  • Aciera
  • Aciera's Avatar
21 Feb 2025 13:16 - 21 Feb 2025 13:43
Replied by Aciera on topic scurve trajectory planner
Why do the tranformations as used in the abstract?
Can't give you a definite answer to that but as long as we can't do it as described in the paper is seems a bit premature to want to modify the described method.
I see you have splitted up the gaus interpolation into x, y, z.
Well that's just a rough hack really that would need some streamlining but as long as nothing converges there is no point in polishing.
[edit]
And it looks like I have done it wrong having set ltot to 0
  • MTTI
  • MTTI's Avatar
21 Feb 2025 13:13
Replied by MTTI on topic 7I97T joint following error
I'm not an expert, but I think DEADBAND must be greater than 0.
Setting this parameter to 0 means that there is no tolerance between the theoretical and actual movement.
  • Muftijaja
  • Muftijaja
21 Feb 2025 12:58
motor-0-position error beim Abbremsen aus 4-7,5 m/min
Category: Deutsch
Hello PCW! Thanks for your hints yesterday.
I did some pings and latency histograms, I hope I can put the photos in here. I thought both was allright, but this motor-0-position errors (and "error-finishing-read" at start) seems to be persistent.
BTW, I tried the most of this thread: forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity and it was very successful in this regard, except these errors.
I think I try servo thread with 2 ms.
File Name: Hanno_Nr5_...2-21.hal
File Size:12 KB
File Name: Hanno_Nr5_...2-21.ini
File Size:6 KB
Thank you for your support!
Hanno
  • Hakan
  • Hakan
21 Feb 2025 12:35
Replied by Hakan on topic EtherCAT plasma torch voltage reader
Category: Show Your Stuff
The idea to power it from 24V stuck, I am going to do it that way. Will get rid of a 5V power supply in the cabinet.
The voltage reader can fit in a connector, that would be possible, but not the EtherCAT components. They need say 100x60 mm as it is today.
Two-sided and dense packing, no still not inside a connector.
I will try that idea to put the EtherCAT function on the plasma cutter. It doesn't make sense for me since it is a matter of 0.5 meter, but why not?
Could be a question of how long the ethernet cable can safely be versus how long the I2C cable can be.
That power injector/ejector is here on Monday.
I have a Herocut 55i, it is all very small scale, hobby and prototypes for my enjoyment.
I get voltage, arc-ok and can control torch-on. Power level, air pressure isn't, well require more work than I want to spend right now.
Must also say I am very happy with QtPlasmaC, works really nice.
  • Tinker
  • Tinker
21 Feb 2025 11:58
7I97T joint following error was created by Tinker
File Name: mill.ini
File Size:3 KB
File Name: main.hal
File Size:8 KB
Not sure if I'm posting this in the right place but I cant get past the joint following error to tune my -10/10 volt servos. I've reloaded everything several times with the same result... When I enable the drives the servos start drifting for about .001/.002 and then the following error. I am THE most computer illiterate person on earth and have no idea how to fix this thing. I've been trying for the last couple of months to get it going but can't get past this. With the help from this forum I've been able to get the network, mesa flash, mesa ct and card wiring complete but am stuck on this one.
  • denhen89
  • denhen89's Avatar
21 Feb 2025 11:48 - 21 Feb 2025 12:03
(LPT) Debian 12 Latency spikes/unexpected real time delay. Looking for solution.
Thank you for that.
Update: I have the pc at this moment at home, so i can do some tests while doing my work.
When i start latency-histogram and run it for some time (e.g. 15 min) with 3x glxgears the base thread looks good. Depending on the cpu bios settings i have stable max us of 20.000, but i found out that when i addionally start a youtube video (720p), the latency goes up, pretty quickly, almost directly after starting the video and then the latency jumps to 45000 then 60.000 and who knows how high it goes but then of course it doesnt matter anymore.
Of course i have to connect the pc back to the machine and see if it starts without unexpected real time delay and if the machines runs smooth, because after going from wheezy to debian 12 i had the situations where there latency-test (not histogram) showed good results in for a short time but the motors didnt move as they should.
While writing this post, the latency-histogram is still runing and still at 20.0 us. Maybe i am able to get it to work, but it seems that the vga might cause the latency spike and thats why i get a unexpected real time delay on start up.
What i could do next is to buy better ram, because one stick of the ddr3 1600mhz (2x4gb) ram that i had from my last main pc is not working, so i am currently using some old 1333mhz ddr3 2x2gb rams.
Also a onboard vga might give better results, but i dont have a pc with integrated vga to test it.
  • rodw
  • rodw's Avatar
21 Feb 2025 11:34
Replied by rodw on topic EtherCAT plasma torch voltage reader
Perfect! Not sure what plasma cutter you have but if it was say hypertherm, a surface mount circular connector that just pushes into the socket on the machine and you would have a nice complete self mounting package. I used the 7i76e spindle relay for torch on so there is nothing wrong with your photo diode. You just need to add a pull down resistor on the arcOK as discussed in the qtplasmac docs.
Of course if you had a XPR hi def its Ethercat anyway!
  • rodw
  • rodw's Avatar
21 Feb 2025 11:16
Red Machine Outline is backwards in Y dimension
Category: Qtvcp
Really think of the X,Y graphs you drew at school. You can choose any quadrant  but its  much easier playing in the positive  quandrant which places 0,0 at the bottom left and you play in the top right quandrant (Travel +X,+Y). It's easier to have home sensors near 0,0 but I do have a machine that was easier to put the y home sensor at max Y so I have a very long home_offset to move it back to the 0,0 position. I have thought of  changing the setup so I work in the bottom right quadrant so 0,0 is at top left close to the home switch. (travel would be +X, -Y) You never work in  raw coordinates  as you touch off your g54 offset so 0,0 is somewhere on your workpiece. If you touched off at bottom left of your workpiece, you would be working on the workpiece in that positive quandrant again. Sometimes you would touch off in the centre of your workpiece to bore a hole or make a motor mount, Sometimes you might also touch off at the back left against the corner of your vice jaws if you had a few parts to make. (travel +X, -Y). If I do this, I have a big magnet I stick on the jaws so I have a repeatable position.
  • JuFu
  • JuFu
21 Feb 2025 10:50
  • rodw
  • rodw's Avatar
21 Feb 2025 10:48
Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
I've not used it in earnest but QTplasmac installs fine with 4 axes with 2 motors on the gantry, XYYZA
I have installed it with 5 stepper drives though
Probably pair it up with Sheetcam rotary for CAM
  • Daan96
  • Daan96
21 Feb 2025 10:31
Then the choice seems quickly made; I'll have to get my hands on an old PC and start exploring Linux, which is completely new to me. Do you have it running on an old PC mounted near the table, or is it also possible to run Linux on a NUC?
In any case, I'll dive into the various posts on this forum while continuing with the mechanical design.
I see that QTPlasm doesn't work so easily for the rotation axis—perhaps I should leave it out for the first project and later build it as a standalone machine, just like Tommy did.
Thanks for the input! It's greatly appreciated!
  • JuFu
  • JuFu
21 Feb 2025 10:16
Switching HAL pin in subroutine (macro)
Category: O Codes (subroutines) and NGCGUI
I want to set / reset a HAL pin by using G-codes (switching a pneumatic valve on/off).
In the documentation G-code Overview | 4. HAL pins and INI values is written: " ... the only way to set HAL pins from G-code remains M62-M65, M67, M68 and custom M100-M199 codes."
I wrote the below subroutine (macro):
   o<test> sub
   (MSG, Spannzange öffnen)
   M62 #<_hal[hm2_7i76e.0.7i76.0.0.output-00]
   o<test> endsub
   M2
When I run the macro, the response is: "Benannter Parameter nicht beendet"
(Using gmoccapy Ver 3.4.9 in German language)
Is there a better way to control HAL pins?
If not, what do I need to do?
Juergen
  • Grotius
  • Grotius's Avatar
21 Feb 2025 10:10 - 21 Feb 2025 13:04
Replied by Grotius on topic scurve trajectory planner
@Arciera,
That's what i think we don't need. If the dogleg solver is able to find the endpoint in 3d space. Why do the tranformations
We have already a case where the helix tail or start from a G2, G3 is used as end vector.
Edit:
Did a mayor update on the infrastructure.
- Use struct for clothoid data.
- Use seperate plot function.
- Use enum to choose a solver from the list.
- Use a central residual function used by all solvers. Where the objective function can cast types.
  • Aciera
  • Aciera's Avatar
21 Feb 2025 10:06
As i understand it there should be no need for another transformation besides the one described in the paper.
  • JB-Motoring
  • JB-Motoring
21 Feb 2025 10:00
Replied by JB-Motoring on topic Mesa 7i97T + 7i84 + 7i78 configuration
Hey guys,
so I got Linuxcnc running- And I would like to test all i o 's on the bench before moving to the machine.
As soon as I hit enable (F1/F2) all assigned Analog Outputs show -10V.
There is no encoder or drive connected, just the naked Mesa on the desk.
How can I handle this to see, if the output is working?
Thanks guys!
Displaying 18796 - 18810 out of 19022 results.
Time to create page: 0.510 seconds
