  • GDTH
  • GDTH's Avatar
19 Apr 2025 11:39
Replied by GDTH on topic 7i80db 7i77 + 7i76 serup Hal conf
Category: Driver Boards
mesaflash --device ETHER --readhmid --addr 192.168.1.121 gives:
Configuration Name: HOSTMOT2
  BoardName : MESA7I80
  FPGA Size: 25 KGates
  FPGA Pins: 256
  Number of IO Ports: 4
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: IOPort
  There are 4 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: MuxedQCount
  There are 16 of MuxedQCount in configuration
  Version: 3
  Registers: 5
  BaseAddress: 3500
  Module: MuxedQCountSel
  There are 1 of MuxedQCountSel in configuration
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: StepGen
  There are 16 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: SSerial
  There are 2 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5A00
  Instance Stride: 64 bytes
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for J2
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       StepGen          0        Dir/Table2      (Out)
14                      1   IOPort       StepGen          0        Step/Table1     (Out)
 2                      2   IOPort       StepGen          1        Dir/Table2      (Out)
15                      3   IOPort       StepGen          1        Step/Table1     (Out)
 3                      4   IOPort       StepGen          2        Dir/Table2      (Out)
16                      5   IOPort       StepGen          2        Step/Table1     (Out)
 4                      6   IOPort       StepGen          3        Dir/Table2      (Out)
17                      7   IOPort       StepGen          3        Step/Table1     (Out)
 5                      8   IOPort       StepGen          4        Dir/Table2      (Out)
 6                      9   IOPort       StepGen          4        Step/Table1     (Out)
 7                     10   IOPort       SSerial          0        TXData0         (Out)
 8                     11   IOPort       SSerial          0        RXData0         (In)
 9                     12   IOPort       SSerial          0        TXData1         (Out)
10                     13   IOPort       SSerial          0        RXData1         (In)
11                     14   IOPort       MuxedQCount      6        MuxQ-IDX        (In)
12                     15   IOPort       MuxedQCount      6        MuxQ-B          (In)
13                     16   IOPort       MuxedQCount      6        MuxQ-A          (In)
IO Connections for J3
 1                     17   IOPort       StepGen          5        Dir/Table2      (Out)
14                     18   IOPort       StepGen          5        Step/Table1     (Out)
 2                     19   IOPort       StepGen          6        Dir/Table2      (Out)
15                     20   IOPort       StepGen          6        Step/Table1     (Out)
 3                     21   IOPort       StepGen          7        Dir/Table2      (Out)
16                     22   IOPort       StepGen          7        Step/Table1     (Out)
 4                     23   IOPort       StepGen          8        Dir/Table2      (Out)
17                     24   IOPort       StepGen          8        Step/Table1     (Out)
 5                     25   IOPort       StepGen          9        Dir/Table2      (Out)
 6                     26   IOPort       StepGen          9        Step/Table1     (Out)
 7                     27   IOPort       SSerial          0        TXData2         (Out)
 8                     28   IOPort       SSerial          0        RXData2         (In)
 9                     29   IOPort       SSerial          0        TXData3         (Out)
10                     30   IOPort       SSerial          0        RXData3         (In)
11                     31   IOPort       MuxedQCount      7        MuxQ-IDX        (In)
12                     32   IOPort       MuxedQCount      7        MuxQ-B          (In)
13                     33   IOPort       MuxedQCount      7        MuxQ-A          (In)
IO Connections for J4
 1                     34   IOPort       SSerial          1        TXEn2           (Out)
14                     35   IOPort       SSerial          1        TXData2         (Out)
 2                     36   IOPort       SSerial          1        RXData2         (In)
15                     37   IOPort       SSerial          1        TXData1         (Out)
 3                     38   IOPort       SSerial          1        RXData1         (In)
16                     39   IOPort       SSerial          1        TXData0         (Out)
 4                     40   IOPort       SSerial          1        RXData0         (In)
17                     41   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
 5                     42   IOPort       MuxedQCount      0        MuxQ-A          (In)
 6                     43   IOPort       MuxedQCount      0        MuxQ-B          (In)
 7                     44   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
 8                     45   IOPort       MuxedQCount      1        MuxQ-A          (In)
 9                     46   IOPort       MuxedQCount      1        MuxQ-B          (In)
10                     47   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
11                     48   IOPort       MuxedQCount      2        MuxQ-A          (In)
12                     49   IOPort       MuxedQCount      2        MuxQ-B          (In)
13                     50   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
IO Connections for J5
 1                     51   IOPort       SSerial          1        TXEn5           (Out)
14                     52   IOPort       SSerial          1        TXData5         (Out)
 2                     53   IOPort       SSerial          1        RXData5         (In)
15                     54   IOPort       SSerial          1        TXData4         (Out)
 3                     55   IOPort       SSerial          1        RXData4         (In)
16                     56   IOPort       SSerial          1        TXData3         (Out)
 4                     57   IOPort       SSerial          1        RXData3         (In)
17                     58   IOPort       MuxedQCountSel   6        MuxSel0         (Out)
 5                     59   IOPort       MuxedQCount      3        MuxQ-A          (In)
 6                     60   IOPort       MuxedQCount      3        MuxQ-B          (In)
 7                     61   IOPort       MuxedQCount      3        MuxQ-IDX        (In)
 8                     62   IOPort       MuxedQCount      4        MuxQ-A          (In)
 9                     63   IOPort       MuxedQCount      4        MuxQ-B          (In)
10                     64   IOPort       MuxedQCount      4        MuxQ-IDX        (In)
11                     65   IOPort       MuxedQCount      5        MuxQ-A          (In)
12                     66   IOPort       MuxedQCount      5        MuxQ-B          (In)
13                     67   IOPort       MuxedQCount      5        MuxQ-IDX        (In)
19 Apr 2025 11:35
Replied by tommylight on topic 7i80db 7i77 + 7i76 serup Hal conf
What does
report?
  • GDTH
  • GDTH's Avatar
19 Apr 2025 11:31
7i80db 7i77 + 7i76 serup Hal conf was created by GDTH
Hello,
I am trying to get a 7i80db-25 working with a 7i77 and a 7i76. I have installed a bitfile that should make this possible. When I start up linuxcnc I am not able to find the 7i77 and 7i76 board in the Hal conf. I was expecting something like hm2_7i80.0.7i77.input.
Am I doing something wrong or is it normal to just have a gpio list. If so how do I know what is connected to what.
19 Apr 2025 11:30 - 19 Apr 2025 11:38
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
As requested, deleted the empty posts.
For future reference, all users are able to delete their own posts.
Edit:
Apparently you did try and failed to delete the posts.
Can you edit them?
No matter what or how, feel free to do the same, namely request us to delete the posts.
Thank you.
19 Apr 2025 11:27
Replied by tommylight on topic Black Friday Deal got me :)
Category: Plasma & Laser
Music was nice! :)
Displaying 17101 - 17105 out of 17105 results.
Time to create page: 0.952 seconds
