  • PCW
  • PCW's Avatar
13 Mar 2025 19:39
Replied by PCW on topic Mesa modbus and pktUart
Category: Other User Interfaces
There have been no changes in mesa modbus that I know of
so all bugs are unchanged. I guess one possible workaround
until this can be fixed is to set the pktuart as the last module.
  • scotta
  • scotta's Avatar
13 Mar 2025 19:38
Replied by scotta on topic Remora with STM32H753ZI
The work for the H7 series is very close to ready. The core code is running and has been updated with a lot of refactoring. I wanted to take this opportunity to get the TMC SPI drivers incorporated, which is what I'm working on at the moment.
github.com/scottalford75/Remora-STM32H7xx
This is the development repo if you would like to have a look. If your board does not use a boot loader than this should get you going. This has been developed on an SKR3 board, so compare your crystal setup and adjust if needed.
Once I'm happy, I'll be adding the bootloader offsets etc in the code.
  • vre
  • vre
13 Mar 2025 19:36
Replied by vre on topic Mesa modbus and pktUart
the test was done with master version
2.9.4 will have the same bug or to try my luck ?
  • PCW
  • PCW's Avatar
13 Mar 2025 19:21
Most likely the driver (that has a number of known bugs)
  • vre
  • vre
13 Mar 2025 19:19
Is this due to hostmot2 firmware or hostmot2 driver of linuxcnc ?
  • PCW
  • PCW's Avatar
13 Mar 2025 19:16
OK I'll add this to the list of known Mesa modbus bugs.
  • Grotius
  • Grotius's Avatar
13 Mar 2025 19:03
Replied by Grotius on topic scurve trajectory planner
Hi all,
Tiny update.
I changed the axis gui colors to show white. This is better readable for web pages and documents.
For the code base :
The helix needed another update. When you trim a helix far enough, the helix turns "P" value is changing.
This is now also taken into account.
Had a lot off work to get the ringbuffer to work as should. It took me hours and hours.
But i am confident now.
I made about 3 example optimizers. From very simple to complexer. This to verify the planners behaviour.
Then finally the scurve has no isnan values anymore, this is fixed for ever.
So now straight on to the finish line.   LINUX FOREVER.
  • vre
  • vre
13 Mar 2025 18:50 - 13 Mar 2025 18:55
Yes correct does not work reliably to 115200 the problem appears to 9600 default speed and 32 i/o of module work fine the time bugs appears.
Problem maybe is not noise related because changing the order
of function lines without changing functions or pins in pin file the problem appears elsewhere..
Also appears in encoder of P1 port and eletech is connected to P3 via ttl to modbus adapter.
Chanching the ordering of functions in constant ModuleID : ModuleIDType without changing pin entries
changes the problem.
From that tests i have done is not due noise but software related maybe some data are written or read from wrong place.
  • Aciera
  • Aciera's Avatar
13 Mar 2025 18:49
Incorporating HAL script recommendation (2.7.14 to 2.9.4 conversion of XZC
You can set the file to be loaded on startup by adding this to the [DISPLAY] section of your ini file:
OPEN_FILE = /full/path/to/file.ngc
If you want no file loaded you can try
OPEN_FILE =""
13 Mar 2025 18:37
Replied by tommylight on topic ATC Tool Rack implementation gesucht
Category: Deutsch
m6 remap atc site:linuxcnc.org
This returns only results from our web and forum containing those words.
  • TangentAudio
  • TangentAudio
13 Mar 2025 18:32
Replied by TangentAudio on topic Qtvcp Development Discussions
Category: Qtvcp
The main shortcomings I can think of:
- it's built primarily for my current conversion project (XYZW axis Bridgeport knee mill). I undid many of the things in QtAxis that made it a more generalized.
- it's built specifically for a 1920x1080 touchscreen in landscape
- I intentionally stripped out key shortcuts because I am integrating a physical control panel, and intend to change several more things for the same reason soon.
- No documentation
I was able to figure out where to add the GUI files and sim config files in the source tree, so I can submit a PR if desired. I'm still not sure if it's a more hassle for everyone to make it part of LinuxCNC right now vs. continuing development in my own repo until it's more mature.
  • PCW
  • PCW's Avatar
13 Mar 2025 18:29
The encoder data issue may be electrical noise related.
I guess it could be a Mesa modbus bug but its a bit strange
that it seems to affect physically nearby signals.
How is the RS-485 interface connected to the 7I80?
Also on baud rate issue, the eletec I/O module will not run at 115200
baud reliably, it crashes and can only be recovered by a power cycle
of the I/O module. I suspect a stack error at 115200 baud  interrupt
rates in the I/O module. Running at 115200 baud the card crashes in
a few hours, at 9600 baud its been running a week so far.
  • Benb
  • Benb's Avatar
13 Mar 2025 18:04
Replied by Benb on topic ATC Tool Rack implementation gesucht
Category: Deutsch
use an internet search engine such as Google Chrome Type:
linuxcnc : m6 remap for atc
you get few answers to your questions.
  • vre
  • vre
13 Mar 2025 17:38 - 13 Mar 2025 18:10
There is another config that shows bug to pktuart module..
With this config and connected eletech 32io modbus module that is in working condition
in halshow encoder.04 read crazy data without connected anything to it.
if disconnect eletech module crazy data stop appear in encoder inputs .
streamable.com/civoip
The problem seems related to hostmot2 firmware or linuxcnc driver.
Memory leak?
library IEEE;
use IEEE.std_logic_1164.all; -- defines std_logic types
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Copyright (C) 2007, Peter C. Wallace, Mesa Electronics
-- http://www.mesanet.com
-- This program is is licensed under a disjunctive dual license giving you
-- the choice of one of the two following sets of free software/open source
-- licensing terms:
-- * GNU General Public License (GPL), version 2.0 or later
-- * 3-clause BSD License
-- The GNU GPL License:
-- This program is free software; you can redistribute it and/or modify
-- it under the terms of the GNU General Public License as published by
-- the Free Software Foundation; either version 2 of the License, or
-- (at your option) any later version.
-- This program is distributed in the hope that it will be useful,
-- but WITHOUT ANY WARRANTY; without even the implied warranty of
-- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-- GNU General Public License for more details.
-- You should have received a copy of the GNU General Public License
-- along with this program; if not, write to the Free Software
-- Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-- The 3-clause BSD License:
-- Redistribution and use in source and binary forms, with or without
-- modification, are permitted provided that the following conditions
-- are met:
-- * Redistributions of source code must retain the above copyright
-- notice, this list of conditions and the following disclaimer.
-- * Redistributions in binary form must reproduce the above
-- copyright notice, this list of conditions and the following
-- disclaimer in the documentation and/or other materials
-- provided with the distribution.
-- * Neither the name of Mesa Electronics nor the names of its
-- contributors may be used to endorse or promote products
-- derived from this software without specific prior written
-- permission.
-- Disclaimer:
-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-- "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-- LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
-- FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-- COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-- INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-- BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
-- LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
-- CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
-- LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
-- ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-- POSSIBILITY OF SUCH DAMAGE.
use work.IDROMConst.all;
package PIN_SVST8_4_72 is
constant ModuleID : ModuleIDType :=(
(HM2DPLLTag, x"00", ClockLowTag, x"01", HM2DPLLBaseRateAddr&PadT, HM2DPLLNumRegs, x"00", HM2DPLLMPBitMask),
(WatchDogTag, x"00", ClockLowTag, x"01", WatchDogTimeAddr&PadT, WatchDogNumRegs, x"00", WatchDogMPBitMask),
(IOPortTag, x"00", ClockLowTag, x"03", PortAddr&PadT, IOPortNumRegs, x"00", IOPortMPBitMask),
(PWMTag, x"00", ClockHighTag, x"08", PWMValAddr&PadT, PWMNumRegs, x"00", PWMMPBitMask),
(StepGenTag, x"02", ClockLowTag, x"04", StepGenRateAddr&PadT, StepGenNumRegs, x"00", StepGenMPBitMask),
(QcountTag, x"02", ClockLowTag, x"08", QcounterAddr&PadT, QCounterNumRegs, x"00", QCounterMPBitMask),
(PktUARTTTag, x"02", ClockLowTag, x"01", PktUARTTDataAddr&PadT, PktUARTTNumRegs, x"00", PktUARTTMPBitMask),
(PktUARTRTag, x"02", ClockLowTag, x"01", PktUARTRDataAddr&PadT, PktUARTRNumRegs, x"00", PktUARTRMPBitMask),
(LEDTag, x"00", ClockLowTag, x"01", LEDAddr&PadT, LEDNumRegs, x"00", LEDMPBitMask),
(NullTag, x"00", NullTag, x"00", NullAddr&PadT, x"00", x"00", x"00000000"),
constant PinDesc : PinDescType :=(
-- Base func sec unit sec func sec pin
IOPortTag & x"01" & QCountTag & x"02", -- I/O 00
IOPortTag & x"01" & QCountTag & x"01", -- I/O 01
IOPortTag & x"00" & QCountTag & x"02", -- I/O 02
IOPortTag & x"00" & QCountTag & x"01", -- I/O 03
IOPortTag & x"01" & QCountTag & x"03", -- I/O 04
IOPortTag & x"00" & QCountTag & x"03", -- I/O 05
IOPortTag & x"01" & PWMTag & x"81", -- I/O 06
IOPortTag & x"00" & PWMTag & x"81", -- I/O 07
IOPortTag & x"01" & PWMTag & x"82", -- I/O 08
IOPortTag & x"00" & PWMTag & x"82", -- I/O 09
IOPortTag & x"01" & PWMTag & x"83", -- I/O 10
IOPortTag & x"00" & PWMTag & x"83", -- I/O 11
IOPortTag & x"03" & QCountTag & x"02", -- I/O 12
IOPortTag & x"03" & QCountTag & x"01", -- I/O 13
IOPortTag & x"02" & QCountTag & x"02", -- I/O 14
IOPortTag & x"02" & QCountTag & x"01", -- I/O 15
IOPortTag & x"03" & QCountTag & x"03", -- I/O 16
IOPortTag & x"02" & QCountTag & x"03", -- I/O 17
IOPortTag & x"03" & PWMTag & x"81", -- I/O 18
IOPortTag & x"02" & PWMTag & x"81", -- I/O 19
IOPortTag & x"03" & PWMTag & x"82", -- I/O 20
IOPortTag & x"02" & PWMTag & x"82", -- I/O 21
IOPortTag & x"03" & PWMTag & x"83", -- I/O 22
IOPortTag & x"02" & PWMTag & x"83", -- I/O 23
IOPortTag & x"00" & NullTag & x"00",
IOPortTag & x"00" & StepGenTag & x"81", -- I/O 48
IOPortTag & x"00" & StepGenTag & x"82", -- I/O 49
IOPortTag & x"04" & QCountTag & x"01", -- I/O 26
IOPortTag & x"04" & QCountTag & x"02", -- I/O 27
IOPortTag & x"04" & QCountTag & x"03", -- I/O 28
IOPortTag & x"00" & PktUARTTTag & PktUTNDrvEnPin, -- I/O 32 TX PKTUART PIN
IOPortTag & x"00" & PktUARTTTag & PktUTDataPin, -- I/O 31 TX PKTUART PIN
IOPortTag & x"00" & PktUARTRTag & PktURDataPin, -- I/O 30 RX PKTUART PIN
emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin, -- added for IDROM v3
emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin);
end package PIN_SVST8_4_72;
13 Mar 2025 17:26
Replied by tommylight on topic QTPlasmaC post processor - SheetCam?
Category: Plasmac
in the ini file
HOME_OFFSET = -3
if metric
and
HOME_IGNORE_LIMITS = YES
So it does not trip limits while homing.
Left some comments on the video.
Displaying 17671 - 17685 out of 18589 results.
Time to create page: 0.346 seconds
