16 Apr 2025 22:02
What are the chances of getting this setup working?
Category: Pick and Place
I am glad.
And i am fully aware of the pain and suffering those types of injuries incur, been over 30 years i messed my spine, still hurts more or less, over 20 years since i messed my knee still hurts daily, elbow, hand, left foot, etc etc.
I learned to live with the pain to the point of not noticing most of the time while working, but any strain reminds me. Luckily, it has not stopped me or even slowed down a bit...well maybe about 10% slow down in general.
  • my1987toyota
  • my1987toyota's Avatar
16 Apr 2025 20:49
Replied by my1987toyota on topic The dumification of humanity through internet
Then on the other side of the spectrum you have this
  • my1987toyota
16 Apr 2025 20:46
Replied by my1987toyota on topic What are the chances of getting this setup working?
if you're referring to my back it's as good as it is going to get. I have to be careful how much I lift
because If I do to much weight I could inadvertently start loosening the screws. For the most
part though I'm good.
  • Rockwood
  • Rockwood
16 Apr 2025 20:02
tormach 1500mx modifications, 4th axis, fast I/O expansion, auxilary spindle.
Category: PathPilot
Thanks for that great info on the drives, I hadn't identified the model yet.
I'm diving deeper into the user manual/electrical prints. They are pretty well done. tormach.com/support/mill/1500mx-documents
The prints confirm you are right on all counts. They are getting the I/O from the drives. The I/O board is called "Tormach Servo IO Breakout". and its connected to each drive with a cable.
And the axis drives are listed as:
"Inovance SV660N, AC Servo Drive, Ethercat, 220 Vac, 5.5 A, STO Function"
I'm likely going to add a 4th axis anyway. So either 5in 3out more will be enough for me, or I'll just buy a Beckhof module like PCW mentioned.
I'm sure I could repurpose some of those existing 25/15 I/O, I'm not going to have flood coolant, for example. But it would be nice to leave the factory stuff alone as much as I can, just for simplicity.
I also noticed the ATC option, which I was going to get, looks like it gives 2 more In and 1 more out unused. It looks like I've got plenty of I/O options.
Thanks for your response!
  • scotth
  • scotth
16 Apr 2025 18:59 - 16 Apr 2025 19:00
Replied by scotth on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
I can go back to a stable Debian system on this computer if needed. I have your original 2.10 on my HP, and it is working. I'm just trying to get the AMD system up with 2.10. It is not a panic situation at all.
Thank you.
  • notJamesLee
  • notJamesLee
16 Apr 2025 18:42 - 16 Apr 2025 18:43
Replied by notJamesLee on topic Determining Angular Scale - Help w/ Microsteps
Category: Configuration Tools
Friends,
from what I can only assume is inconsistencies in diameter or something but 533.33 is the number.
with 533 after 20+ revolutions you can see the starting point creep earlier -- indicating its just short of the number of steps to complete a full circle.
with 534 after 20+ it goes the opposite way.
I have a few follow up questions:
- what should i have the dip switches set to? Now that we've figured out they don't do anything to effect the steps per revolution is there an optimal value for this? I dont need insane amounts of torque or rpms
- is this something i can easily fix with the encoder once i do move to LCNC and tune in the encoder error?
thanks all for sanity checking me thus far, nice to know im not 100% crazy.
  • DarkPhoinix
  • DarkPhoinix
16 Apr 2025 18:42
Replied by DarkPhoinix on topic NVEM V5 LINUXCNC REMORA FIRMWARE[SOLVED]
forum.linuxcnc.org/18-computer/44828-rem...-cnc-board?start=380
I found something here, it's not easy to follow so many different cards and so many different topics in a discussion, it's even hard to find them!
16 Apr 2025 18:33
Replied by tommylight on topic 7i95T & 7i77
7i95T & 7i77
Category: Basic Configuration
Yes i meant the RPI required part.
I got fed up with RPI, first when i bought 3 and found out they are utterly underpowered and require huge amounts of time to get anything working on them (this was back in the RPI3B era), and got disgusted by youtubers shoveling them as the only option to run Klipper/3D printers during the pandemic when the price got to over 180$ !!! Second hand laptops are much cheaper and much more powerful, and can easily run Klipper.
  • PCW
  • PCW's Avatar
16 Apr 2025 18:24
Replied by PCW on topic PC GPIO pins
PC GPIO pins
Certainly possible but likely needs a hardware specific driver,
perhaps the RPI GPIO driver could be used as an example.
  • PCW
  • PCW's Avatar
16 Apr 2025 17:34 - 16 Apr 2025 17:35
Replied by PCW on topic 7i95T & 7i77
7i95T & 7i77
Here is a 7I95T+7I77 configuration
I numbered the encoders and sserial ports to match
a simple 7I77 configuration, so say a 7i92+7i77
configuration can be used with just a card name change
(from 7i92 to 7i95)
All 7I95T I/O is also supported but you would probably
need to create a separate 7I95T configuration and merge hal
files to support the I/O and step/dir channels
File Name: 7i95t_7i77...4-16.zip
File Size:305 KB
  • notJamesLee
  • notJamesLee
16 Apr 2025 17:25
correct, thank you.
I wanted a closed loop belt for a lot of reasons. Its next to impossible to get on a closed loop belt without some sort of tensioning device.
I am with you on avoiding complexity, this is the third rev of this cutting head for that exact reason.
  • BloodyT
  • BloodyT
16 Apr 2025 16:44 - 16 Apr 2025 17:02
Replied by BloodyT on topic 7i95T & 7i77
7i95T & 7i77
Hi @PCW
currently the machine (old Plasma) uses analog servo motors, that's why I added the 7i77. I need 10v/-10v for the Axis.
i am not entirely sure if I add encoders to the board in the future. at the moment they are hooked up to the servo drives.
my thoughts where, If at some point something breaks, and I add a more modern motor to some axis I can handle this with the 7i95T in the future.... that's why its kind of redundant(analog and step/dir).
also I don't know if everything on this machine is really working. its kind of "dead in the corner" for years, and we try to give it a second live. :)
is it possible to have all ports of all cards at the same time present?
or do I have to choose between?
  • BloodyT
  • BloodyT
16 Apr 2025 16:31 - 16 Apr 2025 16:51
7i95T & 7i77
....successfully got my pi5 running with LinuxCNC 2.10 (which I read is required to run a 7i95T).
Where did you read that?
I meant 2.10, not the pi ;)
what's wrong about the pi's?
for me right now the pi is just handy, because I have it here. maybe I change it to a miniPC at some point... I am not sure... but first I need to get a working cards/hal/ini
  • Philip Lydin
  • Philip Lydin
16 Apr 2025 16:31
Replied by Philip Lydin on topic Probe_basic paramters not updating.
Category: QtPyVCP
aha ok im using the lathe version
16 Apr 2025 16:29
Replied by tommylight on topic LinuxCNC S-Curve Accelerations
Though "included" ≠ "enabled"
They are enabled when installed and fully functioning.
Displaying 17116 - 17130 out of 17241 results.
Time to create page: 0.452 seconds
