11 Aug 2026 17:08
Replied by tommylight on topic Gantry oxyfuel / plasma type machine from scratch
I was wondering if I should buy direclty the 7i95T as it has all needed i/o and encoder feedbacks for up to 6 axis.
What you suggest ?
Yes, that would be better, but finding it sometimes not easy,
With Mesa, you can add inputs and outputs and PWM and encoder feedback as you see fit:
-more IO = 7i84 or 7i70 or 7i71 or 7i72
-more encoders = 7i85 or 7i85S (not the same, only half the same)
-more PWm for +-10V servos = 7i83
  • rodw
  • rodw's Avatar
11 Aug 2026 15:32
For such a large machine upgrading from the 7i96s would be a smart move as io is limited (but you can add extra boards). eg. Depending on your needs 7i76eu, 7i95t, 7i97t.
Note that if you do fall back to ethercat, with beckhoff, you just need to add an extra input or output module at any time as required at a cost of about $50 for another 8 ports.
Don't forget LinuxCNC can handle about 8 spindles so the drill could get a free ride on another Z axis stage if you are creative.
Does your table have downdraft zones?
  • rodw
  • rodw's Avatar
11 Aug 2026 15:01
Chinise mesa clone vs Original vs Ethercat
Category: Driver Boards
Yes, there will be synchronized movement as its all controlled by Linuxcnc on the single servo thread
  • rodw
  • rodw's Avatar
11 Aug 2026 14:51
Replied by rodw on topic Unable to Jog When HAL_ToggleBtn Active
halui.mode.teleop bit inpin for requesting coordinated jog mode
  • saxa
  • saxa
11 Aug 2026 13:25
That would be redundant as LinuxCNC is the motion controller.
In short:
-buy a Mesa 7i96S and a THCAD
What you suggest ?
I plan to set up a separate head in the future for plasma and who knows maybe even a spindle for drilling.
  • automata
  • automata
11 Aug 2026 09:55
Replied by automata on topic LinuxCNC S-Curve Accelerations
looking forward to your TP2. I would consider a few jerks in feed override an acceptable loss for using override as long as the max degredation of velocity is trapezoidal. Even a slight violation of max acceleration of an axis during the feed override is an acceptable degradation in my opinion.
If you are looking for a discussion on switchkins, I can help. When I first wrote switchkins, I could not think of an easy method to force a interpreter sync and yield type of queue buster which stops readahead. So looking at Fanuc and Hass, I added G12.1 and carried it through the complete chain of interpreter and motion. However dgarret came up with a much easier way to affect the queuebuster using M66 and remap which avoided touching so many files in the source tree for the switchkins feature.
For using axis limits during planning, the tool length which will become a parameter for the kinematics (including kinematics on the user side), could be carried through HAL or as a status variable from the #variables (#5401 to #5409).
I am looking forward to your release.
-automata
  • besriworld
  • besriworld
11 Aug 2026 09:53
Replied by besriworld on topic Chinise mesa clone vs Original vs Ethercat
I wonder if there are two interfaces. For example, the X and Y axes are controlled by the Ethercat and the Z axis is controlled by a Mesa card, will there be synchronized movements?
  • tuxcnc
  • tuxcnc
11 Aug 2026 09:23
GladeVCP panel fails to launch intermittently
Category: GladeVCP
I uninstalled Glade and then reinstalled it. The issue still persists.
I can't help you, but have a suggestion.
The "object has no attribute" is python's error and means "python can not finds", probably due bad path.
For me often helps to install python package in both ways, deb package and pip package.
  • aaron
  • aaron
11 Aug 2026 09:12
Replied by aaron on topic Update and upgrade debian bookworm.
Yes. When I try to upgrade,I one part of the error message reads:  raspi-firmware: missing /boot/firmware, did you forget to mount it?.
I cannot post full message because the system clock is wrong so internet is not working.........
  • scsmith1451
  • scsmith1451's Avatar
11 Aug 2026 08:15
Replied by scsmith1451 on topic Unable to Jog When HAL_ToggleBtn Active
I'm using the physical keyboard keys to control jogging.
Checking halui.mode.is-manual = FALSE. I attempted to set it to TRUE but halshow reported that the parameter is not writable.
Is there a way to force this pin to be high?
Regards,
  • rodw
  • rodw's Avatar
11 Aug 2026 08:12
Replied by rodw on topic gearchange
gearchange
Sometimes a custom component simplifies your hal file. Here is my solution for a similar problem where there are two belts each with 4 positions. But because it's not possible for both belts to use the same position, it comes down to the same problem you have. For the ratios, I just ran the spindle on each belt combination and read the actual rpm with a cheap laser tacho and did some maths. But I did not have levers, and made a panel for qtdragon which Chris "borrowed" for the qtdragon docs.
github.com/rodw-au/vmnmillqt/blob/main/scalebelts.comp
  • rodw
  • rodw's Avatar
11 Aug 2026 08:00
Thinking of moving my Plasma from Masso to LinuxCNC
Category: Plasma & Laser
Sean Drummond did a really nice diagram of a 7i96s which you can grab over at plasmaspider plasmaspider.com/viewtopic.php?p=231679#p231679
If you want a diagram you can't go better. I usually just create a table of all the pins and where that go. Its better to do it in a word document rather than a spreadsheet so you can add more freeform text/
  • scsmith1451
11 Aug 2026 07:52
Replied by scsmith1451 on topic GladeVCP panel fails to launch intermittently
Category: GladeVCP
Update: I uninstalled Glade and then reinstalled it. The issue still persists.
The errors thrown during launch not reads:
tool_mmap_user(): tool mmap not available
poll(): continuing without tool mmap data
gtk-builder-error-quark: crosshair_panel.glade:12:34 Invalid property: HAL_Table.n-rows (11)
**** GLADE VCP ERROR: With xml file: crosshair_panel.glade : 'gi.repository.Gtk' object has no attribute 'glade'
when launched from the panel from the command line:
$ gladevcp crosshair_panel.glade
Maybe I need to reinstall linuxcnc?
Regards,
  • Routerworks
  • Routerworks
11 Aug 2026 07:46
Replied by Routerworks on topic G Code viewer
G Code viewer
Thanks, I'll give it a try.
Displaying 1936 - 1950 out of 11357 results.
Time to create page: 0.170 seconds
