax" come from.
These are suspicious as they do not exist in a standard LinuxCNC installation.
  • PCW
  • PCW's Avatar
18 Apr 2025 12:41
Replied by PCW on topic Spindle will not stay running
if I change the VFD to manual control the spindle works fine. Testing the 10V spindle out seems to be fine for the 1 second then drops to 0v. The machine almost always goes to "Machine Off".
The question then would be why you get to the machine off state. (this will certainly turn off the spindle)
If you start LinuxCNC from the command line, are any errors displayed?
18 Apr 2025 12:40
Not tested, but try:
-home the machine at MACHINE 0 limits with G53
-jog the machine to PART 0 and touch off with G54
If you have the machine limits set correctly in the ini file, if any move would exceed the machine limits, LinuxCNC will show a warning asking you if you want to continue, do not continue if this happens.
  • pgf
  • pgf
18 Apr 2025 12:24
I'm working on carving a piece that's really a little too big for my mill.  It barely fits if I rotate it 45 degrees, and carve it that way.  But the size and rotation make it hard to be sure no movement will exceed the machine limits, and sure enough, about halfway through a carving (a draft practice run, happily), I tripped a limit switch.
(I should clarify that my machine is "homeless".  "home" is always relative to the piece, so there's no way for the interpreter to know in advance that I'll be exceeding a limit.)
Are the program's extents (min/max X, min/max Y) available in variables that could be used by a canned subroutine?  I did a quick skim of the source, but didn't find anything obvious.
  • FPM
  • FPM
18 Apr 2025 12:01 - 18 Apr 2025 12:03
Replied by FPM on topic converting a tos/intos fngj 40
Category: Milling Machines
I connected the 7i77 to p1 and the 7i78 to p2, i assume this is the correct order.
I've tried to modify the hal so that the z-Axis is the stepper connected to the first interface of the 7i78. The encoder for the z-axis is connected to the 7i77. Is this more or less done correctly? (hal is attached).
Since the 7i78 has no enable signals for the steppers, is it possible to use the enable pin from the spindle, since i am not using this? and how do i need to mod the hal?
Thanks!
File Name: intos.hal
File Size:10 KB
  • ErwinCNC
  • ErwinCNC
18 Apr 2025 11:33
  • ErwinCNC
  • ErwinCNC
18 Apr 2025 11:30
Replied by ErwinCNC on topic 7i96s Watchdog Ethernet
Category: Deutsch
Hallo PCW,
ich habe noch einige andere Einstellungen versucht aber ohne Erfolg.
Eigentlich ist das Hobby fräsen und nicht Einstellungen in Linux CNC zu testen.
Deshalb habe ich überlegt einen Raspberry Pi 5 8gb zu kaufen. Jederzeit verfügbar, ein fertiges Image, kein raten / testen, passt bequem in den Schaltschrank.
Hältst du das für sinnvoll?
Grüße Erwin
  • RNZ
  • RNZ
18 Apr 2025 10:58
LinuxCNC and Linux and Ubuntu and PC and RPi ping issues with Mesa 7i96s
Category: Installing LinuxCNC
Yes it works perfectly. I would have to dig out the fix — it was suggested on the forum and the Pi5 setup has been flawless ever since.
  • ErwinCNC
  • ErwinCNC
18 Apr 2025 10:44
Hello Have you been able to fix the problem in the meantime?I am also thinking about using a pi 5 + 7i96s as I now have a second PC which is apparently not suitable for Linux CNC. If you were able to fix the problem, what was the cause and are you satisfied so far?
Regards Erwin
  • Grotius
  • Grotius's Avatar
18 Apr 2025 10:41
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
I was just able to compile the scurve planner with the original linuxcnc Makefile system.
repository
Use the ./install script to install linuxcnc. It first installs the libscurve & libclothoid3d locally.
Then it just runs the axis_scurve_mm.ini config using scurve.
Hmm, interesting development.
Now a dev can make modifications to their needs, and merge it, if they want to.
Displaying 17026 - 17040 out of 17193 results.
Time to create page: 0.414 seconds
