- GDTH
19 Apr 2025 11:39
Replied by GDTH on topic 7i80db 7i77 + 7i76 serup Hal conf
Category: Driver Boards
mesaflash --device ETHER --readhmid --addr 192.168.1.121 gives:
Configuration Name: HOSTMOT2
BoardName : MESA7I80
FPGA Size: 25 KGates
FPGA Pins: 256
Number of IO Ports: 4
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 4 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 16 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3500
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: StepGen
There are 16 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: SSerial
There are 2 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for J2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData0 (Out)
8 11 IOPort SSerial 0 RXData0 (In)
9 12 IOPort SSerial 0 TXData1 (Out)
10 13 IOPort SSerial 0 RXData1 (In)
11 14 IOPort MuxedQCount 6 MuxQ-IDX (In)
12 15 IOPort MuxedQCount 6 MuxQ-B (In)
13 16 IOPort MuxedQCount 6 MuxQ-A (In)
IO Connections for J3
1 17 IOPort StepGen 5 Dir/Table2 (Out)
14 18 IOPort StepGen 5 Step/Table1 (Out)
2 19 IOPort StepGen 6 Dir/Table2 (Out)
15 20 IOPort StepGen 6 Step/Table1 (Out)
3 21 IOPort StepGen 7 Dir/Table2 (Out)
16 22 IOPort StepGen 7 Step/Table1 (Out)
4 23 IOPort StepGen 8 Dir/Table2 (Out)
17 24 IOPort StepGen 8 Step/Table1 (Out)
5 25 IOPort StepGen 9 Dir/Table2 (Out)
6 26 IOPort StepGen 9 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData2 (Out)
8 28 IOPort SSerial 0 RXData2 (In)
9 29 IOPort SSerial 0 TXData3 (Out)
10 30 IOPort SSerial 0 RXData3 (In)
11 31 IOPort MuxedQCount 7 MuxQ-IDX (In)
12 32 IOPort MuxedQCount 7 MuxQ-B (In)
13 33 IOPort MuxedQCount 7 MuxQ-A (In)
IO Connections for J4
1 34 IOPort SSerial 1 TXEn2 (Out)
14 35 IOPort SSerial 1 TXData2 (Out)
2 36 IOPort SSerial 1 RXData2 (In)
15 37 IOPort SSerial 1 TXData1 (Out)
3 38 IOPort SSerial 1 RXData1 (In)
16 39 IOPort SSerial 1 TXData0 (Out)
4 40 IOPort SSerial 1 RXData0 (In)
17 41 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 42 IOPort MuxedQCount 0 MuxQ-A (In)
6 43 IOPort MuxedQCount 0 MuxQ-B (In)
7 44 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 45 IOPort MuxedQCount 1 MuxQ-A (In)
9 46 IOPort MuxedQCount 1 MuxQ-B (In)
10 47 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 48 IOPort MuxedQCount 2 MuxQ-A (In)
12 49 IOPort MuxedQCount 2 MuxQ-B (In)
13 50 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for J5
1 51 IOPort SSerial 1 TXEn5 (Out)
14 52 IOPort SSerial 1 TXData5 (Out)
2 53 IOPort SSerial 1 RXData5 (In)
15 54 IOPort SSerial 1 TXData4 (Out)
3 55 IOPort SSerial 1 RXData4 (In)
16 56 IOPort SSerial 1 TXData3 (Out)
4 57 IOPort SSerial 1 RXData3 (In)
17 58 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 59 IOPort MuxedQCount 3 MuxQ-A (In)
6 60 IOPort MuxedQCount 3 MuxQ-B (In)
7 61 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 62 IOPort MuxedQCount 4 MuxQ-A (In)
9 63 IOPort MuxedQCount 4 MuxQ-B (In)
10 64 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 65 IOPort MuxedQCount 5 MuxQ-A (In)
12 66 IOPort MuxedQCount 5 MuxQ-B (In)
13 67 IOPort MuxedQCount 5 MuxQ-IDX (In)
19 Apr 2025 11:35
Replied by tommylight on topic 7i80db 7i77 + 7i76 serup Hal conf
What does
report?
report?
- GDTH
19 Apr 2025 11:31
7i80db 7i77 + 7i76 serup Hal conf was created by GDTH
Hello,
I am trying to get a 7i80db-25 working with a 7i77 and a 7i76. I have installed a bitfile that should make this possible. When I start up linuxcnc I am not able to find the 7i77 and 7i76 board in the Hal conf. I was expecting something like hm2_7i80.0.7i77.input.
Am I doing something wrong or is it normal to just have a gpio list. If so how do I know what is connected to what.
19 Apr 2025 11:30 - 19 Apr 2025 11:38
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
As requested, deleted the empty posts.
For future reference, all users are able to delete their own posts.
Edit:
Apparently you did try and failed to delete the posts.
Can you edit them?
No matter what or how, feel free to do the same, namely request us to delete the posts.
Thank you.
Edit:
Can you edit them?
Thank you.
19 Apr 2025 11:27
Replied by tommylight on topic Black Friday Deal got me :)
Category: Plasma & Laser
Music was nice!
Time to create page: 2.957 seconds
