  • Lcvette
  • Lcvette's Avatar
04 Feb 2025 17:52
Replied by Lcvette on topic Probing keeps failing
Category: QtPyVCP
did you update all of the config files? that is why i wanted to see your var file. if it was out dated it means all the subroutines are also outdated which would be a possible contribution to your issue.
once you have verified all of your config files have been correctly updated for the latest probe basic release requirements, if you still are getting the error then come back and we will have a further look at it. in the interim it is always best to run a comparison on config folders when you do an update. in many cases if there are substantial changes to probe basic that include configuration changes such as subroutine file edit and or adds/deletions, if you do not have those things will not work as expected. a quick test is to try probing in the sim, if it does not fail in 0.5mm, then you know its a config issue.
  • unknown
  • unknown
04 Feb 2025 17:50
Replied by unknown on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
If you build LinuxCNC now from Master you don't have to patch the kernel anymore from 6.12+.
To be clear, of course you still need a PREEMPT_RT built kernel.
Do you know if this has filtered down to 2.9.4 yet ?
  • unknown
  • unknown
04 Feb 2025 17:49
I'm trying to follow Deje63's step by step to build the RT Kernel but I end up with an error:
"reversed (or previously applied patch detected) assume -R?" when trying to run command
"patch -p1 < ../patch-$RT_PATCH_VERSION.patch".
I'm not sure what it meant so I tried to patch anyway but end upp with make throwing "Error 2" at me,.on makefile:1921. Any idea what this might be and/or how to rectify it?
OR even better if anyone might be able to share an .img with LinuxCNC working with Rpi5 and built on RaspberryOS Lite.
I can't get the GPIO pins to work with the distro on the downloads page and it looks like in the man pages that a build on RpiOS is necessary for this to work...
Edit: attached Deje's txt-file for convenience.
I can't get the GPIO pins to work this doesn't help.
and it looks like in the man pages that a build on RpiOS is necessary for this to work... This is not true
Output from a halrun session loading the driver
halcmd: loadrt hal_gpio inputs=GPIO5,GPIO6,GPIO12,GPIO13,GPIO16,GPIO17,GPIO18,GPIO19 \
halcmd+:                                 outputs=GPIO20,GPIO21,GPIO22,GPIO23,GPIO24,GPIO25,GPIO26,GPIO27 \
halcmd+:                                 invert=GPIO20,GPIO27 \
halcmd+:                                 reset=GPIO21,GPIO22
Note: Using POSIX realtime
halcmd: show pin
Component Pins:
Owner   Type  Dir         Value  Name
     4  bit   OUT         FALSE  hal_gpio.GPIO12-in
     4  bit   OUT         FALSE  hal_gpio.GPIO12-in-not
     4  bit   OUT         FALSE  hal_gpio.GPIO13-in
     4  bit   OUT         FALSE  hal_gpio.GPIO13-in-not
     4  bit   OUT         FALSE  hal_gpio.GPIO16-in
     4  bit   OUT         FALSE  hal_gpio.GPIO16-in-not
     4  bit   OUT         FALSE  hal_gpio.GPIO17-in
     4  bit   OUT         FALSE  hal_gpio.GPIO17-in-not
     4  bit   OUT         FALSE  hal_gpio.GPIO18-in
     4  bit   OUT         FALSE  hal_gpio.GPIO18-in-not
     4  bit   OUT         FALSE  hal_gpio.GPIO19-in
     4  bit   OUT         FALSE  hal_gpio.GPIO19-in-not
     4  bit   IN          FALSE  hal_gpio.GPIO20-out
     4  bit   IN          FALSE  hal_gpio.GPIO21-out
     4  bit   IN          FALSE  hal_gpio.GPIO22-out
     4  bit   IN          FALSE  hal_gpio.GPIO23-out
     4  bit   IN          FALSE  hal_gpio.GPIO24-out
     4  bit   IN          FALSE  hal_gpio.GPIO25-out
     4  bit   IN          FALSE  hal_gpio.GPIO26-out
     4  bit   IN          FALSE  hal_gpio.GPIO27-out
     4  bit   OUT         FALSE  hal_gpio.GPIO5-in
     4  bit   OUT         FALSE  hal_gpio.GPIO5-in-not
     4  bit   OUT         FALSE  hal_gpio.GPIO6-in
     4  bit   OUT         FALSE  hal_gpio.GPIO6-in-not
     4  s32   OUT             0  hal_gpio.read.time
     4  s32   OUT             0  hal_gpio.reset.time
     4  s32   OUT             0  hal_gpio.write.time
This is from the latest image. Now if something doesn't work, please please go into detail. How are we supposed to fix an issue when you don't elaborate on what happens ? I can't tell you how frustrating this is.
This driver wont work on the RPi5 hal_pi_gpio has it depend on the bcm2835 headers, which is applicable for the Rpi4 & Rpi3.
  • Aciera
  • Aciera's Avatar
04 Feb 2025 17:48
Replied by Aciera on topic Macros. File not open
Category: Gmoccapy
Just a stab but have you tried ./macros instead of just macros?
  • Aciera
  • Aciera's Avatar
04 Feb 2025 17:41 - 04 Feb 2025 17:44
Issue with Access - "pin is not writable" Error when using setp
Category: EtherCAT
It's an output pin of the cia402 component so the cia402 component writes the control word to lcec
#from cia402 to servo(ethercat)
net x-controlword         cia402.0.controlword => lcec.0.0.cia-controlword
  • my1987toyota
  • my1987toyota's Avatar
04 Feb 2025 17:39
Replied by my1987toyota on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
I have been bitten by the 3D printing bug as well and because of recent Bambu Lab events I am in the process of
building a Voron 2.4. To the vets who have done this before have you done the can bus print head conversion
and if so did it make things better, faster, ect?
  • Sternfox
  • Sternfox
04 Feb 2025 17:20
Replied by Sternfox on topic Probing keeps failing
Category: QtPyVCP
I have just copied over the latest probe_basic.var file from github and same results.
I have tested my probe in hal and I have two entries. Probe in and probe input. Only probe input is turning yellow when triggered.
  • bkt
  • bkt's Avatar
04 Feb 2025 17:07 - 04 Feb 2025 17:18
The dumification of humanity through internet
No tommy not study at 1800 ... only study element table as explain here in old continent with scientific Latin world .... All nation use a derived name, based on Modern Latin (silicium = modern latin .... silex = old latin) .... at end your explanation is right, But if you buy a table of element in Italy Silicium is the world ... or Silicio in italian ... Silicium is for most part of european people if they buy an original element table (not in local language).
Any how Tommy when study zilog80 and NE555 texas instruments (25 year ago) all manuals talk about Silicon. American manual obviusly ... Have you never noticed that the division between Christianity and Protestants here in Europe has also divided scientific studies? This is what happened.... we separated 300 years ago and even today we struggle to find the thread of union.
The dumification is an old history ... and history tends to be really boring!!! .... need to change it every one a little pieces .... THAT'S THE WAY !  (that I prefer to "may the force be with you").
  • Lcvette
  • Lcvette's Avatar
04 Feb 2025 16:57
Category: QtPyVCP
Post your var file
  • bkt
  • bkt's Avatar
04 Feb 2025 16:56
Replied by bkt on topic good day to all (in some gtp languages)
Aussie:
 but can chain an otto bin lid behind the bike
Dear Friend ... snow and drunk can be a good couple if after can go to sleep ..... my english I know is terrible .... after these I'm curious about your upper worlds ... seems like a figure to speech .... and honestly I know only "brass monkeys", no other unfortunately my flights is only for work, so is difficult to discover people culture. Here for me is a better place.
Ok you take a pause from work (chat gtp explain to me these is a typical australian slang) .... but where does these phrase came from? (I refer to ..... can chain an otto bin lid behind the bike ...) .
bye .... uknowwn member ....
  • Martin.L
  • Martin.L
04 Feb 2025 16:48
LinuxCNC with raspberry Pi5. Ethercat and step/dir interface.
For your actual machine I wouldn't bother with step/dir and go straight to another servo ethercat. Sell yours and with 150 difference you are already setup.
For your second machine take a look at FlexiHAL, you can directly slap a raspi5 in it. also they are designing a new board with Rj45 for step/dir and another guy is designing a board to swap A6 step/dir to Rj45. Join the printNC discord the board creator is there
  • Martin.L
  • Martin.L
04 Feb 2025 16:36
Replied by Martin.L on topic Modbus input for absolute encoder position?
My servos just need a boolean input, guess yours need the same
  • Martin.L
  • Martin.L
04 Feb 2025 16:32
Replied by Martin.L on topic Probing keeps failing
Category: QtPyVCP
Just fresh installed PB and probing works like a charm. Check probe behavior in halshow?
  • Sternfox
  • Sternfox
04 Feb 2025 16:26
Category: QtPyVCP
Thanks for the reply. I updated about a month ago.
So the behaviour is. No matter what i change the probe will only search down 0.5mm
Then I get a message saying G38.2 move finished without making contact.
Thanks Chris
  • Lcvette
  • Lcvette's Avatar
04 Feb 2025 16:17
Replied by Lcvette on topic Rack Tool Changer
Rack Tool Changer
Category: QtPyVCP
none yet, haven't had time with other more immediate machine issues im dealing with.
Displaying 19501 - 19515 out of 19548 results.
Time to create page: 0.374 seconds
