22 Feb 2025 16:53
Replied by tommylight on topic estop issue
estop issue
Category: HAL
now the estop on the screen only reflects the physical button.    may be this is the way it is ment to work and i just had somthing different.
That should be the proper way, it should not be possible to enable the machine on screen while any of the e-stop buttons are pressed.
22 Feb 2025 16:45
Replied by tommylight on topic My Homemade plasma CNC
Category: Show Your Stuff
Dang, those are some nice cuts! :)
Should we move this to "show your stuff"?
  • MaHa
  • MaHa
22 Feb 2025 16:00
How to integrate manual spindle lock into Axis GUI?
phillc54 gave some good advice to display stuff in axis, some i have still in use.
This entry in the usercommand file
linuxcnc.org/docs/stable/html/gui/axis.html#_user_command_file
could be used to display the the state of the lock. Just replace  'spindle.0.inhibit' by the switch input.
To prevent run a program, i can only imagine, press F2 button.
#! /usr/bin/env python
W = root_window.tk.call
W('label','.pane.top.tabs.fmanual.jogf.zerohome.rot')
W('grid','.pane.top.tabs.fmanual.jogf.zerohome.rot','-column','0','-row','2','-sticky','w')
def user_live_update():
    W('.pane.top.tabs.fmanual.jogf.zerohome.rot','configure','-text','Spindle locked :  ' + str((hal.get_value('spindle.0.inhibit'))))
  • MaHa
  • MaHa
22 Feb 2025 15:41
Replied by MaHa on topic global named parameter error
You can solve that this way:
o800 IF [#<_task> EQ 1]
     #100=#<_varzag>
o800 ENDIF
  • jyeomans
  • jyeomans
22 Feb 2025 15:24
estop issue was created by jyeomans
estop issue
Category: HAL
i am not sure whether this is a hal issue or an issue with qtdragon_hd.
i have just installed 2.9 the newest build,
and rebuilt my machine.  on my old machine the esop on the screen and the physical estop worked independantly.
i liked it as i get the button on the oppiset side form the screen and i had an estop on both sides of the machine.
# --- ESTOP-EXT ---
net estop-ext <= hm2_7i76e.0.7i76.0.0.input-11
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
  • Grotius
  • Grotius's Avatar
22 Feb 2025 15:02
Replied by Grotius on topic scurve trajectory planner
@Hi
There are now different solvers in the codebase, in c and c++.
Performance:
Test object:
  • WKS-3D
  • WKS-3D's Avatar
22 Feb 2025 13:11 - 22 Feb 2025 13:14
Abfrage Werkzeugrevolver verschlossen
Category: Deutsch
Hallo Gemeinde,
ich bin dabei einen der 2 Sensoren für den Werkzeugrevolver zu definieren bzw. was zu tun ist, wenn der Sensor nicht ausgelöst wird.
Der Revolver wird von einem Pneumatikzylinder aus seiner Verzahnung gedrückt, dabei wird der Sensor unlocked ausgelöst, wenn die Position erreicht ist, darf der Motor den Revolver drehen. Danach wird der Revolver wieder nach hinten gezogen und ein 2. Sensor wird geschaltet, es sind also Positionsschalter. Mein Problem ist der 2. Schalter, wenn der Revolver zurückgezogen ist, wenn diese Position nicht erreicht wird und eine Fehlstellung vorliegt (zB Stepper Schrittverlust oder sonstige Störung) dann soll die Maschine ja nicht weiterfahren.
Das habe ich mit einem digitalen Input und M66 im M6-Macro versucht, was so weit auch zu funktionieren scheint:
M66 P0 L3 Q5
Jetzt ist es aber so, dass nach dem Timeout die Maschine trotzdem weitermacht.
Ich vermute da müsste eine Bedingung rein, aber ich weiß nicht, wie ich das am besten umsetze.
Mein M6 Macro:
o<toolchange> sub
G53 G0 X-5.
#4001=45            (bei 8 Positionen 360 Grad durch 8)
M61 Q#4999            (Werkzeug aus Speicher setzen)
o500 if[#<_current_tool> EQ #<_selected_tool>]
    (DEBUG,Tool bereits in Spindel)
o500 else
    G0 C[#<_selected_tool> * #4001-#4001]
    M6 G43
    #4999=#5400
    M66 P0 L3 Q5
o500 endif
o<toolchange> endsub
m2
Nun habe ich folgendes gelesen:
Q- - gibt den Timeout in Sekunden für das Warten an. Wird der Timeout überschritten, wird das Warten unterbrochen, und die Variable #5399 erhält den Wert -1. Der Q-Wert wird ignoriert, wenn das L-Wort Null ist (IMMEDIATE). Ein Q-Wert von Null ist ein Fehler, wenn das L-Wort nicht Null ist.
Wäre es dann so korrekt?
[code]o<toolchange> sub
G53 G0 X-5.
o500 else
    M6 G43
    #4999=#5400
    M66 P0 L3 Q5
    o501 if #5399=-1
         (DEBUG, Revolver nicht in Grundstellung)
         M0
    o501 endif
o500 endif
m2
Danke und Gruß
Olli
[color=#2ecc71] [/color]
[/code]
  • JT
  • JT's Avatar
22 Feb 2025 12:47
Replied by JT on topic Mesa Configuration Tool
Category: Configuration Tools
This is cool, I have Mesa CT making a working configuration for the 7i76EU now. Just need to add the spindle types.
Thanks PCW
JT
  • JuFu
  • JuFu
22 Feb 2025 12:11
Replied by JuFu on topic Macros. File not open
Category: Gmoccapy
I solved the issue by moving the files to the root of the machine configuration folder.
All of the files or macros only?
  • Hakan
  • Hakan
22 Feb 2025 12:05 - 22 Feb 2025 12:11
Replied by Hakan on topic EtherCAT plasma torch voltage reader
From what I have seen during the tests the torch voltage is below 200V. During start and piercing it easily goes up to 180V but not above that.
It cuts around 100V. Thin material in the 80s-90s, thick in the 110s.
The arc is also DCEN, DC electrode negative, I have been told. The work piece ground is not connected to mains ground.
200V isn't uncommon to have on a PCB, mains 230V AC is common here. My understanding is that with enough isolation distance it is fine. And the whole ADC side is isolated.
I think an ADS1115 can be used just as well, ebay aliX amazon are full of them at super low cost. To go with the 11-bit version meant that I get 3.3 kHz sample time. The ADS1115 is only 860 Hz max. That was the main factor. For the ADS1xxx ADCs one need to put them in continuous conversion  mode or the time to get a value is terrible, several milliseconds. In continuous mode its 150 microseconds. I know now how to read the ADS1014 which is actually two channels A0 A1, and I think it would be possible to use the ADS1115 with 15-bit resolution in continuous mode reading one differential channel (between A0 and A1). How important is updating exactly every 1 ms with a new value? It can't be that important, there is a bit of noise in the voltage and to read the same value every 7th time can't be that bad, can it? Anyway, that was the decision point and I choose 11-bit resolution, one differential channel and 3.3 kHz updating rate. The footprint is the same for those ADS1xxx so one can easily solder in another one, and reprogram. It is actually only something like 10 lines of code for the ADC.
The BAT54S is there to protect the input of the op-amp. Don't know much about that, it is something I found. The lmv321 was also not actively chosen but was known to work. I do see non-linearity at the very bottom of the range, so it isn't fully rail-to-rail. They aren't as I understood it, and it isn't important, it isn't working close to the rail voltages. But it means the display says 2V when it is 0V, but it should be linear above say 5V (in the 0-200V range).
Do you have an ohmic sensing solution when the plasma nozzle is the same polarity as the work piece?
I can see no change in voltage when the torch touches the work piece. I was hoping for that, but no.
I am very interested to include that.
  • Yaroslav
  • Yaroslav
22 Feb 2025 11:55
Replied by Yaroslav on topic Macros. File not open
Category: Gmoccapy
  • MaxEkb77
  • MaxEkb77's Avatar
22 Feb 2025 11:31
global named parameter error was created by MaxEkb77
Hello.
On linuxcnc 2.10, 2.9. (axis, gmoccapy)
I try enter in MDI  " #<_varzag>=55 "
after i try load ngc file when using that variable " #100=#<_varzag>.
I got error "Named parameter #<_varzag> not defined" , programm working fine - why showed that error ?
  • Nserega.90
  • Nserega.90
22 Feb 2025 10:35 - 22 Feb 2025 11:10
Replied by Nserega.90 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Hi John! Need your help! I ran into a problem: in the style sheet I made a style for buttons, I showed it in the video. That is, in the style there are different settings, but the main one is using an image as a button background! So I do absolutely the same thing for other buttons, that is, I apply the same style to other buttons and it does not work, or rather it works, but not quite correctly: in the video you can see that the button is not displayed. And when you hover over it, it applies the :hover and :pressed style, but the button inactivity style is not applied)))) what could be wrong? I attached the archive!
  • RDA
  • RDA
22 Feb 2025 10:32
Replied by RDA on topic EtherCAT plasma torch voltage reader
Looks good. I dont think you have issues with the voltage levels. In another thread I said I would scope out the work to electrode voltage to show what those voltages are, but unfortunately I have not had the chance, maybe next week.
When you use the divided arc voltage, you could put this design in to your easercat pcb, as in you dont need it to be separate.
If you find a decent 16-bit one example ADS1114IDGST then it might be worth the money. The 16-bit one gives you more opportunities if you want to make some additional features in the future, its quite a bit more expensive I know.
For the OP-amp if you find something with more tolerance in the input, that would make it safer but may not be worth it.
If you can give me an email address where you can be reached, I can share you an ohmic sensing schematic if you want to try it out and then share to the community.
  • jjdege
  • jjdege's Avatar
22 Feb 2025 10:28 - 22 Feb 2025 16:51
hi Scotta
I wanted to compliment you on the work you have done and made available
to the LinuxCNC community.
I am excited about it and I bought an NVEM V5 to try to install the Remora firmware,
but when I opened the case I noticed that the chip is not an STM32F207 but the one in the photo
is it still compatible or did I buy the wrong card?
Thanks if you can give me some advice
P.S. sorry Scotta
I went a bit back with the posts and at 191 there is the answer to my question, thanks,
I'll move on....
Displaying 18721 - 18735 out of 19018 results.
Time to create page: 0.502 seconds
