  • Aciera
  • Aciera's Avatar
10 Mar 2025 16:54
  • Todd Zuercher
  • Todd Zuercher's Avatar
10 Mar 2025 16:35
Replied by Todd Zuercher on topic QTplasmaC upgrade now huge latency
The old Linuxcnc version would have been based on running a 32-bit version of Debian 7 (Wheezy) and depending on your hardware likely running the RTAI real time patched kernel. This worked well with many slower CPUs.
The latest versions of Linuxcnc's ISOs are based on 64-bit Debian 12 (Bookworm) and comes with a Preempt RT patched real time kernel. This system generally does not give good latency with slower CPUs. You may need to try to install an RTAI version. (I have not tried to get a current release of Linuxcnc running with RTAI so I can't be of much help there other than to point you to the documentation.)
linuxcnc.org/docs/stable/html/getting-st...#cha:Installing-RTAI
  • Todd Zuercher
10 Mar 2025 16:22 - 10 Mar 2025 16:24
Error when starting LinuxCNC: “undefined symbol: kinematicsSwitch”
I think you might be missing some essential entries in the [TRAJ] section of your ini file and one that's there may be named wrong.
You have:
[TRAJ]
COORDINATES = X Y Z
NO_FORCE_HOMING = 1
MAX_LINEAR_VELOCITY = 100.0
DEFAULT_VELOCITY = 50.0
Try changing it to:
[TRAJ]
COORDINATES =  X Y Z
NO_FORCE_HOMING = 1
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 50.0
  • robh
  • robh
10 Mar 2025 16:15
Replied by robh on topic Joint Error After large rotary move
Would be grate to get a driver update to 64bit i have done the job so so rush for me, once done i can test it out
because as i see it even if i reduce for half on the count , will only give 180 turns, twise as many parts output.
  • fabi0696
  • fabi0696
10 Mar 2025 15:41
Replied by fabi0696 on topic EL6731 changes cyclically to INIT status
Category: EtherCAT
Okay, then I'll look for this post.
The other terminals, e.g. the EL7041 terminals, work straight away. Only the ProfiBus does not start straight away after a Koppler restart.
I have the current TC3 project here again. I have changed the file extension tnzip to zip so that I can upload it.
File Name: LinuxcncNe...3-10.zip
File Size:195 KB
  • workshop54
  • workshop54
10 Mar 2025 15:24
Retrofit: Maho MH400E to LinuxCNC was created by workshop54
Category: Show Your Stuff
Retrofit: Maho MH400E naar LinuxCNC
Hi everyone,
I’ve recently started converting my Maho MH400E to LinuxCNC, and I’d like to share my progress here. I was inspired by RotarySMP—his posts gave me the courage to take on this project. Initially, I tried to get the original Philips control system working, but unfortunately, I couldn't get it to function. That led me to take the plunge and retrofit the machine with LinuxCNC.
Understanding the machine
To better understand how everything works, I fully translated the original manual into English. This has made it much easier to follow, especially when cross-referencing signals and system behavior.
Additionally, I’ve been diving into the control cabinet wiring and schematics, making sense of the machine's logic and how it all ties together.
Mesa hardware choices
RotarySMP used PCI-based Mesa cards, but since those are becoming outdated, I went with a different setup. After some research and trial and error, I decided on the following Mesa cards:
7i94T (Ethernet FPGA card)
7i77 (Analog servo interface)
7i84 (I/O expander)
So far, this combination seems to be working well, though I'm still troubleshooting some issues.
Current LinuxCNC setup
For now, I'm running LinuxCNC on an old laptop. It works, but eventually, I plan to upgrade to a dedicated PC.
As for the user interface, I’m currently leaning towards QtDragon, but that choice is still open for discussion.
What has been done so far:
1️⃣ Completely cleaned the machine (it was necessary!).
2️⃣ Organized the wiring in the control cabinet—technically not needed, but very satisfying.
3️⃣ Removed the original Philips CNC controller and monitor.
4️⃣ Translated the full machine manual into English.
5️⃣ Started analyzing the control cabinet logic and making sense of the schematics.
Current status of the Mesa cards/LinuxCNC setup:
✔️ I successfully established a connection with the 7i94T, which is in turn connected to the 7i77 via ribbon cable.
⚠️ However, I’m currently facing an issue, for which I have an open question on the forum.
I’ll be adding some photos of the machine and the Mesa cards soon. Looking forward to sharing more progress and learning from the community!
  • low-blip
  • low-blip
10 Mar 2025 15:15
Replied by low-blip on topic GladeVCP and venv?
GladeVCP and venv?
Category: GladeVCP
Did you figure it out? I want to use a Rust library in my VCP, but I only know how to install it as a package in a virtual environment.
  • workshop54
  • workshop54
10 Mar 2025 15:06
Hi everyone,
I’ve been stuck on this issue for quite a while now and I cannot figure out what’s going wrong. I’m very new to LinuxCNC, but I’ve been programming for quite a few years (and I feel like a junior dev all over again! ).
I’m getting an error when trying to run LinuxCNC with my linuxcnc.ini file. I hope someone can help explain what’s going on and how to fix it.
Here is the output when I start LinuxCNC:
johan@LinuxCNC:~/linuxcnc/configs/maho_mh400e$ linuxcnc linuxcnc.ini
LINUXCNC - 2.9.4
Machine configuration directory is ‘/home/johan/linuxcnc/configs/maho_mh400e’
Machine configuration file is ‘linuxcnc.ini’
Starting LinuxCNC…
Note: Using POSIX realtime
Found file(REL): ./maho_mh400e.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): 00:60:1b:18:80:0f
hm2_eth: discovered 7I94T
hm2/hm2_7i94.0: Low Level init 0.15
hm2/hm2_7i94.0: Smart Serial Firmware Version 43
Board hm2_7i94.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_7i94.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_7i94.0: 42 I/O Pins used:
motmod: dlopen: /usr/lib/linuxcnc/modules/motmod.so: undefined symbol: kinematicsSwitch
./maho_mh400e.hal:7: waitpid failed /usr/bin/rtapi_app motmod
./maho_mh400e.hal:7: /usr/bin/rtapi_app exited without becoming ready
./maho_mh400e.hal:7: insmod for motmod failed, returned -1
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
    /home/johan/linuxcnc_debug.txt
    /home/johan/linuxcnc_print.txt
as well as in the output of ‘dmesg’ and in the terminal.
Has anyone encountered this before? I suspect it’s related to the motmod module, but I’m not sure how to resolve it.
I’ve attached the relevant configuration and log files:
File Name: linuxcnc_info.txt
File Size:3 KB
File Name: linuxcnc.ini
File Size:1 KB
File Name: maho_mh400e.hal
File Size:2 KB
File Name: linuxcnc_debug.txt
File Size:0 KB
File Name: linuxcnc_print.txt
File Size:1 KB
Any help would be greatly appreciated!
  • Hakan
  • Hakan
10 Mar 2025 14:23
Replied by Hakan on topic EtherCAT plasma torch voltage reader
Got the new version, built and tested. This one works as well, no big difference from the previous version.
Maybe the linearity is a bit better, it goes to zero Volt now when there is no voltage.
View from initial test.
  • JTknives
  • JTknives's Avatar
10 Mar 2025 14:20
QTplasmaC upgrade now huge latency was created by JTknives
I just upgraded from a 2019 version of PlasmaC to the current QTplasmaC on a new SSD. I now am having massive issues with latency/jitter. I’m running a BRIX mini pc that’s sporting a J1900. In the past it was fine but now it wont even run. I went into the bios and disabled everything like I did in the past and disabled Wifi. I think befor my max jitter was like 20k but now the max jitter is Max Jitter (ns) 129316 / 106580
Am I just out of options with this older mini pc? Is it time to look for a more powerful cpu mini PC?
thanks for all your help.
  • Todd Zuercher
10 Mar 2025 14:19
Replied by Todd Zuercher on topic halui toggle button
halui toggle button
Category: Basic Configuration
For your coolant flood, you would use the "toggle2nist" component.
It has 4 hal pins:
toggle2nist.N.in Would connect to the output signal from your button input.
toggle2nist.N.is-on Would connect to the output signal from the hal pin "halui.flood.is-on".
toggle2nist.N.on Would connect to the input signal to the hal pin "halui.flood.on".
toggle2nist.N.off Would connect to the input signal to the hal pin "halui.flood.off".
There is not any pre defined pins designated for lube or spindle release. You must build your own logic to handle these functions.
Often machine integrators will set up custom M-codes (M100-199) that turn the required hal pins on or off. Then implement special logic (Hal or PLC) to prevent or enable the states as necessary. Such as preventing the tool from being released if the spindle is running.
  • emcPT
  • emcPT's Avatar
10 Mar 2025 14:10
Replied by emcPT on topic MBT -> GPT to reuse existing installation
Category: Installing LinuxCNC
The issue is that the disk is not listed there.
Motherboard is MSI. I will try something else later today, but does not look promising.
  • Todd Zuercher
10 Mar 2025 13:36
Replied by Todd Zuercher on topic Delta VFD-B Modbus with QtDragon_hd
I would consider integrating a drive using RS485 a more advanced subject.
Start with reading the Linuxcnc documentation, and begin with a basic configuration for running your machine without spindle control. Then after you have a better handle on Linuxcnc, and the basics of Hal programming, try to integrate the modbus spindle control into your configuration. There may be an existing modbus driver compatible with your drive. (I don't know, never used one.) If so that would probably make integrating RS485 control much simpler. But if not you can always make the generic Mb2hal driver work, but this is a bit of a chore to set up and configure. (I have done this before.) The generic RS485 drivers are a lot of work to set up because you must research all of your drive's modbus settings and communication parameters, and every drive (even different models from the same manufacturer can) have different parameter arrangement, there is no "standard" way drives do modbus.
  • endian
  • endian's Avatar
10 Mar 2025 13:28
Replied by endian on topic EL6731 changes cyclically to INIT status
Category: EtherCAT
If you are following steps which I have desribed somewhere here at the forum... It has to working properly every time on startup.. I am running profibus, profinet and canopen on single koppler in same time over ethercat
After koppler restart have a look at command -
sudo systemctl restart ethercat.service
... But U are decribing other type of problem... I am currently working on C# console app which will generate us configuration from ethercat slaves && ethercat pdos commands ... I have beta version but it is not too adult to outcome on public... Do U have a TC3 project?
  • Grotius
  • Grotius's Avatar
10 Mar 2025 12:35
Replied by Grotius on topic scurve trajectory planner
@Lcevette,
that is awesome!!
We hope so.
I had to add extra logic to the arc-helix.
When the arc-helix is trimmed at the front, i had to update the center point.
As the old center at the front is off plane after trimming.
The result looks ok now. Helixes in plane G18 & G19.
Deviation = 5.
If there are shorter segments, the clothoid fillet previews to be tinyer.
Also working on the look ahead now.
Displaying 17881 - 17895 out of 18591 results.
Time to create page: 0.719 seconds
