  • awallin
  • awallin
27 Oct 2026 12:50
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
Can someone give an update on the current (October 2026) status of homing with the Stepperonline A6 drives?
I got my servos moving and roughly tuned, but haven't been able to get homing working.
I tried to follow some of the cia402_homecomp examples, but I just get a following error immediately when starting homing. What are the exact pin-connections needed with cia402_homecomp?
FWIW I plan to use the negative limit switch + forward movement to next index method - not that the exact method for homing should matter much for getting this working..
  • PCW
  • PCW's Avatar
27 Oct 2026 12:17
Replied by PCW on topic 5i25, 6i25, 7i92, firmware request.
Category: Driver Boards
File Name: 7i92t_enc_...tepd.zip
File Size:198 KB
7I92T config for 8 encoders, 5 PWMgens, and one stepgen
Wasn't sure if you needed DIR on the PWMs so two of the PWMgens are
PWM only (no dir) due to  pin limitations, can easily change if needed.
  • dberegovoy
  • dberegovoy
27 Oct 2026 12:12
Lathe Spindle Encoder: What are the options for EtherCAT?
Category: EtherCAT
Hi everyone,
I just received my Omron NX-ECC201 today. The first thing I did was verify that it works, and I couldn't resist playing around with it a bit—I successfully toggled the LEDs on the output module directly from a Linux terminal via EtherCAT.
Now I am planning the next steps for my machine setup. I need to process an encoder signal, and after doing some research, it seems that the NX-EC0222 or NX-EC0122 modules would be the best fit since they support differential signals.
However, my current machine encoder operates on a 5V TTL signal. This leaves me with two main options:
1. Convert the 5V TTL signal up to 24V single-ended.
2. Convert the 5V TTL signal into a differential signal to feed it directly into the NX-EC0222.
I am leaning towards the second option (differential) because I feel it is much more noise-immune and future-proof for upcoming retrofit projects.
I would really appreciate your advice on choosing the best Omron module for this setup to help me narrow down my search.
Thanks in advance!
  • jazzkramer
  • jazzkramer
27 Oct 2026 11:16 - 27 Oct 2026 11:27
Replied by jazzkramer on topic It's me or it's a bug?
Category: Plasmac
Thanks , so I will not use emoticons jejeje.
So, follow up:
I will install as soon as possible the last version from...  instructions buildbot.linuxcnc.org/
so maybe errors are already corrected...
In the meantime, I'm attaching the gcode as modified by the "convers" in my QtPlasmaC. I saw I don't have the original produced by SheetcamTNG, I saved this on that one, so I only have this one (that is the one I was using).
About the error n 2, the "cutting in the air", while finishing the job (it's for a cantilever in my "borning shop"), I discovered the error is
when I press my custom button "Goto last X0Y0" before the Z axis finishes to reach the "idle height" after finishing a cut.
The button is a G0 X0 Y0 only (or it has Z0 as well? I have to check).
If I wait the Z axis to be at the idle height before pressing that button, the next cut properly works.
Bye, thanks,
have a nice day!
It did not attach the gcode, so I put it here:
;     file name: V2_Buco singolo.ngc
; date and time: Sun Oct 25 2026    01:44:24 PM
; postprocessor: LinuxCNC PlasmaC.scpost rev: 0.5
;begin pre-amble
 G21 (units: metric)
 G40 (cutter compensation: off)
 G90 (distance mode: absolute)
 M52 P1 (adaptive feed: on)
 M65 P2 (enable THC)
 M65 P3 (enable torch)
 M68 E3 Q0 (velocity 100%)
 G64 P0.254 Q0.025 (tracking tolerances: 0.254mm)
#<holes>      = 2
#<h_velocity> = 60
#<h_diameter> = 32
#<oclength>   = 4
;end pre-amble
;begin material setup
 T0 M6 (select plasma tool)
 G43 H0 (apply tool offsets)
 M190 P18 (plasma, mield steel + zinc 2mm material)
 M66 P3 L3 Q2 (wait for valid change)
 F#<_hal[plasmac.cut-feed-rate]>
;end material setup
 G0 X24.49 Y12.151
 M3 $0 S1 (plasma start)
 M67 E3 Q100
 G3 X17.928 Y15.211 I-4.811 J-1.751
 G1 X3.833 Y10.081
 G3 X7.167 Y0.919 I1.667 J-4.581
 G1 X35.358 Y11.18
 G3 X32.023 Y20.342 I-1.667 J4.581
 G1 X17.928 Y15.211
 M5 $0 (plasma end)
 ;begin post-amble
 M65 P2 (enable THC)
 M5 $-1 (backup stop)
 ;end post-amble
 ;begin statistics
 ;Pierces = 1
 ;   Cuts = 1,    Length = 98.67mm
 ;end statistics
 M30 (end program)
  • retrofitcenter
  • retrofitcenter
27 Oct 2026 08:29
Replied by retrofitcenter on topic Getting there... we plan to release soon enough
Category: Show Your Stuff
Interesting to see someone working in a similar direction! I’ve recently done something similar with my linuxcncMulti project. My version is already running and available to test online.
It remains compatible with existing LinuxCNC configurations and supports a large part of Siemens NC syntax, including transformations and measuring cycles. It also includes material removal simulation.
A more polished visualization using Godot is currently in development.
You can try it here: www.cnc.gmbh
Would be interesting to exchange ideas and compare approaches!
27 Oct 2026 06:58
Replied by tommylight on topic It's me or it's a bug?
Category: Plasmac
Yeah, our editor gets flummoxed by smileys, so it does not show anything after those.
  • jazzkramer
  • jazzkramer
27 Oct 2026 06:41
Category: Plasmac
maybe I found some answer about installation here buildbot.linuxcnc.org/ ...I'm reading. I was editing my previous post but... there something wrong and only the first part of my previous post is showing in the edit window... so I posted this one...
  • jazzkramer
  • jazzkramer
27 Oct 2026 06:32
Category: Plasmac
Hi :)
thanks Tommylight for moving the thread to the correct forum section, I thought I posted it to the PlasmaC section but I mistook posting it to the general section
Thanks Snowgoer540, I will post/attach the gcode as soon as I get to the machine: I have the original gcode produced by SheetcamTNG and the modified gcode I saved by the QtPlasmaC I was actually using.
I think about one month ago' I installed the LinuxCNC last version downloaded from linuxcnc.org (Current release: 2.9.10) because the one I got was skipping some hole parts (I found a post about it)... I thought it included the last version of QtPlasmaC.
So if I understand the one included is not the last version, so I would like to install the correct one.
How can I install the last QtPlasmaC version? And, I did not understand, are there two locations where QtPlasmaC is?
Where is the most recent one and how to install it please?
Thanks to all in advance! :)
Alberto.
Thank you! :)
  • my1987toyota
  • my1987toyota's Avatar
27 Oct 2026 05:20 - 27 Oct 2026 05:36
Replied by my1987toyota on topic Usefull Open Source software, vibe coded in Rust
Muzzer how problematic has it been to vibe code programs. I am thinking of trying it on a few ideas
I have floating around in my head. I have been learning Python coding but it has been a frustrating
journey to say the least. I'm also using Raspberry pi zero 2w so that may have something to do with it
And as luck would have it I am thinking of using Claude Code.
  • snowgoer540
  • snowgoer540's Avatar
27 Oct 2026 04:07
Replied by snowgoer540 on topic It's me or it's a bug?
Category: Plasmac
1) without your gcode it’s hard to tell what’s going on.
For the others, I would say that development for the qtplasmac in 2.9 stopped in August of 2024. Any and all bugs that have been brought up since have been addressed in 2.10.
It’s one of the unfortunate parts of the project that releases take years between versions. So much has changed in QtPlasmaC between version 2.9 and 2.10 that maintaining bug fixes in both locations for QtPlasmaC was not something I wished to spend my time doing.
Before he retired from the project, Phill rewrote a lot of the conversational code so I would imagine your issue has been solved in 2.10.
  • dberegovoy
  • dberegovoy
27 Oct 2026 02:42 - 27 Oct 2026 04:57
Replied by dberegovoy on topic 5i25, 6i25, 7i92, firmware request.
Thank you so much, that's excellent news.
The pinout doesn't matter since I will be soldering the cable myself.
I'm planning to use an EtherCAT setup with discrete I/O modules, so I mostly need the encoder functions on the Mesa card.
Could you please make the firmware with 8 encoders, 1 stepgen, and the remaining pins as PWM? I would need it for both the 7I92 and 7I92T, but the 7I92T is the priority since I have two of them. Any pinout layout works fine for me.
Thank you in advance!
  • tietouwa
  • tietouwa's Avatar
27 Oct 2026 02:01
Help identifying a CM5-based LinuxCNC controller
Hi everyone,
I came across a piece of CNC controller hardware running LinuxCNC. Does anyone recognize this setup or know who makes it?
I checked the system over SSH and found:
- Raspberry Pi Compute Module 5 Rev 1.0
- 2 GB RAM and 16 GB eMMC
- Debian 12 Bookworm
- LinuxCNC 2.9.3
- PREEMPT_RT kernel: 6.6.54-rt39
- CPU configured to run at 1.8 GHz
- Realtek RTL8111/8168 Ethernet controller using the ec_r8169 EtherCAT driver
- EtherCAT master 1.5.2
- WCH USB device (1a86:5537) using a custom ch37x driver, with /dev/ch37x0
- PCF8563 RTC
- Connected touchscreen
The EtherCAT master is detected, but its link is currently down and no slaves are connected.
Does this look like a known commercial controller or a custom carrier board? I would appreciate any information about its manufacturer, model, hardware revision, or available documentation and LinuxCNC configuration files.
Thanks!
  • Schaublin12
  • Schaublin12
27 Oct 2026 01:51
Replied by Schaublin12 on topic EtherCAT Master Beckhoff slave not found
Category: Basic Configuration
Ich dachte ich gebe euch mal wieder ein kleines Update zum aktuellen Stand: In der Zwischenzeit habe ich einen Nuc MiniPC gekauft und habe diesen PC statt der virtuellen Umgebung eingerichtet. Mein Servothread brauchte anfangs knapp über 1ms und ich musste die Aufgaben auf die Kerne verteilen. Jetzt bin ich unter 1mS. Ich habe einen Notaus mit manuellem Reset, ich kann „Maschine ein/aus“ über Taster steuern. Dann habe ich daran gearbeitet den Schneider ATV320 über das EtherCAT Modul in die Steuerung einzubinden. Das hat gut geklappt. Die Taster für M3,M4 und M5 haben allerdings gefühlt eine Ewigkeit gedauert.  Aber auch dieses Problem ist gelöst und die Taster funktionieren nach meiner Vorstellung. Dann kam noch Cycle start und Cycle stop dazu. Für feed hold sind mir die Taster ausgegangen. Aktuell warte ich noch auf eine Beckhoffklemme für meinen Joystick für x und y. Was wären noch wichtige Funktionen, die man als physikalischen Taster braucht? Was wäre ein praktisches Layout für das Bedienpanel?
  • PCW
  • PCW's Avatar
26 Oct 2026 23:46
Sure, it's possible, a 7I92X has 34 I/O pins so could have as many as 11 normal encoders
Do you have a desired pinout?
26 Oct 2026 18:41
Category: Plasmac
Moved to "PlasmaC" section.
Displaying 196 - 210 out of 11392 results.
Time to create page: 2.339 seconds
