  • smc.collins
  • smc.collins
11 Mar 2025 17:45
Implementing Spindle Homing for DELTA C2000 Plus (In)correctly?
Category: EtherCAT
the origin switch is probably what your after, but you might want to make sure it consistently repeats to within a few encoder counts every time or it's useless for things like threading etc.
  • Bjornstabo
  • Bjornstabo
11 Mar 2025 17:24
Replied by Bjornstabo on topic Plasmac Post Processors
Category: Plasmac
SOLVED: Doug solved my problem, now it works great!
  • PCW
  • PCW's Avatar
11 Mar 2025 17:16
Replied by PCW on topic Mesa 7i96s PID Spindle Setup
Category: Basic Configuration
You should never get a runaway, but you will get oscillations with a too high PID value
To avoid a runaway around 0 speed where a negative PID output may occur might require
some hal magic, say using the PID output sign to run the VFD direction signal or forcing the
PWM value to 0 when the PID output is negative.
  • PCW
  • PCW's Avatar
11 Mar 2025 16:53
MBT -> GPT to reuse existing installation
Category: Installing LinuxCNC
"uspace" in this context means using a Preempt-RT kernel.
(rather than RTAI or some other real time kernel)
  • scda
  • scda's Avatar
11 Mar 2025 16:42 - 11 Mar 2025 16:54
Replied by scda on topic Mesa 7i96s PID Spindle Setup
Thanks. Yeah I think the main problem was that I have set the P value too high (above 2 is too much --> runaway). So the system seems to be working now.
  • I set a non-zero value to the DEADBAND setting (10)
  • I am using a low pass filter on the encoder feedback signal before feeding it to the PID loop
  • I use a low P value to stop the system "from running away"
#  Spindle0
setp   pid.s.Pgain     [SPINDLE_0]P
setp   pid.s.Igain     [SPINDLE_0]I
setp   pid.s.Dgain     [SPINDLE_0]D
setp   pid.s.bias      [SPINDLE_0]BIAS
setp   pid.s.FF0       [SPINDLE_0]FF0
setp   pid.s.FF1       [SPINDLE_0]FF1
setp   pid.s.FF2       [SPINDLE_0]FF2
setp   pid.s.deadband  [SPINDLE_0]DEADBAND
setp   pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp   pid.s.error-previous-target true
setp hm2_7i96s.0.pwmgen.00.enable 1
setp hm2_7i96s.0.pwmgen.00.scale [SPINDLE_0]MAX_RPM
setp lowpass.0.gain [SPINDLE_0]LOWPASS_GAIN
setp    hm2_7i96s.0.encoder.04.counter-mode 0
setp    hm2_7i96s.0.encoder.04.filter 1
setp    hm2_7i96s.0.encoder.04.index-invert 0
setp    hm2_7i96s.0.encoder.04.index-mask 0
setp    hm2_7i96s.0.encoder.04.index-mask-invert 0
setp    hm2_7i96s.0.encoder.04.scale  [SPINDLE_0]ENCODER_SCALE
net spindle-index-enable      =>    pid.s.index-enable
net spindle-enable            =>    pid.s.enable
net spindle-vel-cmd-rpm         =>    pid.s.command
net spindle-vel-fb-rpm          =>    pid.s.feedback
net spindle-output            <=    pid.s.output        => hm2_7i96s.0.pwmgen.00.value
net spindle-vel-cmd-rps        <=    spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs    <=    spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm        <=    spindle.0.speed-out
net spindle-vel-cmd-rpm-abs    <=    spindle.0.speed-out-abs
net spindle-enable        <=    spindle.0.on             # =>    hm2_7i96s.0.pwmgen.00.enable
net spindle-cw            <=     spindle.0.forward        =>    hm2_7i96s.0.outm.00.out-04
net spindle-ccw            <=    spindle.0.reverse         =>    hm2_7i96s.0.outm.00.out-05
net spindle-revs            =>    spindle.0.revs
net spindle-at-speed        =>    spindle.0.at-speed
net spindle-vel-fb-rps      =>    spindle.0.speed-in            <=     hm2_7i96s.0.encoder.04.velocity
net spindle-vel-fb-rpm_raw    =>    hm2_7i96s.0.encoder.04.velocity-rpm    =>     lowpass.0.in
net spindle-vel-fb-rpm        <=    lowpass.0.out
net spindle-index-enable    <=>    spindle.0.index-enable
  • PCW
  • PCW's Avatar
11 Mar 2025 16:18
Normally this is just done with normal PID,
with FF0 set to 1 and PWM scale set to RPM at 10V
PID would mainly be for Keeping constant RPM vs load.
If you have major non-linearities, these can be corrected with
the lincurve component.
  • scda
  • scda's Avatar
11 Mar 2025 15:36 - 11 Mar 2025 15:52
Mesa 7i96s PID Spindle Setup was created by scda
Hi all,
I am working on a weiler cnc lathe retrofit. So far it works well, the only thing left ist the PID tuning of the spindle speed.
The spindle also works without PID but the offset to the actual speed varies quite a bit (not linear), I was hoping to correct this with a PID loop.
VFD: Huanyang with analog voltage input (0-10V).
Currently I am trying to figure out how to implenent the PID setup for this.
How can I scale the PID output to 0-10V (or 0-4600 rpm) ? Currently my PID output can be negative and so the pwmgen.value of the Mesa7i96s spindle is negative which does not work for my setup. I feed the PID ouput to the scaled pwmgen input.
I think the system has to adjust the current value sent to the pwmgen.value just below and above the current setpoint in order to adjust for velocity offset. I was thinking of using the sum function (which kind of works but also does not really correct the non-linearity) but I think there must be an easier way...
Cheers,
David
  • Lcvette
  • Lcvette's Avatar
11 Mar 2025 15:05
Replied by Lcvette on topic Permanent probing parameters
Category: QtPyVCP
Great, glad you got it sorted!
  • Stran_ge
  • Stran_ge
11 Mar 2025 14:35 - 11 Mar 2025 15:35
Replied by Stran_ge on topic Permanent probing parameters
Category: QtPyVCP
Nvm i got it working. I forgot to actualy update the .var file itself so it startet at number 5xxx and not 3xxx.
So new parameters couldnt be stored.
  • Stran_ge
  • Stran_ge
11 Mar 2025 14:26
Category: QtPyVCP
I did update the subroutines folder for the latest Version of probe basic.
So do i have to manually go and edit the probe_basic.var?
  • Todd Zuercher
  • Todd Zuercher's Avatar
11 Mar 2025 14:20
Replied by Todd Zuercher on topic halui toggle button
halui toggle button
I'm sorry I am not as familiar with iocontrol v2, and missed that. I'm not sure what exactly the lube related pins do other than exactly what it says in the man page. As far as I know the pins will only be true if the machine is out of estop and the halui pin "halui.lube.on" is true. So it might be a rather toothless addition that doesn't really do much of anything, and you will still need to create appropriate logic to control it. I could be completely wrong, but I'm not seeing documentation to say otherwise.
  • Todd Zuercher
11 Mar 2025 13:56
Replied by Todd Zuercher on topic Probe and Touchoff
Probe and Touchoff
I'm not sure I understand what your trying to do with the fipflop component. I don't think it is necessary. (A hal input pin remembers the value it is given with a setp if it isn't connected to a signal and hal commands like setp in the hal file are only executed once when the hal file is loaded at start up.)
I would probably use a couple of custom M-codes to enable/disable the 2nd probe. In your hal file add a line to setp the value of the and2.0.in0. and remove all other hal file references to that pin. Then in the two M-code files setp the value of and2.0.in0 to true or false to enable and disable the input.
# Load logic components
loadrt and2 count=1
loadrt or2 count=1
addf and2.0 servo-thread
addf or2.0 servo-thread
setp and2.0.in0 false #Set probe2's input state to disabled at startup.
# Define probe inputs (Pin 0 and Pin 2)
net probe1-in <= hm2_7i96s.0.inm.00.input-00-not # Tool Touch-off probe (Pin 0)
net probe2-in <= hm2_7i96s.0.inm.00.input-02-not  =>  and2.0.in1 # Edge Finder probe (Pin 2)
# Enable Edge Finder only when connected
net probe2-final <= and2.0.out # Final state of Edge Finder # Allow probe2 (Edge Finder) if connected
# Send final signal to motion.probe-input
net probe1-in => or2.0.in0 #Combine probe 1 and 2 inputs
net probe2-final => or2.0.in1 #Combine probe 2 input (when enabled)
net probe_comb or2.0.out => motion.probe-input
Then to create an M101 M-code create a file containing the following, called M101 save it to your config dir and save as an executable file.
#!/bin/bash
# file to enable Probe2
halcmd setp and2.0.in0 True
exit 0
Then you can make another one to disable the probe called M102
#!/bin/bash
# file to disnable Probe2
halcmd setp and2.0.in0 False
exit 0
  • stenly
  • stenly
11 Mar 2025 13:40
Category: EtherCAT
Thanks for the overview.
I don't think that will work for me, as my encoder doesn't have a Z pulse. Just an A, B and R one. The motor itself has an origin switch that gives a digital output. The idea is to have that serve as the homing point, probably by using Homing Method 4 for Homing Mode (an operation mode in EtherCAT). I'm going to look into whether or not something like this has been discussed here, but for now it seems I'm the only one with this sort of setup, I think.
  • PCW
  • PCW's Avatar
11 Mar 2025 13:34 - 11 Mar 2025 16:13
Replied by PCW on topic Spindle PID RPM oscillates under load
You may be able to reduce the overshoot by using
the PID components maxerror pin. This should allow
higher P (and I) terms.
Also anything in the VFD setup that slows response
will limit the highest stable P term.
  • Wischi
  • Wischi
11 Mar 2025 13:09 - 17 Mar 2025 13:34
Hello guys,
i just started taking heavier cuts on my machine (Deckel FP2A) and i noticed that the rpm drops down, sometimes up to 150 rpm. The machine uses a 2.2 kW motor with a huanyang vfd. Between the motor and spindle is a belt drive as well as an gearbox (similar to the MAHO machines). Up until now i ran the spindle open loop. But since i added a encoder directly to the spindle i thought i could close the loop and use pid to counteract the rpm drops. I ran a couple of tests today but i was not able to keep the rpm steady under load. With all PID values at 0, except FF0 that was 1 during all the tests, i was already getting a good response (see halscope below). At around P=2 the over and undershoots started. So i tried P=0.5 and ran a test cut in mild steel (cut conditions below, machine should be more than capable for that). At the halscope you could see how to rpm drops and then oscillates. And the end of the cut the rpm came back up to the commanded speed. You can actually hear the rpm drop and accelerate.
I don't know how to continue from here, so i wish to get help from you guys! The pid with all values at 0 gives the best response but also makes it kind of useless. I attached a couple halscope diagrams of different tests below. They are always three: spindle startup, idling and under load. I also tired higher P values just to see if the pid is working. My spindle hal section is pretty much the default pncconf, only added the gearbox and vfd stuff (gear selection etc.). This might as well be a vfd issue, so i included my parameters that i have changed after a factory reset.
Thank you!
Cut conditions:
Warning: Spoiler!
Huanyang VFD HY04D043B 4kw 380V motor is wired in star config
Parameters:
Warning: Spoiler!
Displaying 17821 - 17835 out of 18592 results.
Time to create page: 0.533 seconds
