  • FraesPaul
  • FraesPaul
10 Mar 2025 22:20
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
3 Probably because QtDragon does not use the same enable pin as GmoccaPy, although if that is the case, i would really insist on fixing that in QtDragon.
Can you upload config files for both GUI's?
hattest Du schon Zeit mal einen Blick auf meine Konfiguration zu werfen ?
Have you had time to take a look at my configuration ?
  • PCW
  • PCW's Avatar
10 Mar 2025 22:02
7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
Category: Driver Boards
To invert a GPIO input, you use the inverted pin, for example:
hm2_7i95.0.gpio.054.in_not
  • Khan
  • Khan
10 Mar 2025 21:40
Replied by Khan on topic Delta VFD-B Modbus with QtDragon_hd
thank you,
you are right, i think there is already a driver available for my vfd, after some googling around i found this,
github.com/araisrobo/linuxcnc/tree/maste.../user_comps/vfdb_vfd
linuxcnc.org/docs/2.7/html/man/man1/vfdb_vfd.1.html
  • PCW
  • PCW's Avatar
10 Mar 2025 21:11
Replied by PCW on topic OLD Lathe conversion to a CNC
Category: Turning
In the lspci command:
lspci | grep -i eth
The | is a vertical bar character (pipe) not an uppercase i
  • besriworld
  • besriworld
10 Mar 2025 20:41
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
After the series of errors I decided to update. But I guess I've had this kernel before. During the update the system showed some errors... I'll try to investigate tomorrow.
  • Stran_ge
  • Stran_ge
10 Mar 2025 20:33
Permanent probing parameters was created by Stran_ge
Category: QtPyVCP
Hey,
are the probing parameters supposed to be reset after every pc restart or should they stay in the .var file.
For some reason after a pc restart they always revert to very old settings that i set long time ago.
Bst regards
Nils
10 Mar 2025 20:30
Replied by tommylight on topic LinuxCNC 2.9.4 Released
Category: Installing LinuxCNC
Update the kernel to at least 6.8.n, preferably 6.12.n.
10 Mar 2025 20:26
Replied by tommylight on topic OLD Lathe conversion to a CNC
Category: Turning
I wonder, why was the kernel not updated for the 2.9.4 ISO????
6.1.n kernel has huge latency and networking issues that are frankly getting to damn tiresome to read about them daily for nearly two years.
I have 6.8.n and 6.10.n on laptops without any issues.
  • besriworld
  • besriworld
10 Mar 2025 20:19 - 10 Mar 2025 20:20
Category: Turning
Thanks for joining. Here's what it showed.
moriseiki@debian:~$ sudo chrt -f 99 ping -i .001 -q -c 60000 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.065/0.074/0.241/0.007 ms
moriseiki@debian:~$ lspci I grep -i eth
Usage: lspci [<switches>]
Basic display modes:
-mm        Produce machine-readable output (single -m for an obsolete format)
-t        Show bus tree
Display options:
-v        Be verbose (-vv or -vvv for higher verbosity)
-k        Show kernel drivers handling each device
-x        Show hex-dump of the standard part of the config space
-xxx        Show hex-dump of the whole config space (dangerous; root only)
-xxxx        Show hex-dump of the 4096-byte extended config space (root only)
-b        Bus-centric view (addresses and IRQ's as seen by the bus)
-D        Always show domain numbers
-P        Display bridge path in addition to bus and device number
-PP        Display bus path in addition to bus and device number
Resolving of device ID's to names:
-n        Show numeric ID's
-nn        Show both textual and numeric ID's (names & numbers)
-q        Query the PCI ID database for unknown ID's via DNS
-qq        As above, but re-query locally cached entries
-Q        Query the PCI ID database for all ID's via DNS
Selection of devices:
-s [[<domain>]:]<bus>]:][<slot>][.[<func>    Show only devices in selected slots
-d [<vendor>]:[<device>][:<class>]        Show only devices with specified ID's
Other options:
-i <file>    Use specified ID database instead of eth
-p <file>    Look up kernel modules in a given file instead of default modules.pcimap
-M        Enable `bus mapping' mode (dangerous; root only)
PCI access options:
-A <method>    Use the specified PCI access method (see `-A help' for a list)
-O <par>=<val>    Set PCI access parameter (see `-O help' for a list)
-G        Enable PCI access debugging
-H <mode>    Use direct hardware access (<mode> = 1 or 2)
-F <file>    Read PCI configuration dump from a given file
  • jayyhu
  • jayyhu's Avatar
10 Mar 2025 20:06 - 10 Mar 2025 20:34
External comp driver for custom hostmot2 module
Category: HAL
Hello,
I'm currently in the process of creating a new module for the 7i80 FPGA, and realizing that I also need to add a driver on the LinuxCNC side. Since the module is pretty niche, I'm trying to avoid modifying the entire Hostmot2 driver (and then worry about having to maintain my local copy against master every time there's a version change), so I was wondering if it was possible to write a driver for Hostmot2 as an external comp. I've seen the mesa_7i65.comp and mesa_uart.comp examples, but I'm more interested in the low level register access (eg. how the inmux driver communicates with the inmux module on the FPGA).
Thanks,
James H.
  • rodw
  • rodw's Avatar
10 Mar 2025 19:56
  • rodw
  • rodw's Avatar
10 Mar 2025 19:53
Replied by rodw on topic QTplasmaC upgrade now huge latency
I still use a Gigbyte Brix J1900 and its fine if you follow my Bookworm guide.
docs.google.com/document/d/1jeV_4VKzVmOI.../edit?usp=drive_link
You will have a Realtek NIC so be sure to install the dkms driver as I describe.
  • rodw
  • rodw's Avatar
10 Mar 2025 19:40
MBT -> GPT to reuse existing installation
Use a new SSD.
Bookworm is pretty good with UEFI but I think I would try installing Trixie to get any later enhancements now there is a beta ISO release
You should be able to install Linuxcnc with:
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev mesaflash
The dev package installs halcompile etc
  • workshop54
  • workshop54
10 Mar 2025 19:17 - 10 Mar 2025 19:18
Error when starting LinuxCNC: “undefined symbol: kinematicsSwitch”
Thanks Todd,
It was actually much simpler. When watching the HAL tutorial from The Feral Engineer I noticed he had the following line at the top of his HAL file:
loadrt [KINS]KINEMATICS
That solved this issue for me.
  • PCW
  • PCW's Avatar
10 Mar 2025 18:52
Category: Turning
What are the results of:
sudo chrt ping -i .001 -q -c 60000 10.10.10.10
(takes 1 minute)
and
lspci | grep -i eth
Displaying 17866 - 17880 out of 18592 results.
Time to create page: 0.835 seconds
