  • cmorley
  • cmorley
05 Mar 2025 02:41
Replied by cmorley on topic panelui
panelui
Category: LinuxCNC Documents
Did you see the docs?
linuxcnc.org/docs/devel/html/gui/panelui.html
and AXIS has a sample configuration:
github.com/LinuxCNC/linuxcnc/tree/2.9/co...im/axis/panelui-demo
It's been a while since playing with it but I'll try to help.
  • ihavenofish
  • ihavenofish
05 Mar 2025 02:33
05 Mar 2025 02:31
05 Mar 2025 02:27
Should I just suck it up and buy a good stepper driver?
Category: Driver Boards
HEXFET, TrenchFET, Epitaxial FET, .... damn i am getting old and this time i am not blaming it on being 3:15AM right now, there are many more types of MOSFET's, and almost all have flyback diodes, you can spend days sifting through catalogs to find any that does not
That is not the point at all, it is to show you how much we have to refrain here when we reply, ...
Again not the point, ....
The point is, do some reading and checking and rechecking before wiring and powering on stuff.
Take Unknowns advice, take a step back to reassess things.
As for TB6600 i have used the original ones and the smaller "not TB6600 despite being named so" and the "not TB6600" are much better and do not die at random. And can be found cheaper at 12-15$ a piece. Might have issues with DIP switches triggering from vibrations, though.
  • gwond
  • gwond
05 Mar 2025 02:22
Replied by gwond on topic Fusion 360 post processor file for Plamac
Category: Plasmac
Thanks, I tried the Merge circles, with the same outcome as before. I also found a test in the manual “isFullCircle()”, which returns False for this hole and true for all of the others. Should I try redrawing the hole or is the issue more so with the CAM processing? Maybe I should just keep testing different files and see how often this issue actually happens. Not a big deal to hand mark and drill this part, but more so just want to understand how to potentially resolve it he underlying issue and improve the robustness of the post processor.
  • ihavenofish
  • ihavenofish
05 Mar 2025 00:21
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
ok, i dont know what the issue was, but it works now. i see the slave.......
what next? :)
need a wizard :P
  • ihavenofish
  • ihavenofish
05 Mar 2025 00:11 - 05 Mar 2025 00:19
Replied by ihavenofish on topic Ethercat linuxcnc not seeing any slaves
Category: EtherCAT
ok so that was wifi. i switched back to the other... and now i see my slave. i dont really know what i did wrong before, but now we can start moving forward
yay
thanks
  • unknown
  • unknown
05 Mar 2025 00:07
Been reading this for while, I think you need to reassess what you think you know compared to what you actually know.
Usually the stepper drivers are pretty hardy, the ones I have in my mill are about 15 years old and haven't missed a beat.
I've never heard of anyone having to make modifications.
Some of the early TB6600 drivers weren't as reliable as they should have been, no experience with them myself but many reports of them being that way.
So just settle down, do things the recommended way and don't try to modify things that don't require modification. And if you still insist of doing board level mods consult the data sheets for the components that will be affected. I'm sure this would have resolved the issue of "no flyback diodes".
  • Daz
  • Daz
04 Mar 2025 23:49
Replied by Daz on topic Work with probe
Work with probe
Category: Basic Configuration
Yes, I am using GMOCCAPY UI, but I have just checked QTDragon_HD, and it looks really cool! I might be tempted to make a switch at some point. I am completely new to LinuxCNC, got it all up and running last week after pulling my hair out after experiencing multiple bugs with Mach3 and EC300(digital dream) controller. I have to say I am super happy, LinuxCNC is soooooo much better than Mach3.
  • ihavenofish
  • ihavenofish
04 Mar 2025 23:44 - 04 Mar 2025 23:45
Category: EtherCAT
switched to the second one which i thought was the wifi.. now it says link up. still no slaves though
Master0
Phase: Idle
Active: no
Slaves: 0
Ethernet devices:
Main: 60:36:dd:54:7b:49 (attached)
Link: UP
Tx frames: 488
Tx bytes: 29280
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Tx frame rate [1/s]: 124 34 6
Tx rate [KByte/s]: 7.3 2.0 0.4
Rx frame rate [1/s]: 0 0 0
Rx rate [KByte/s]: 0.0 0.0 0.0
Common:
Tx frames: 488
Tx bytes: 29280
Rx frames: 0
Rx bytes: 0
Lost frames: 488
Loss rate [1/s]: 124 34 6
Frame loss [%]: 100.0 100.0 100.0
Distributed clocks:
Reference clock: None
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000
  • ihavenofish
  • ihavenofish
04 Mar 2025 23:39
Category: EtherCAT
network ip/mac
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:23:24:3e:1b:ba brd ff:ff:ff:ff:ff:ff
altname enp0s25
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 60:36:dd:54:7b:49 brd ff:ff:ff:ff:ff:ff
inet 192.168.2.194/24 brd 192.168.2.255 scope global dynamic noprefixroute wlp2s0
valid_lft 257328sec preferred_lft 257328sec
inet6 fe80::6236:ddff:fe54:7b49/64 scope link noprefixroute
  • ihavenofish
  • ihavenofish
04 Mar 2025 23:35
Category: EtherCAT
only one network port on this machine plus the wifi for the internet.
I *think* im using the right one. haha. I dont see how i cant be.
dmesg spits out 10000 things. last one mentions lan at 100base though
  • Hakan
  • Hakan
04 Mar 2025 23:30
Replied by Hakan on topic Ethercat linuxcnc not seeing any slaves
Category: EtherCAT
Mac address and generic driver.
Two network interfaces and you picked the wrong one? Has never happened to anyone...
Ethercat master prints in /var/log/messages. Have a look there or at the end of the huge output of "sudo dmesg" for signs of why it won't use the network interface
  • ihavenofish
  • ihavenofish
04 Mar 2025 23:13 - 04 Mar 2025 23:22
Category: EtherCAT
so yes, that would have included typing in the MAC in that file per instructions
checked that file again. seems fine. reran enable, start, status... nothing changes.
  • ihavenofish
  • ihavenofish
04 Mar 2025 23:11
Category: EtherCAT
I did only what the instructions said up to the point of typing ethercat slaves.
Displaying 18241 - 18255 out of 18598 results.
Time to create page: 0.396 seconds
