  • timo
  • timo
08 Mar 2025 12:51
Rigid Tapping - VFD and needed encoder ppm
Category: Milling Machines
Depends also on the number of sensors. If you increase the number of sensors it will give you more pulses per revolution. ( I think to put 4 sensors on the thing is a realistic approach)
The hardware is also a factor. How many ppr can your system keep track of?
Then (i did not try it) a floating tap holder can help compensate small deviations when it is not super accurate.
  • Nathan40
  • Nathan40
08 Mar 2025 12:44
7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
Category: Driver Boards
Hi.
How do we add the inputs for the 5axis BOB pins in the hal files? Please share the lines that needed to be added for inputs oF BOB in the hal files.
  • Aciera
  • Aciera's Avatar
08 Mar 2025 12:39
  • unknown
  • unknown
08 Mar 2025 12:21
I'm sure one on my exes had a Common Vagina, everyone used it.
I had a look inside once and I'll swear I saw a Texan looking for his horse.
Serial Port looks a little weird as well.
  • unknown
  • unknown
08 Mar 2025 12:16
Raspi 5 touchscreen experience - recommendation
Look for a touch screen that enumerates as HID (USB). Human Interface Device, these need no special drivers or such.
  • Surmetall
  • Surmetall's Avatar
08 Mar 2025 11:45
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
Sadly i only can add 8 pics in one post.
So here is one of the spindleservo with fan, gearbox, brake, belt...
and the machine in the warm workshop
  • Surmetall
08 Mar 2025 11:33 - 08 Mar 2025 11:36
Category: Turning
Hello all,
I have taken on a 2.2-ton heavy problem and started a new project: a CNC lathe from WEMAS, or Kovosvit MAS, built in 2000. So, it’s a 25-year-old German-Czech machine.     History of the machine: This machine was purchased by a larger company in 2000 and was used in prototype production until around 2004. Then, it encountered an issue with the electronics. After an internal move—after which it was never repaired—it was slated for scrapping. But that was far too good of a machine to throw away! Luckily, a dear friend stepped in to prevent that and played a significant role in getting it to me (thanks again, you know who you are!). To summarize: 2.2 tons, incredibly top-heavy, difficult to move, barely liftable, and broken... why would anyone take this on? Fortunately, I had professional help from my family for the (not-so-simple) transport, and it was soon safely at home. We disassembled it while it was still on the trailer to make it more manageable. It’s a massive cabinet made of robust 3mm steel sheet—very sturdy and maintenance-friendly, but it takes up a lot of space and isn’t exactly hobbyist-friendly. Plus, the weather wasn’t on my side, so I had to make it smaller quickly despite various challenges.
 Here’s a first look at its inner beauty. It stands there nearly smallish without the cabinet (I’d compare it roughly to a Weiler B Condor). To move it without hydraulics or a crane, I built a chassis from scrap parts (a broken flange and the lower part of a vice plate) using some hardware and heavy-duty wheels.With this setup, it can be maneuvered easily and very precisely with one person. it’s now flexible enough for the casing modifications. I’ve also given it a bit of a clean.
      Next step is planning and buying hardware for the conversion to LinuxCNC. I’d like to continue using the servo motors, as I believe they are definitely worth preserving. In particular, the spindle drive is fantastic. It’s a SIEMENS asynchronous servo motor with an external fan, brake, and a two-speed planetary gearbox. The motor can reach up to about 9000 RPM. Through the belt drive, I have spindle speeds of 0 to 1000 and 0 to 4000 RPM. Given the well-designed bearings and the belt in between, I’m hoping for excellent Surface-results.
Unfortunately, the large motor is both a blessing and a curse. The Heidenhain compact inverter is actually brilliantly small designed and should still work fine. However, it seems that the folks in Traunreut have turned it into a complex project, and it looks like you can only connect this thing to HH controllers. Documentation on this is almost non-existent, which is frustrating. So, finding a suitable (small) inverter for the spindle servo is not easy, and it’s not cheap either. The best option might be to go with a SIEMENS S120. However, the software, namely TIA Portal, is a significant hurdle for me.
I’ve been mulling over this for a few weeks now; if it weren’t for these issues, the machine would probably already be moving. I might even take the plunge into EtherCAT. That way, it could be easier to buy new motors and drivers for the X and Z axes directly (with absolute encoders and position feedback).
Finding a suitable driver for the large SIEMENS 1PH7105 servo is quite challenging. Perhaps something from Beckhoff, like an AX51? Or again a SIEMENS S120, which can sometimes be found very cheaply on eBay, although it’s primarily designed for ProfiBUS. There is an EtherCAT adapter available, but I fear that no one has tried it with LinuxCNC yet, and I don’t have the skills to tackle that.
Unfortunately, LinuxCNC and EtherCAT are still a bit of a mystery to me. I’m looking forward to hearing your thoughts and tips!
Best regards,
Tom
  • MillingMarvin
  • MillingMarvin
08 Mar 2025 11:12 - 08 Mar 2025 12:48
Rigid Tapping - VFD and needed encoder ppm was created by MillingMarvin
Hello Everyone,
I am planning to convert a BF20 Optimum Mill to CNC and want use rigid tapping.
I am currently redesigning the spindle. For rigid tapping, a encoder with A, B and Z pulse is needed, atleast that is what my reserch got me.
I would like to have the encoder directly on the spindleshaft, so no beld needs to be used.
So my question is, how many slots does this "encoder disc" need to have?
(1 slot would equal 2 pulses right? Rising edge and falling edge?)
And would it be possible and practical to use a ac motor with a vfd to do rigid tapping?
Any input is highly appreciated.
Thanks in advance!
  • zz912
  • zz912's Avatar
08 Mar 2025 10:14 - 08 Mar 2025 10:42
Replied by zz912 on topic Path to source code LCNC
"Python can find the path to the running code with the __file__ system variable."
I know it now.
It's even used right here:
github.com/LinuxCNC/linuxcnc/blob/1c72d4...cconf/pncconf.py#L33
"In both cases you probably need to use the Python path manipulation functions to assemble the required path."
stackoverflow.com help me with it. It is not problem for me.
Now I have enough information to implement my original plan.
Create new files in the linuxcnc/src/emc/usr_intf/pncconf folder and then copy them to the new LCNC configuration using pncconf.
However, @Aciera came up with a better idea.
He doesn't want to create new files in the linuxcnc/src/emc/usr_intf/pncconf folder.
He wants to use the original data from the configs/sim/gmoccapy folder.
The advantage is that there will be no unnecessary duplicate data in the source files.
The problem is that I don't know how to define this path cleanly: configs/sim/gmoccapy
This path is different for RIP installation and different for package installation.
github.com/LinuxCNC/linuxcnc/blob/40fe3e...rc/configure.ac#L702
github.com/LinuxCNC/linuxcnc/blob/40fe3e...rc/configure.ac#L724
I think this might solve my problem, but I don't know how.
  • Surmetall
08 Mar 2025 09:25
problem to start a new topic was created by Surmetall
Category: Forum Questions
Hello all, i tryed to start a new topic in "CNC Machines Lathes"
Sadly it dosent let me post :/
Is there a problem or is the problem in front of my pc? :D
  • abdulasis12
  • abdulasis12
08 Mar 2025 09:13
Replied by abdulasis12 on topic Machine Jerk When Post process all command CAM
I Found a problem
If use FACE process
next step after FACE , not include G64 P Q Line
maybe problem from Post Processor of fusion360
now my post $Revision: 44166 e813d608ccd22fb0949f73fcdb773b434407b131 $
I put G64 with PQ in  adaptive clearing step3 now can solved no machine jerky
Problem not from linuxcnc , problem from Post .
Thank you
Asis
  • StoneB
  • StoneB
08 Mar 2025 09:10 - 09 Mar 2025 20:56
Hello, I have gotten Linuxcnc running in my RPi 5 with MESA and am now moving on to cutting chips :) the original build uses a 10" Raspberry pi touchscreen (this: Cool hood 10.1 RPi screen), but I can't get the touchscreen part working. In the meantime I realize that 10" is small and I'd love to use the Probe Basic interface which required Full HD (1920*1080).
​​​​QUestion is: what touchscreen in 12-15" size have been proven working with a RPi 5?
I am interested in the Waveshare 13.3inch DSI LCD ( Waveshare ) as it seems to fit from compact dimensions and have drivers for bookworm. I see these are dependent on kernel though so I am now fearful it may not work with our RT kernels?
Any experience or other recommendation?
​​​​​​Thanks!
  • timo
  • timo
08 Mar 2025 08:25 - 08 Mar 2025 08:30
Replied by timo on topic Lathe spindle index only?
Category: Basic Configuration
I think at the end making your own encoder is similar effort like mounting a small timing belt.
Unfortunately hollow shaft encoders are much more expensive than the required parts. (timing pulleys, small timing belt and cheap encoder)
Maybe I should try ordering a slotted disc from a PCB maker for 2USD? They do drilling and milling and it is a matter of sending them the correct pcb file.
Displaying 17971 - 17985 out of 18591 results.
Time to create page: 0.445 seconds
